  • June 29, 2025, 01:53:01 AM
Author Topic: Cut down a prop  (Read 1124 times)
Online John Rist
Cut down a prop
« on: August 04, 2018, 08:57:21 AM »
It seem that it is common to cut down an APC electric prop to match a motor battery combination.  For may E-Cavalier I cut down a APC 12x6 EP marked F2B to an 11-1/2 x 6.  In order to get repeatable results I built a fixture to mark the cut off point on the tips.  It amounts to a block of wood a drill bit and a cardboard template.  Photos should explain.
Re: Cut down a prop
« Reply #1 on: August 04, 2018, 04:56:52 PM »
I guess I'm just old school.  Once I get my prop cut down to the desired diameter, I just put on bigger wheels...
Mark
