  • July 12, 2025, 05:23:33 PM
Author Topic: Cobra electric motors are on sale!  (Read 2052 times)
Offline Crist Rigotti
« on: December 10, 2013, 07:16:29 PM »
Innov8tive Designs has them on sale!  Like 30% off.
http://www.innov8tivedesigns.com/index.php?cPath=21_120_122
Re: Cobra electric motors are on sale!
« Reply #1 on: December 15, 2013, 09:12:22 PM »
What size would be equal to a 50 size IC?
Offline William DeMauro
« Reply #2 on: December 16, 2013, 05:06:22 AM »
Better yet what do you want to put it in?
AMA 98010
« Reply #3 on: December 16, 2013, 11:27:21 AM »
Was thinking about a vector or SV 11 H^^
« Reply #4 on: December 16, 2013, 02:21:19 PM »
For the SV11 4 cell setup-  http://www.innov8tivedesigns.com/product_info.php?cPath=21_120_122&products_id=840&osCsid=43161239709c9e3b48abf0086923a10e    or this one  http://www.innov8tivedesigns.com/product_info.php?cPath=21_120_123&products_id=846&osCsid=43161239709c9e3b48abf0086923a10e
If you want a 5 cell set up let me know
For Vector use the 2820/12  970kv  or the 2820/14 840kv both should be ok on 4 cells
AMA 98010
« Reply #5 on: December 17, 2013, 05:49:39 PM »
Thanks William.
Offline Allan Perret
  • Proverbs
« Reply #6 on: December 28, 2013, 08:34:23 AM »
Hey William:
I would like to know your recommendations for the Cobra 5-cell motor.  Also would there be a significant weight difference in the battery pack needed 4 vs 5 cell ?  Thanks for the help.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Dan Bregar
  • Field Marshall
« Reply #7 on: December 28, 2013, 12:42:29 PM »
I'm not William, but the 2826/12 may be the mtr. you want, depending on what size airplane you intend to put it in.  Crist Rigotti has been using this mtr. very succesfully on 5 cell packs. He may chime in here also untill William can respond to your querry.  :)  Just make sure you don't over-dissipate it.  LL~
AMA 33676
« Reply #8 on: December 28, 2013, 08:41:37 PM »
Allen,
The 2826/12 like Dan says or the 3515/18 should work fine for most of our needs with a 5 cell. For some the 3520/14 may be a better choice. I have no idea what you want to use it in, but those would be your 5 cell choices in the majority of applications. Unless you plan on using those super light Thunderpower 5s2700 mah batteries(10.5 oz I think) your weight for batteries stays about the same weather you use a 4 cell set up or a 5 cell set up. Less cells=lower voltage=higher mah needed.  More cell =higher voltage=lower mah needed. So using very rough imprecise math (I'm no engineer) lets say a 4s4000 weighs 400 grams on average(I know I'm close), I would expect the average 5s 3000-5s 3300 to weigh about the same in most case as long as the C ratings are also comparable. If you go  to Hobby King's website and use their battery heaven battery finder program and plug numbers in for 4 and 5 cell packs using the numbers I just gave you will see that this actually works. Don't forget to sort by weight after you plug the numbers in.
AMA 98010
Offline Leo Mehl
« Reply #9 on: December 29, 2013, 11:39:46 AM »
Offline John Cralley
« Reply #10 on: December 29, 2013, 07:54:10 PM »
Thanks for the heads up Crist!!  y1
I have one on order for the Vector that I am building this winter!! You saved me enough to buy a cheapie battery. LOL
John Cralley
AMA 52183
Central Illinois
Offline Darkstar1
« Reply #11 on: December 29, 2013, 09:25:10 PM »
Hey William:
Allan
I bought a Cobra C-2826/12 Brushless Motor, Kv=760 for a 5s setup for a Brodak Bearcat. It is a copy of the AXI
Ill let U know what I think as soon as I can get it going.
Later,
Evolve or get left behind!
