Welcome Lester,
Just go to the top of this section and look at the "List your System" thread that Crist was kind enough to put together for us. There are many examples for your size engine replacement.
You can also go to Eric Rules extensive CL web site (RSM Distribution) and buy his excellent "turn key" Electric system. It was designed to replace a .46 Eng. It has everything you need and is pre programed so it is "plug and play" ready. :-)
If you build very light, and have a classic style thin airfoil and a streamlined plane, then the Electric systems from Brodak will work fine. If you subscribe to "CL World" mag. then you can see the very good article by Dennis on these systems. If you get this informative CL mag. then you may want to read the excellent electric CL articles by Mike Palko in past issues.
The system that has been very successfully used by many E CLPA pilots, thousands of CLPA flights, is:
AXI 2826-10 motor, Castle Creations 40 or 45 ESC, Thunder Power (or Hyperion) 3800 mAh battery and the excellent Hubin FM-9 timer with programmer. APC 12 x 6 Electric Pusher Prop.
If you are a PAMPA member you may want to look at the E-Stunt column written 1st by Will Moore and now by someone else (I forget his name). There is info there that may help you get started.
RE: the Chargers, equip. installation etc., You may want to read many of the excellent posts in this section then come back with any questions you still have.
Your question has been answered many times on this forum. It should be easy to find many good explanations using Roberts effective "Search" function at the top upper right part of this page.
