  • June 17, 2025, 05:11:26 AM
Author Topic: Keep your lines tight with this!  (Read 779 times)
Offline Rudy Taube
  • Ret Flyboy
« on: November 06, 2009, 08:56:57 PM »
OK Guys,
Look here, cool:    http://www.plettenberg-motoren.com/UK/Neuheiten2006.htm
Moving motor/prop  :!
Hook this up to something that tells the servo that your lines are not tight, and you can have REAL tight lines in a millisecond!  8)
Rudy
AMA 1667
Alan Hahn
Re: Keep your lines tight with this!
« Reply #1 on: November 07, 2009, 08:28:37 AM »
Sort of a front-end Rabe rudder.
Of course you could use elevator control to apply up/down thrust to provide some sharp corners too!
Offline Dean Pappas
« Reply #2 on: November 07, 2009, 10:03:41 AM »
At the last Pattern Worlds, German team member Bernd Bershorner used this on his EVO-30 powered 2-meter plane to improve rolling loop performance wiothout resorting to a whale-like fuselage for side area.
Folks there said it works!
Dean P.
Dean Pappas
