  • July 09, 2025, 09:33:02 AM
Author Topic: Castle link software problem  (Read 1807 times)
Offline Alan Resinger
« on: June 28, 2011, 09:18:37 AM »
I've got a new laptop running Windows 7 (64 bit).  I've tried over and over to load the Castle link software.  I've tried everything and it refuses to load on this computer.  Castle's tech gave me a number of things to try and still no luck.  Anybody else have this problem and did you get any kind of fix?  Maybe I should look for a used laptop running XP.
Alan Resinger
Offline John Cralley
Re: Castle link software problem
« Reply #1 on: June 28, 2011, 09:28:04 AM »
I'm sure Castle Creations Tech folks know what there is to know but I believe you do have to load the software while in Administrator mode for Win 7.
John Cralley
AMA 52183
Central Illinois
Offline William DeMauro
« Reply #2 on: June 28, 2011, 10:08:54 AM »
Did you try running the software first in administrative mode? then connecting the link after? You can also try compatibility mode for one of the versions of Win XP. I've had no issues installing  this on multiple Win 7 computers. Of course that doesn't mean that there cant be an exception.
AMA 98010
« Reply #3 on: June 28, 2011, 10:16:29 AM »
Same as above, right click then "Run as Administrator"
« Reply #4 on: June 28, 2011, 12:11:19 PM »
Thanks guys.  I tried again after posting and got the same error message and was going to give up.  I went to the download file on the computer and this time there was the download.  It had acted just like it did during the previous tries but this time even with the error messages it came through.  I right clicked, got run and Admin., and it installed.  Can't figure what the problem was.  Castle even had me checking to see if a certain TT font was installed on the new computer.  I'm happy now.
Alan Resinger
Offline Peter Nevai
    • C3EL
« Reply #5 on: June 28, 2011, 08:16:41 PM »
Would not surprise me one bit that you will find down the line that some other application or function will no longer function properly. What you did was force the operating system to install drivers and other code, when built in safe guards kept aborting the process. Most times this ultimately come back to haunt you later. Particularly if you are running it in compatibility mode under W7 64 bit. The way around this is to run the 32 BIT version of the OS but then you just cut the performance of your PC in half.
« Reply #6 on: June 28, 2011, 09:20:19 PM »
Having just gone through the teething process of installing W 7 64 bit, it is designed to install and run some 32 bit applications, in fact it installs them in a different portion of the OS. The right click "run as administrator" is a real key to making things work right.
No reason to downgrade to a32 bit OS,, I would be surprised if it was "forced" to installk drivers that circumvented the operating system safegaurds,, in fact I would be shocked if it came " back to haunt you " down the road
« Reply #7 on: June 28, 2011, 10:08:18 PM »
the admin mode in VISTA and 7 is designed to stop illegal installs by external  (remote) parties - try loading ANYTHING onto VISTA or 7 and you will have to run it as Admin - it ensures that it is being installed by an operative - not a programme..
