  • July 18, 2025, 12:35:13 AM
Author Topic: Centrifugal cooling fan for Cobra motors  (Read 1227 times)
Offline Matt Piatkowski
« on: September 24, 2019, 07:21:32 AM »
Hello,
Does anybody know where to find at least one?
The motor is mounted behind the firewall.
Thank you,
M
Online John Rist
Re: Centrifugal cooling fan for Cobra motors
« Reply #1 on: September 24, 2019, 12:50:50 PM »
What Cobra Motor?  I have one you can have if it fits.  It is the old style 3 bolt version.  PN C-MCA-28.  It fits the 28xx motors.  PM me if you can use it.
« Reply #2 on: September 24, 2019, 02:08:05 PM »
Hi John,
I need it for one of my Cobras 3520/12.  These motors have four M3 threaded holes to mount https://innov8tivedesigns.com/parts/motor-parts/cobra-c-35mm-bolt-on-prop-adapter-4-hole and these holes can be used to mount the fan. 3 bolt version of the fan for 28xx Cobras will unfortunately not fit.
I know that fans for 35xx series existed but are hard to find.
M
« Reply #3 on: September 24, 2019, 03:05:00 PM »
Hi John,
M
I have been looking for a fan for my 3520 about 6 months.  If you find a source please post it here.  I can't find so much as a picture of one.
Offline William DeMauro
« Reply #4 on: September 25, 2019, 09:24:29 AM »
I believe I bought the last one like 4-5 years ago, As I called him directly and he had to dig that one up for me and said they were discontinued already for a while at that time. These only fit the older 3 screw versions of that motor and not the newer 4 screw versions. In any case this is what they look like. Excuse the scratches. This is for the 35 series. The 28 series is pretty much the same only smaller. Just a side note that I found it pretty ineffective on the 28 series as the motor seemed to run hot regardless in full fuse planes and on the 35 series I ran it with and without the fan and it ran cool, did not see much difference there either. Maybe it was more effective for helicopter guys? Just a guess.
AMA 98010
« Reply #5 on: September 25, 2019, 10:27:30 AM »
Thanks for the picture, at least I know what they look like.  The fact that they are no longer manufactured leads me to believe that they were not particularly effective.  Personally I have never had a heat problem with any of the three Cobra's I am running and that is in Texas where the air temperature over our asphalt circles is well over 100 in the summer.  They seem to vent themselves and as long as you have airflow to draw off the expelled heat they do fine.  It also appears that the fan would force a front mount and I would rather periodically replace bearings than deal with collets.
