  • July 28, 2025, 08:12:33 PM
Author Topic: CC ESC parameters from Linheart  (Read 2744 times)
Offline linheart smith
« on: May 19, 2007, 12:38:55 PM »
These are my settings for the Electric Bearcat where with I get a Heli Gov run with two Blip warning before cut off:
  1. Cutoff         Lipo
  2. Cutoff Type         Soft
  3. Brake Strength          50%
  4. Throttle Type         Heli: Fixed Points
  5. Brake Delay         1 sec
  6. Direction         Forward
  7. Brake Ramp         1 Min
  8. Motor Start Power      med. (59)
  9. PWM Rate         13khz
10. Throttle Response      High (8)
11. Current Limiting      Normal       (I have since changed this to "Sensitive" after losing a motor during a prop strike on take off.)
12. Motor Timing         Std. Adv.
13. Gov. Gain         Custom (93)
14. Spool-Up Speed      Med. (5)    Changed to "High"
The Electric Bearcat is the Classic legal version and was built from plans.
Wing Area  615  (including flaps)
Weight  60oz   ready to fly
The Power set is:
Mortor   Axi   2826/10
ESC       Castle Creation  Phonix 45  Software Ver 2.23
Timer     JMP3
Battery  Poly Quest  PQ-4000-4S
Prop      APC  12-6 Electric
« Last Edit: June 20, 2007, 05:28:41 AM by linheart smith »
linheart
Re: CC ESC parameters from Linheart
« Reply #1 on: May 24, 2007, 10:08:54 AM »
  1. Cutoff         Lipo
  2. Cutoff Type         Soft
  7. Brake Ramp         1 Min
  9. PWM Rate         13khz
Hi Linheart
Thanks for posting this info, why don't you also add  to this the motor, battery type and size, the controller brand, esc  brand, pitch and diameter of the prop, RPM, the weight and size of your airplane, This is information people like to see. And it is a big help to many people, I get lots of calls on this, and  I think this forum is a great place  for information.
Offline fernando torres
« Reply #2 on: May 30, 2007, 07:27:20 PM »
linheart:
Is this the Al Rabe Bearcat? I Have the plans for his gas model.
FET
Online Mike Palko
« Reply #3 on: May 30, 2007, 10:05:17 PM »
Hi Linheart,
   Can you add the software version you are using in CC ESC also.
Thanks, Mike
« Reply #4 on: May 31, 2007, 03:53:10 AM »
Mike,
The CC software version is 2.23.
Fernando,
This is the original Al Rabes Bearcat design to fly with something like a ST46.  In its day, it was considered a big airplane. It is Classic Legal.  The newer BBQ Bearcat is about 20 percent larger and is designed for 60-90 engines.
Linheart
linheart
« Reply #5 on: June 01, 2007, 03:49:45 PM »
LInheart:
 I have the same plans for the St46 Bearcat. I am going to try building one using your specs. Do you have any advise for a beginner like me?
Fernando
FET
« Reply #6 on: June 02, 2007, 02:47:13 PM »
Hi Fernando,
I am an Advanced Flier and builder. The Bearcat was somewhat challenging for me.  I built three wings before I got it the way I wanted it. The first one was like the plans.  Then I switched to the Tom Morris system.
To save weight, I formed the top and bottom fuselage pieces from 1/16 balsa.  The tail feathers were built just as shown on the plans.  For Electric, do not install motor mounts (I did at first but then cut most of it away).  Plan on mounting the motor on Former number 2.
Good luck with your project.
Linheart
linheart
