  • July 05, 2025, 11:21:05 PM
Author Topic: C/L Timer with new firmware ready for testing.  (Read 8560 times)
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
« on: September 02, 2016, 05:27:35 PM »
People, completed the new firmware start testing next week.
The update will be free. Shipping costs only.
Rogerio Fiorotti
Offline John Tate
Re: C/L Timer with new firmware ready for testing.
« Reply #1 on: September 02, 2016, 09:38:54 PM »
Sounds good. Please keep us updated.
« Reply #2 on: September 03, 2016, 12:15:12 PM »
Didn't know you could program your timer with the Jeti box.
« Reply #3 on: September 03, 2016, 02:40:19 PM »
Yes it is possible, the new firmware novelty.
Upgrading in accelerometer data acquisition filter and increase PWM performance for 1.25 - 2,00ms
Rogerio
« Last Edit: September 03, 2016, 02:59:15 PM by Rogerio Fiorotti »
« Reply #4 on: September 04, 2016, 10:17:20 PM »
Could you still use the Castles ESC?  or this one only works with the Jeti 66 (non pro).
« Reply #5 on: September 05, 2016, 03:55:58 AM »
Joe
You can use the Castle but with restrictions Castle Creations  did not solve the problem with the PWM.
I made tests with the Spin PRO and the result was good, the governor system is much better does not vary with the battery voltage at the beginning of the flight.
Rogerio
Offline Igor Burger
« Reply #6 on: September 06, 2016, 12:27:12 PM »
Rogerio, I see sooner or later you are going to make complete copy of my timer. What about to chage at least description so it is does not look like stolen from mine?
« Reply #7 on: September 06, 2016, 12:54:21 PM »
Igor, indeed our products have several similarities, as much as any OS engine have similarities with any Enya or other brands, after all, all of them are engines, running on glow and used for the same purpose. We do have timers, tailored for control line, with accelerometer and with external device control panel.
Other than that, you cannot say it´s a copy, you always can claim that has similarities, but please be welcome to send me your address and i´ll send you my timer so you can do reverse engineering and finding that’s it´s a copy be back here and show your findings.
Other than that, save you name from this exposition online, it´s doing no good for you neither for me, and to be honest, I am sure my timer is not hurting the sales of yours, so be cool and play along, the market is there and what makes one product sells in favor of another is quality, customer support, user friendly and price. Accusing me is only doing harm to your product.
And finally, regarding description, the similarities are due to the fact that we both sells the same product with same functions and same principles. Check any ESC manual or description and compare with other brands, you will be amazed how they look similar.
Rogerio Fiorotti
« Reply #8 on: September 07, 2016, 12:06:06 PM »
Igor, you've got PM.
« Reply #9 on: September 14, 2016, 11:34:13 AM »
C / L Timer with new firmware v4.1 available in cltimer.com
News.
Using the programming box JETI Model - JetiBox
Wide RPM adjustment and more accurate with 400 steps and (1.200 at 2,000ms PWM)
Compatible with ESC's Jeti Spin Pro and Castle Creation in mode Governor Hi
Wire super flexible accelerometer.
Rogerio Fiorotti
« Reply #10 on: October 15, 2016, 09:29:17 PM »
Has anyone got there thing upgraded and want to give a review? Somebody told me the Castle ESC is too slow for a change speed system and you have to use a certain old Jetti I can't find anywhere.
Offline Guilherme Souza
Re:
« Reply #11 on: October 24, 2016, 09:43:03 PM »
I did the upgrade and bought the Jeti Box.
The new system is amazing, wonderful . You can listen the motor up and down.
I use the Castle Edge 50 and is working great.
My setup is :
Motor Hyperion
Battery Zippy Compact  5 S 2700 25 C
Plane is FRANK (Trivial fuselage and Impact wing)
Thank you
GUIL
Enviado de meu ASUS_Z00AD usando Tapatalk
« Reply #12 on: December 01, 2016, 12:46:41 PM »
My setup is :
Motor Hyperion
Thank you
GUIL
Hi Guil,
Just a little curious which Version do you have?
« Reply #13 on: December 07, 2016, 05:33:37 PM »
Hi Guil,
Hi Joe
I have the last version with Jeti Box . And is working very well .
Thank you
« Reply #14 on: December 07, 2016, 05:56:22 PM »
Can you still program it without the Jeti box?
« Reply #15 on: December 08, 2016, 08:15:10 AM »
No, in this version only with Jetibox.
Rogerio
« Reply #16 on: December 08, 2016, 06:45:47 PM »
Hi Joe
Thank you
Would that be the Version 4.4?
« Last Edit: January 10, 2017, 06:59:36 PM by Joe Yau »
« Reply #17 on: January 10, 2017, 03:19:22 PM »
Rogerio
Thank you a lot for this wonderfull timer .
I´m using it in my Legacy and my new Chupin 60 .
it´s amazing listen the motor increasing the rpm .
All the setup options are very good  .
Thank you a lot
Guil
« Last Edit: January 10, 2017, 04:10:52 PM by Guilherme Souza »
« Reply #18 on: January 12, 2017, 03:55:33 PM »
blank
« Last Edit: March 06, 2022, 04:29:43 PM by Motorman »
