  • August 05, 2025, 12:56:59 AM
Author Topic: Changing Bearings  (Read 1296 times)
Changing Bearings
« on: March 13, 2014, 09:28:36 PM »
Can you rebuild E motors? If it's brushless the bearings are the only thing right? Do you change bearings or just buy a new motor? How do you judge when it's shot, do you just run it until ca chunk? If the bearings grenade does it ruin the motor?
Offline Robert Redmon
Re: Changing Bearings
« Reply #1 on: March 14, 2014, 07:18:33 AM »
I have changed the bearings in almost all of my motors at least once. They usually go well over 200 flights, regardless of the way the motor is mounted. Heavy props and spinners tend to wear bearings out faster.
You will notice excessive play at the prop (either/both fore and aft and side to side play) or noise...typically a kind of rattling sound and vibration. Bearings are easy to change (note: e-flite glues in the bearings with what appears to be cyanoacrylate...a gentle tap is enough to free them). I use a punch made of 1/8" music wire to catch the lip of the bearing, moving it around the circumference of the bearing until it pops out.
Bearings are available from a number of sources. BOCA bearings in Florida is fast and reliable. RCBearings.com have a good inventory as well, but I have not been impressed with the quality of their bearings. Innov8tiveDesigns.com (suppliers of scorpion and cobra motors) stock bearings for all the motors they sell at very reasonable prices.
Hope this helps.
Bob
Robert Redmon
AMA 58073
Offline jfv
« Reply #2 on: March 14, 2014, 09:41:44 AM »
Here's a video on YouTube that shows how to change bearings on a Scorpion motor.  Pretty much the same for most motors.
Jim Vigani
Online Tim Wescott
« Reply #3 on: March 14, 2014, 12:07:19 PM »
Just be aware of the big three and a half ways of retaining shafts in motors.  Get it wrong and you'll damage something trying to take it apart.  I think I've seen all three (I'm not about the 1/2) on our motors, but I have NO CLUE about which ones are most used: I just know what I've found with 30 years of working with similar things in industry.
  • Press fit.  Done if the motor is really fancy or really cheap, this depends on the friction between the shaft and the housing to keep the shaft in place.  The Scorpion motor in the video appears to be a press fit backed up by the collet with set screws.
  • Shrink fit (this is the 1/2).  Done if the motor is really fancy.  You chill the shaft, heat the housing, then assemble.  When things reach equal temperatures the fit is TIGHT.  You may or may not damage a shrunk-fit motor trying to press the shaft out.  With an aluminum housing and a steel shaft you can usually loosen things up by heating everything, but you have to be aware of what the windings can stand -- and winding insulation temperature ratings vary!
  • Set screws.  They'll either be in a collet or in the motor housing.  These often fit into flats that are milled in the shaft.  Try hard enough to press a shaft out without removing the screws and you'll damage shaft, housing, or both.
  • Circlips (AKA "E-clips" by marketing people, or "Jesus clips" by anyone who's ever pried one off, heard it go "spiiiiing!" into some dark corner of the shop, and said "Jesus!  Where'd it go?").  Leave the circlip on, press hard on the shaft, and the only way something will move is if metal bends or breaks
Offline ericrule
« Reply #4 on: March 15, 2014, 11:29:31 AM »
Not only the bearing go bad you can lose one or more of the magnets. This usually happens if the motor gets too hot. This can cause the glue to break down (happened to Keith Renecle at the World Champs). If that happens you just epoxy the magnets back in place.
Bearings are the things most likely to go as C/L flying exerts massive side thrust on the motor shaft. Bearings are also one of the few areas that the manufacturers can save money on. Cheaper bearings cost less than higher quality bearings. Probably why Boca Bearings offer two kinds of replacement bearings for the E Flite motors one cast $14.95 while the good one costs $39.00. Guess which one will go bad first?
