  • June 19, 2025, 07:15:01 PM
Author Topic: cobalt motor question  (Read 1018 times)
Offline Alan Buck
« on: January 24, 2010, 10:19:04 AM »
I have one new in the box. is any good for anything in c/l flying. it is a CEM cobalt motor  cem 0506  thanks
ALAN E BUCK
Alan Hahn
Re: cobalt motor question
« Reply #1 on: January 24, 2010, 10:48:43 AM »
Alan,
I am not that acquainted with this motor, but from what I can find, it is a brushed motor with a kV in the 2000 rpm/volt range.
Probably means that you would be flying with 2s Lipo pack to get rpm's in the 10-12000 rpm range.
I have an Astro 05 Cobalt motor that I use to fly in an old Goldberg Electra RC powered glider. I am not sure if the two are similar, but I bet they are.
I think the motor can handle ~20A or so max, so that would give you ~160watts of input power. My SuperClown setup was running somewhat higher than that, so I am guessing that you are probably going to be marginal with that size plane.
The downside is that this motor is relatively heavy for its power handling capabilities (~5-6 oz if I got the specs right) compared to a brushless motor. Also you need a brushed controller if you don't already have one.
My guess is that it probably would be cheaper in the long run to go to a brushless setup--this depends if you already have the ESC and battery in hand. If you don't then buying a brushed setup with a 2s pack is probably a dead-end system. You won't have a governor mode capability (AFAIK) for example.
So although it might be fun to try, my advice is to go brushless.
Maybe others have more experience with this and would have a better idea of a suitable setup and airframe.
Alan
« Reply #2 on: January 24, 2010, 01:14:17 PM »
I agree with all Alan said (no surprise there!) and add this: With a high winding cobalt it seems logical to add a gearbox - however I tried that with a brushless inrunner last summer and the gearbox lasted 10 flights!  Thus I think you are better off with direct drive and probably a smallish prop - maybe a 7x4.
Its possible to plug the motor directly into the battery but DON'T DO IT with Lipo's - you will go dangerously deep into discharge ruining the batteries or worse.   Use an ESC with a Lipo cut-off voltage mode.  Then I suggest writing to Wil Hubin and asking him to build a suitable timer - I'd think a normal timer would do the deed but check with Wil to be sure.
Offline Alan Buck
« Reply #3 on: January 24, 2010, 06:05:42 PM »
Alan & Dennis, Thanks for your answers. I thought it was heavy for use on a super clown Thank you
ALAN E BUCK
