  • June 19, 2025, 09:17:02 AM
Author Topic: Starting to build a 59 Ares (Brodak kit)  (Read 26140 times)
Re: Starting to build a 59 Ares (Brodak kit)
« Reply #50 on: October 20, 2022, 08:04:04 PM »
Beautiful work on that Ares.   And Ty that where I learned it from.  Just now remembered you are older than I am. May we keep breaking age records. H^^
« Reply #51 on: October 21, 2022, 06:15:13 AM »
Old is a state of mind for grownups - when did any of us grow up?
Online John Rist
« Reply #52 on: October 21, 2022, 08:29:55 AM »
Rudder now installed. Next is install landing gear and add the last of the ribs around the landing gear.  At that point it will be ready for some silk span.  PS I am older than dirt but I am still looking down at the dirt not up at the dirt.  LL~
Online John Rist
« Reply #53 on: March 20, 2023, 05:08:34 PM »
I am ready to start finishing this aircraft. Ty  Do I need to use Non-Tautening Butyrate Dope to prep the wood work?  PS Ty is going to help me cover this aircraft.
Online John Rist
« Reply #54 on: June 14, 2023, 08:08:10 AM »
Well Ty has agreed to cover and paint my 59 Ares.  So as the monkey said when he got his tail cough in the lawn mower  "It won't be long now!"   LL~
Offline Ty Marcucci
« Reply #55 on: June 14, 2023, 02:09:05 PM »
By 0900 this morning, sanding  and two coats of clear and one small repair. Progress. H^^
Ty Marcucci
Offline Ty Marcucci
« Reply #56 on: June 17, 2023, 06:02:05 PM »
Sat progress; Both flaps and elevators covered in silk span, top nose block and cowl also covered.. 4th coat of clear on rest of fuselage and wing LE/TE/tips.  Had to quit early as standing is hard on my back since surgery late May.  More tomorrow. H^^
Ty Marcucci
Online John Rist
« Reply #57 on: June 17, 2023, 06:50:47 PM »
Wow!!!   #^    #^    #^
Offline Ty Marcucci
« Reply #58 on: June 18, 2023, 05:25:07 PM »
Sunday and more progress.  Fuselage completely covered, both wings covered, but may have to do a recover on one tip. At any rate, tomorrow tautening dope on the wings, sanding and doping the fuselage, then the hardest part, coming up with a paint scheme.  It will be as per Johns instructions, basic white.  I have some ideas, but until I lay them out on the actual model, one never seems satisfied..all part of the hobby. D>K
Ty Marcucci
« Reply #59 on: June 18, 2023, 08:03:11 PM »
Hope he is paying you well.  You have more patience than I do. D>K
Offline Ty Marcucci
« Reply #60 on: June 19, 2023, 12:25:34 AM »
No payment, John is a friend and as to patience, this is part of the hobby..Not sure why you would make that statement. ???
Ty Marcucci
« Reply #61 on: June 19, 2023, 12:01:31 PM »
Justme  S?P.    D>K
Online John Rist
« Reply #62 on: June 19, 2023, 09:12:13 PM »
I stopped by Ty house today to drop off the Brodak Ares decal.  My 59 Ares is looking good!   #^
Online John Rist
« Reply #63 on: July 03, 2023, 09:14:00 PM »
We had our July NACA club meeting at Ty's home.  My 59 Aries is looking good. Ty is a master at covering and painting!  #^
Offline Ty Marcucci
« Reply #64 on: July 04, 2023, 05:55:30 PM »
It was going great until I messed up the canopy, so I ordered two from Brodaks. With two on hand, you never mess one up, but if you only have one....... LL~ D>K H^^
The primer I am using is "Iron Armor" brand from Harbor Freight, Item 60789, Sandable Primer.
Ty Marcucci
Offline Steve St.Martin
« Reply #65 on: July 05, 2023, 12:31:07 PM »
Great job, John! Same for you Ty!  Silk span?
Fuzz
Online John Rist
« Reply #66 on: July 05, 2023, 02:05:11 PM »
Fuzz
Yes.  Ty has a stock of the good stuff.   #^
Offline Ty Marcucci
« Reply #67 on: July 05, 2023, 11:54:24 PM »
Yep, good old silk span.. Two tiny corner wrinkles that will be gone by the time I apply color dope.. D>K
Applied damp, first coat of dope is tautening, then 4 thin coats of non tautening, final coat of clear is sanded with 1000 grit. For some reason it cuts the dope better than 400, which I use  on the primer. H^^
Ty Marcucci
Offline Ty Marcucci
« Reply #68 on: July 07, 2023, 05:12:28 PM »
Great service from Brodak's. Both canopy's came in the mail this afternoon, so one will be installed tonight and tomorrow painting will commence.  H^^
Ty Marcucci
« Reply #69 on: July 08, 2023, 04:15:45 PM »
It's good to see another "old doper" at work, Ty. And, not two, do it exactly the same.  Have not used "dope" since my I.C. days pre 1998, when I converted completely to electric. Since, I just use reg hardware store lacquer(Watco) for silkspan and Poly Span. I miss the days when we could purchase a sleeve of 00, GM or SGM for 4 bux.  I should have stocked up better.
Fuzz
Offline Ty Marcucci
« Reply #70 on: July 08, 2023, 06:34:17 PM »
Well, when you have literally a gallon of this and that,you use it up.  Three of my elelctrics are covered in Krylon or Rustoleum (which I hate).
Got the first coat of white on this afternoon...sanding lightly tomorrow and then a second coat of thinned white.. Just enough to cover the gray primer.
Ty Marcucci
Online John Rist
« Reply #71 on: July 16, 2023, 12:52:49 PM »
Ty E-mailed the following:  "HI John.  I have finished the base white coats, just need some trimming.. Red and blue stripes are on the wing, doing the stab later."  SO it wont be long until a test flight.   #^   #^
Online John Rist
« Reply #72 on: July 27, 2023, 02:36:27 PM »
Well the 59 Ares is ready for first flight.  Right now it's to hot for an 83 year old.  But hopefully soon.   #^  #^
PS.  Thank you Ty for all your help in building this model.  Great job on the Silkspan covering and paint job.
« Last Edit: July 27, 2023, 07:01:32 PM by John Rist »
« Reply #73 on: July 28, 2023, 12:00:15 PM »
Looks great.  Gives me some ideas on the one I'm finishing now called Combateer. D>K
« Reply #74 on: July 30, 2023, 10:28:47 AM »
Good luck with the maiden, John. Hope it goes well!
Fuzz
Online John Rist
« Reply #75 on: August 17, 2023, 06:31:54 PM »
I flew my 59 Ares today.  It flies great.  The Bad Ass motor is strong. The airplane pulls like a bear even during a wingover.  Wings were level.  All I did was loops.  They were round and smooth.  Now for the bad news.  I am 83 years old.  I have a bad back and one bad knee. I am staggering around in the circle like I am drunk.  Because of this I did not stay in the middle of the circle.  On the landing I hit my tool/batter sack.  Did minor damage to the inboard wing.  Also because of unsteady footing I dared not go inverted. My flying days may be numbered.  I think this is all the fall out from my car accident April a year ago.  Old age sucks!!!
Anyway a 59 Ares converted to electric is a winner.   #^   #^   #^
« Reply #76 on: August 17, 2023, 06:37:32 PM »
I am in the same boat.  Been looking at the swivel chairs.  But my main problem is no vehicle to transport stuff to the field.  Working on a 1/2A set up using the Man Winds from the NW. D>K
« Reply #77 on: August 17, 2023, 06:44:22 PM »
Glad it flew well for you, John. Makes me feel more at ease.
Fuzz
Online John Rist
« Reply #78 on: August 18, 2023, 09:39:43 PM »
A little more info.  On a 4 minute flight charge put back was 1482 on a 4 cell 2800 TP battery.  Looks like it would go 5.5 minutes no problem.  At the end of the run everything was just a little warm.  I also weighed the airplane. It weighs 46 oz.  A little over weight but has gobs of power so it goes like crazy and pulls like a bear.  CG is a 1/2 inch in front of the  high point of the wing.  Very stable and smooth.  Landing was smooth with no bounce (until I hit the tool sack).  y1   y1   #^   #^
Offline Will Moore
« Reply #79 on: August 29, 2023, 09:40:38 AM »
[/b] What did you use for a control system?  did you use the horns that come in the kit, or did you use the angled control horns they talk about  in the details on the plan.
Your Ares looks really nice !  I am building one in the Fall, and it will also be electric.
And what brand paint did you use to put the silkspan on , taunting dope, or non taunting?
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
 AMA # 209
Online John Rist
« Reply #80 on: August 29, 2023, 10:13:41 AM »
Ty covered and painted this model for me.  Per Ty:
"Yep, good old silk span.. Two tiny corner wrinkles that will be gone by the time I apply color dope.. D>K
Applied damp, first coat of dope is tautening, then 4 thin coats of non tautening, final coat of clear is sanded with 1000 grit. For some reason it cuts the dope better than 400, which I use  on the primer. H^^"
For control I used the KR timer system from RSM.  However right now RSM is closed de to medical reasons.  Don't know when they will be back on line.  An alternate would be the Clime and Dive controller.  The down side to the Clime and Dive controller is that it requires good soldering skills to build and install.
Offline Will Moore
« Reply #81 on: August 29, 2023, 01:14:18 PM »
I will be using Igor’s timer.  Many people  are using the Fiorotti timer with success. What about the control horns and pushrods, what did you use there ? That is what I meant when I said control system.  Did you use the horns that were in the Brodak kit?
 AMA # 209
Online John Rist
« Reply #82 on: August 29, 2023, 06:24:43 PM »
Did you use the horns that were in the Brodak kit? - Yes.
I made my own pushrods.  Carbon rods with Tom Morris threaded ends that I salvaged from old crashed airplanes.
Offline Will Moore
« Reply #83 on: August 30, 2023, 07:44:14 AM »
  Thanks John, enjoy your Ares !
 AMA # 209
