  • July 14, 2025, 10:47:14 AM
Author Topic: Cobra motor questing on mounting. How will you do it?  (Read 845 times)
Online Paul Taylor
« on: December 22, 2013, 05:01:18 PM »
I ordered on of the 40 size motors. It shipped the same day that I ordered it. Great service!
Anyway I get unlike 2 days, open the box to check things out. It has a mount for one side and came with a prop shaft to bolt up on the back. So are people using the shaft on the motor or the bolt on shaft?
I hope I explained that right?
Offline William DeMauro
Re: Cobra motor questing on mounting. How will you do it?
« Reply #1 on: December 22, 2013, 05:21:19 PM »
You can front mount it and use a standard collet. You can rear mount it using the x-mount and the screw on collet. You can take it apart, loosen the shaft, press it through and then rear mount it using a standard collet. Simply put, they can be mounted any way you need to mount them. I hope I explained this right. If not, feel free to give me a call.
AMA 98010
Offline Leo Mehl
« Reply #2 on: December 29, 2013, 12:06:04 PM »
I hope I explained that right? This is how I did it! HB~> HB~> HB~>
