CLICK HERE--><--CLICK HERE
We Must go Faster (AMA Event 334)
Started by Motorman, August 25, 2025, 03:56:02 PM
Previous topic - Next topic
0 Members and 3 Guests are viewing this topic.
Motorman
#25
Looks like the battery I want is out of stock. I wonder if someone else makes the same type.
Must be a couple hunderd motors on that page. Which one would work with that battery?
Tim Wescott
Quote from: spare_parts on August 29, 2025, 07:47:37 AM
Notice the rules say "8.4V nominal".
I read those rules, and missed that "nominal".  Thanks for pointing that out.  I'm gonna edit my post!
Tim Wescott
Quote from: Motorman on August 29, 2025, 05:03:24 PM
Whatever you do the first time around will be wrong, and you'll have to change stuff (i.e., buy more stuff).  Don't waste time trying to be perfect the first time out -- find something similar and buy it.  There's plenty of other HV, high C batteries out there.
In fact, an approach I might take would be to go out and buy the cheapest crap out there that may still work, put it together, and see what burns up.  That'll keep the price of your screwups down while you learn how to do it without screwing up.
Must be a couple hundred motors on that page. Which one would work with that battery?
  • Decide on your RPM
  • Calculate the kV rating range that gets you about 20-30% more RPM with the battery fully depleted (3.3V for a regular cell, 6.6V for two, I don't know how much for a "HV" cell -- it should say)
  • E.g., if you want 25000 RPM, then you need a kV in excess of 25000 / 6.6 = 3788 RPM/V -- probably something like 4500-5000
  • Assume a motor output power (i.e., 1500 watts is about 2HP)
  • If you're being good, assume an efficiency below 1 -- I'd guess at 60%, but I don't have much of a clue here.  If you assume 60%, then your 1500W output power turns into 2500W input power
  • Calculate the motor current.  I.e., at 100% efficiency, 1500W / 6.6V = 227A, at 60% efficiency 2500W / 6.6V = 380A
  • Find a motor that's in or a bit above your kV, and around your desired current rating.
  • Find an ESC that exceeds your expected current
  • Go buy stuff
  • Put it together, turn it on, see what smokes, and buy a bigger one of those the next time
That's it!
Motorman
Yes, first plane will be made from barbeque grill material.
When going for a world record bring $.  I set a world boat speed record back in the NiCad days.  Mothers were one or two runs at most.  It was a stock motor class so motors were cheep.  However battery cost got pretty $$$$.  Anyway it was a blast to figure out how to go fast.   Good luck and keep us posted.
spare_parts
The record was set over 10 years ago. Do we know anything about that setup? Batteries have certainly improved since. Motors haven't really changed.
After a lot of digging, I found a photo of Howard Doering's 334 record model. As expected, it has a Neu motor on it.
https://www.facebook.com/photo/?fbid=820452357966308&set=pcb.691126157590573
Greg
Motorman
That's interesting, looks like a chopped up FAI speed plane. I like how the ON switch goes back for on so the ram air doesn't shut it off. Can't quite make out the lable on the motor.
Dave Rigotti
I disagree on the switch.  Aft is off. I see a trip wire around the toggle for in flight shut off with down elevator methinks.
Quote from: Motorman on September 01, 2025, 06:23:40 AM
Dave Rigotti
AMA 66859
Chesterland, Ohio
Motorman
I'm thinking this motor has to be an inrunner because of the rpm involved. Looking at Neu motors 1506/2.25D/4400kv 73 max amps. Don't know what the 2.25D means but also considering 1506/1.25Y/4400kv and don't know what the 1.25Y means either lol. Anyone want to hazzard a guess? Got an email off to the factory.
Castle Creations makes an Edge Lite 75 amp ESC that will work with 2S voltage.
Hubin FM9 timer
6700mah 90C 2S lippo
How am I doing so far?
MM :)
Tim Wescott
Should be a good start.  I'd strongly recommend setting it to constant-RPM mode, and experimenting with what gives you the best speed.
spare_parts
In the end, the winding (1Y, 2.5D, etc) doesn't matter much. It's the motor constant and Kv that determine performance. In/outrunner doesn't really matter, if it performs. 1506 might do it, might have to go bigger. Steve will set you up with a suitable motor for the application. Just be prepared to wait if it's not a stock wind. It was several months sometimes, years ago when I last dealt with a custom order.
~200A battery and 75A ESC?
Greg
spare_parts
Quote from: Tim Wescott on September 05, 2025, 09:02:22 PM
Why would you want anything less than full power? I'm not sure I understand.
Greg
Tim Wescott
Quote from: spare_parts on September 06, 2025, 07:44:28 AM
Why would you want full power when your helper is holding onto the plane, only to experience battery sag when you're being timed?
Why would you want to weigh the plane down with bigger batteries so that it sags less when you're being timed, because you wasted so much energy waiting for launch?
Why would you want to prop the plane so that the motor burns out when it's being held for launch, just so that you'll get "full power" after the battery has sagged?
If using constant RPM is a help, you'd want to set it up so that you're out of headroom somewhere around the end of the timing interval -- maybe right at the end, maybe a few laps before.  That way the plane is going as fast as it can, with the battery in it, for the whole flight, not just the beginning.
Motorman
Quote from: spare_parts on September 06, 2025, 06:31:34 AM
Is the battery too big? I was thinking the power going through everything could be controlled with the rpm setting? They also make a 4900mah that's 60g lighter.
With the Hubin timer I only get one rpm setting but I can choose a slow ramp up so hopefully I can get enough speed up to avoid torque roll. Helper will release as soon as the prop starts to turn. Have to get it in the pylon first 1-2 laps, that'll give 5 laps from take off before the timed run.
Would be nice to do take off then 1-2 laps at half speed before full blast.
MM :)
Tim Wescott
Put the battery at the CG and be ready to experiment.
Motorman
Ghost RC got back to me and said their 4300/1412 motor would be good.
