  • July 18, 2025, 08:28:38 AM
Author Topic: CC Phoenix ESCs  (Read 3333 times)
Offline andreas johansson
  • SWE-56998
CC Phoenix ESCs
« on: May 07, 2009, 07:42:59 AM »
Hi all!
I have recently started to look at E-CL and I have ordered a TF Nobler ARF for this project. As I really like CC products I would like to use a Phoenix ESC, but, as I intend to use a 4s pack and the ESC says max 3s with BEC. How to solve this? external BEC? The timer is a ZTron.
regards
Andreas
Nobler-O-Maniac
SWE 56998
Alan Hahn
Re: CC Phoenix ESCs
« Reply #1 on: May 07, 2009, 07:47:07 AM »
I have no problem with my CC Phoenix ESC running with a 4s battery and the timer (both Ztron and JMP-2). The timers draw so little current, that the power load on the internal BEC isn't an issue at all.
Re: CC Phoenix ESCs
« Reply #2 on: May 07, 2009, 07:55:36 AM »
The reference I beileve is more in that if you are running servoes and a reciever, it will overdraw the BEC circuit when the servos and reciever are drawing current at the higher voltage. My CC 45 works fine to drive the timer.
Online Crist Rigotti
Re: CC Phoenix ESCs
« Reply #3 on: May 07, 2009, 08:10:12 AM »
If you contact Castle they will tell you you can run a 4S battery.  You'll have no problem with running a CC-35 on a 4S battery.  I do it all the time.
  • SWE-56998
Re: CC Phoenix ESCs
« Reply #4 on: May 07, 2009, 09:31:00 AM »
Thanks for your answers, I´ll order a Phoenix 45.
Andreas
Nobler-O-Maniac
SWE 56998
Re: CC Phoenix ESCs
« Reply #5 on: May 07, 2009, 09:40:27 AM »
Andreas:
Will this be your first ECL project?  If so Welcome!
Please keep us posted on your progress.  The ARF Noblers seem to build light, making them excellent starting points for ECL, I LIKE your chances for sucess.
  • SWE-56998
Re: CC Phoenix ESCs
« Reply #6 on: May 07, 2009, 10:20:44 AM »
Thanks Dennis
Yes it is my first attempt at ECL. The Nobler ARF is a light airframe so I hope its a good starting point. As I´m "Nobler crazy" I will happily add another Nobler to my CL fleet.
The setup I have bought is:
Top Flite Nobler ARF + new hardware (bellcrank and so on....)
Turnigy  TR 35-48-B 900kv, a bit low kv rating, but I will try it to begin with.
CC Phoenix 45
no battery yet, but it will be a 4s 3000-4000mah.
Ztron simple CL timer
Nobler-O-Maniac
SWE 56998
Re: CC Phoenix ESCs
« Reply #7 on: May 07, 2009, 11:05:47 AM »
Andreas,
For a battery please consider the ones i'm flying with.  They are made by PolyNoOne and have given me excellent service.  It is a 4S2P 3400mah pack that weighs 313 grams (11 oz) with connectors.  Here is a link:
http://polynoone.com/main.php
Contact Mr. Ivy Wong by email.  Mention that I sent you.
Here is their part number - PN553496P20R4S2P
Here are some pictures of the batteries I'm using.
« Last Edit: May 07, 2009, 05:46:33 PM by Crist Rigotti »
  • SWE-56998
Re: CC Phoenix ESCs
« Reply #8 on: May 07, 2009, 11:30:08 AM »
Wow, what a lightwight battery, they are on the top of my battery list.
What are the size of the battery? Inches or metric doesnt matter.
You guys are the best!
Just for the record, I'm not converting from glow to electric, both have their advantages and disadvantages. However, with a silent ECL aircraft I can fly on a nearby unused soccer field.
Andreas
Nobler-O-Maniac
SWE 56998
Offline Mike Anderson
Re: CC Phoenix ESCs
« Reply #9 on: May 07, 2009, 11:46:00 AM »
Andreas -
I would recommend that you get the Turnigy SK3548-900 (as opposed to the TR3548-900).  It has a larger diameter shaft and improved magnets and bearings.
As for the Kv - well, on 4 cells this package will 'haul the mail' - The original e-Nobler that I recall (by the German flyer, whose name I can't recall  :) ) was flying on a much smaller motor and 3 cells and was reported to be at least adequate.  We (in my club) are currently flying a half dozen different planes on the Turnigy SK 3548's and the 1100 version on 3 cells will easily do the job on a Nobler.  The -900 version on four cells will be even stronger.  You are going to like it ...  a lot.
Keep us posted --
« Last Edit: May 07, 2009, 01:00:19 PM by Mike Anderson »
Mike@   AMA 10086
Central Iowa
Alan Hahn
Re: CC Phoenix ESCs
« Reply #10 on: May 07, 2009, 03:07:40 PM »
With the Arf Nobler, a 4s2500mAHr is plenty and will give you a good excess capacity. I use a 4s2100mAHr on mine.
One thing to keep in mind is the physical size of the pack. My 4s2100 pack (26mm x 33mm x 100mm and 208g or 7.3 oz) is just about the maximum (lengthwise) to stay within the Noblertank compartment. Originally I set it up for two 3s2100 packs hooked up in parallel (same cells as in my 4s2100 pack) because I wasn't sure how much power I needed. In that case I made it possible for one pack to slide back over the top of the wing while the second pack stayed in the tank compartment. I think I could have made the opening large enough for the width of my 4s pack.  You may need that option if your battery is much longer than my 100mm.
Offline John Cralley
Re: CC Phoenix ESCs
« Reply #11 on: May 07, 2009, 03:44:37 PM »
Andreas,
You might want to check the prices at http://www.rcplanet.com/
I picked up a CC 45 Phoenix ESC from them a little while back for $96.95
You could also do better on Ebay but you take your chances there.
John Cralley
AMA 52183
Central Illinois
Offline William DeMauro
Re: CC Phoenix ESCs
« Reply #12 on: May 07, 2009, 05:16:52 PM »
Todd's Models has the Phoenix 45 for $79.99. This is the best price I've found from a regular dealer. http://www.toddsmodels.com/Castle_Creations_ESC_s/39.htm
AMA 98010
  • SWE-56998
Re: CC Phoenix ESCs
« Reply #13 on: May 08, 2009, 12:33:55 AM »
Thanks for your answers!  :)
Alan: Ok, I´ll keep that in mind. A smaller pack = a lighter pack. If ~2500mAh is enough I will happily use it.
John and William: The only problem is that I have to add 30% in vat and customs to those prices (if I´m unlucky). About 60-70% of my US ordered packages slip thru the customs without additional fees :) I have found a source in UK with (for Europe) fair prices on CC products.
All: With your help this will be great fun :D
Andreas
Nobler-O-Maniac
SWE 56998
  • SWE-56998
Re: CC Phoenix ESCs
« Reply #14 on: May 08, 2009, 10:11:00 AM »
Hey hey, I found some E-Nobler movies on youtube. The e-noblers in the movies worked very well, this seems like a promising project. I might build the E-Nobler as a take-apart model, not sure yet but maybe.
I will try to get a really neat electric installation, I dont like the thought of having electric wires dangeling (word? spelling?) from the model.
There will also be a build tread here on SH, focused at the conversation.
Andreas
Nobler-O-Maniac
SWE 56998
Alan Hahn
Re: CC Phoenix ESCs
« Reply #15 on: May 08, 2009, 02:06:50 PM »
Andreas
Well this one was mine from Spring 2008.
[youtube=425,350]vQSNwHWbtZU[/youtube]
  • SWE-56998
Re: CC Phoenix ESCs
« Reply #16 on: May 09, 2009, 12:35:42 AM »
Alan: I´m very impressed with the performance of your E-Nobler. Do you have any pictures of your motor installation?
What size of prop do you recommend?
Andreas
Nobler-O-Maniac
SWE 56998
Alan Hahn
Re: CC Phoenix ESCs
« Reply #17 on: May 11, 2009, 08:29:37 AM »
Andreas
Andreas,
Here is a link to my original post---back in the old days! It has some photos of my installation, and some photos of another way-cool Nobler setup.
http://stunthanger.com/smf/index.php?topic=6975.0
My current setup uses a Scorpion 3020-16 motor, a FMA 4s2100AH LIPO, CC Phoenix 35A ESC (running in governor mode), and a JMP-2 timer. The prop is a 12-5 APC thin Electric and I use ~60 foot lines (eyelet to eyelet). I pull a little less than 1600 mAHrs per flight.
I am happy with the setup. Since I don't know how yours will end up, you might want to go with 2500mAHr cells to give you some extra capacity.
