Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 15, 2025, 01:06:50 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
12" Wingspan Nobler
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 12" Wingspan Nobler (Read 1532 times)
Jeffrey Olijar
Trade Count:
0
Lieutenant
12" Wingspan Nobler
on:
August 04, 2010, 08:00:33 PM »
I built a mini Nobler (its a 1/2 Scale Half A Nobler by Dick Sarpolus)
It weighs in at 30 grams and flies on 15' lines.
[youtube=425,350]
[/youtube]
I built another one that is much lighter and will post a video as soon as I get a chance to fly it.
Last Edit: August 06, 2010, 03:20:44 PM by Jeffrey Olijar
Logged
If it ain't broke, fix it till it is.
Larry Renger
21 supporter
Trade Count:
0
Admiral
Re: 12" Wingspan Nobler
Reply #1 on:
August 05, 2010, 09:01:38 AM »
Dang, it is so small I can't see it in the picture at all!
Logged
BTW, Dracula Sucks! A closed mouth gathers no feet!
Wynn Robins
Trade Count:
0
Admiral
Reply #2 on:
August 05, 2010, 06:14:00 PM »
that is HARD CASE.....but neat.... I like it!
Logged
bob branch
AMA Member
Trade Count:
0
Admiral
Reply #3 on:
August 05, 2010, 07:14:37 PM »
good workable lap times!
bob branch
Logged
Larry Renger
21 supporter
Trade Count:
0
Admiral
Reply #4 on:
August 05, 2010, 11:59:32 PM »
What is your power system? Or is it posted on the My setup section?
Logged
Jeffrey Olijar
Trade Count:
0
Lieutenant
Reply #5 on:
August 06, 2010, 03:20:21 PM »
Motor
HobbyKing AP-03 7500kv Brushless Micro Motor (3.1g)
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9663
Prop
3x2 Gws (balanced)
Esc
HobbyKing XP 3A 1S 0.7g Brushless Speed Controller
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9667
Battery
Turnigy 160mAh 1S 30C (E-flite, Minium compatible)
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=10980
I am using a ztron v3 timer set to 1min 10 seconds
I can get 3 flights on each battery and it brings it to roughly 20-30% charge
Logged
Jeffrey Olijar
Trade Count:
0
Lieutenant
Reply #6 on:
August 06, 2010, 08:11:15 PM »
Flew Mini Nobler #2 (#1 was too heavy)
It flies okay but I need more weight on the nose and wingtip.
Logged
Jim Moffatt
Trade Count:
0
Lieutenant
Reply #7 on:
August 07, 2010, 05:19:56 AM »
Great video! I enjoyed both flight videos. I fly on a 20' tethered line and control both motor and elevator by RC. I timed your laps at about 3 sec from the video and it would be way too fast for me.
Logged
Jeffrey Olijar
Trade Count:
0
Lieutenant
Reply #8 on:
August 07, 2010, 11:18:40 AM »
Any longer and you loose line tension. I'm still working on it though.
Logged
jim gilmore
Trade Count:
0
Admiral
Reply #9 on:
August 07, 2010, 04:43:51 PM »
You might do better with less engine offset.
Logged
Jeffrey Olijar
Trade Count:
0
Lieutenant
Reply #10 on:
August 07, 2010, 07:14:19 PM »
Just flew it again. It flies much better with the nose and tip weight. I can do loops and wing overs just fine. It has some difficulty with figure eights and inverted flight. I am going to add flaps and see where that takes me. My micro shoestrings had almost no engine offset and line tension was a major issue. I may experiment later but I think the offset is okay where it is for now.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
12" Wingspan Nobler
