  • June 15, 2025, 04:00:44 PM
Author Topic: New Model William Demauro's composite SV22  (Read 1604 times)
Offline jose modesto
« on: June 08, 2011, 08:43:12 AM »
Posting photos of William's new Balsa composite shell construction  SV22
The model ready to fly under 68oz. William's SV22 was test flown yesterday and it looks like a winner.
William will do the tech part
photos of model
Jose Modesto
Re: New Model William Demauro's composite SV22
« Reply #1 on: June 08, 2011, 12:47:28 PM »
Added photos
William Demauro's E SV22
Online Dennis Adamisin
« Reply #2 on: June 08, 2011, 04:14:21 PM »
Looks like "Smilin' Will" has a lot to smile about - way to go.
Oh yeah, also a way to go to the "build coach" Jose!
Offline Mike Palko
« Reply #3 on: June 08, 2011, 04:29:12 PM »
Looking good Will. Is it to late for it to make Brodak's?
Will or Jose, what do the composite airframes finish out at w/o the power system? Do they vary much (besides paint/finish weight)?
Offline William DeMauro
« Reply #4 on: June 08, 2011, 05:32:00 PM »
Hi all,
First I have to thank Jose. He is a great building coach and very generous with his time and shop and tools. I learned alot about an alternate way of constructing a stunt ship. The construction  was definitely a new experience for me. The fuse is literally a like a  hollow tube. When you look in the front you can see out the back and it has no flex at all!!!!!
 I also owe Sina a big thank you too. He came up with the as yet unfinished paint scheme.He was also a great help in the shop and encouraged me to go on when i got frustrated with it at times!!!!!
I believe it weighs about 40oz without electrics and paint.(22 for the powersystem and 6 for the paint). This was the very first plane out of the molds so i know we can cut at least a few ounces off the next one. I feel under 64 is doable. If I would have opened the bays on the wing and used better wood I'm sure i could have lost 4 oz right there.
Power system is my usual proven setup. Scorpion 3026-890 Phx 45, FM-9vr timer.Hyperion 4s 4000 batteries. 13x4.5 pusher prop.Tru turn e spinner. It has Tom Morris controls system and a Winship main gear(thanks Bob).
Flew 3 short flights(1.5 min) adjusted the trim tabs just a bit, added some tip weight and turned it loose.
First full flight was the full pattern It flew on rails and tuned on a dime. I'm impressed for sure!!!!! I feel that I have a winner here that wont need much to have it flying at 100%.  This plane will not make it to brodaks. I need to get my letters and numbers on it and fix some flaws in the paint. After that it should make every contest that I attend for the rest of this year.
AMA 98010
Offline Matt Colan
« Reply #5 on: June 09, 2011, 07:08:04 AM »
It looks GREAT will!!!!  Are you planning to go to the NATS again?
« Reply #6 on: June 09, 2011, 09:07:50 PM »
Mike we kept weights of model at every stage, during construction. SV22 composite components, complete ready for assembly with landing gear and wheel pants 33oz. NOTE: model was built with Non contest balsa
Current SV22 with open bay wing,stab and contest balsa 28oz., Ready for paint. The new raw balsa models are Little lighter.
Photo #1 plug in wing take apart SV22. Components shown weigh 33oz. including Yatsenko type hardware.
Model is now in one piece, Wynn.
Photo #2 a look inside a LFCSW (lost,foam,composite,shell,wing)
JoseModesto
« Reply #7 on: June 12, 2011, 07:30:01 AM »
Looks great.  How long does it take to get to this point in construction?  H^^
« Reply #8 on: June 12, 2011, 06:37:18 PM »
mine was supposed to be finished, test flown and shipped to me in March - but still waiting - so it takes a LOOONG time....
just razzing you Jose.......
« Reply #9 on: June 13, 2011, 07:07:29 AM »
A couple of in flight and with pants on.
Photo #1 in flight see hot air exhaust
Photo #2 in flight
Photo #3 with alum gear and pants.
Photos taken yesterdays flying session.
Jose Modesto
