  • July 07, 2025, 09:48:00 PM
Author Topic: Castle link 3.23 Beta  (Read 2779 times)
Offline John Cralley
« on: September 28, 2010, 03:17:40 PM »
This may have been posted previously but today I upgraded to the 3.23Beta firmware. I then made some RPM changes using Set RPM Governor mode. When I tested the new RPM settings my motor started but then went into a "surge" mode where it speed up and then slowed. After about an hour of messing I finally went back to 3.21 firmware and presto the surge disappeared.
John Cralley
AMA 52183
Central Illinois
Re: Castle link 3.23 Beta
« Reply #1 on: September 28, 2010, 04:29:09 PM »
Does the governor mode allow you to change any gains?  Or did loading in the new code wipe out some old settings?  It sounds like the control loop is tuned too tight (or there's a garden variety error in there some place).
Offline Crist Rigotti
« Reply #2 on: September 28, 2010, 04:56:35 PM »
I think 3.26 is the latest FW.
« Reply #3 on: September 29, 2010, 05:40:33 AM »
Crist,
Thanks but I'm talking Firmware here. I'm running 3.26 Software for my Castle Link program. The Firmware is downloaded into the ESC by the Software.
By the way I tried a bunch of settings changes and they did not help. That makes me suspect that the problem is in the Firmware -- this was a Phoenix 10 Amp ESC -- dialing back to the previous 3.21 made it go away.
John Cralley
AMA 52183
Central Illinois
« Reply #4 on: September 29, 2010, 08:40:20 AM »
Crist,
I don't see a 3.23FW revision for the Phoenix ESC's.  Am I missing something?
Offline WhittleN
« Reply #5 on: September 29, 2010, 09:12:44 AM »
I think he means 3.24.  I tried using Firmware 3.24 but my RPM dropped 900. Switched back to 3.20 and RPM returnrd to normal.
Firmware 3.24, 3.22 and 3.21 load with Software 3.26.  Firmware 3.21 is Phoenix ICE 100 specific.
Norm
« Reply #6 on: September 29, 2010, 11:12:53 AM »
Thanks Norm.  I'll have to look into the different FW versions when I go flying this weekend.
« Reply #7 on: September 30, 2010, 06:13:56 AM »
Crist and Norm,
All I know is that 3.23 Beta popped up at the top of the list when I responded to the message that there was new firmware available and did I want to change it etc (don't the Castle  Link and ESC handy to recheck right now - all packed up for a trip to Northern MI). Maybe there was scroll possibility that I missed which would have allowed me to see/load higher versions.
The printout of the parameters for the current settings shows "Firmware version 3.23 Beta" at the bottom of the page (or did before I went back to 3.21).
Norm, How do you know that 3.21 is specific to the ICE 100 ESC?? I guess that fact slipped past me but it seems to work for the Phoenix 10 ESC.
John Cralley
AMA 52183
Central Illinois
Offline WhittleN
« Reply #8 on: September 30, 2010, 07:38:28 AM »
If you go to CC home page, Downloads, Phoenix Firmware Revision History, you can see the listing of Bata and released versions.  If you tell it to install 3.24 it will load all updates that are included in 3.22 etc… so the applicable updates to your ESC may be in 3.21 or 3.22
Norm
« Reply #9 on: September 30, 2010, 07:10:23 PM »
Norm,
You are correct the version 2.23 Beta is not listed on Castle's site it just skips from 3.2 to 3.4. There may be a message in that fact. LOL Why it showed up on my computer when I opened Castle Link escapes me but there it was and it messed up my ESC. l also see on their site that 3.21 is specific for the ICE 100. When the pop up menu appears on opening Castle Link as a firmware option it is not flagged as ICE 100 specific.
Right now 3.21 is working for me and I will mess with other firmware next week when I am home and have some time.
John Cralley
AMA 52183
Central Illinois
« Reply #10 on: October 03, 2010, 07:33:45 PM »
I have discovered a problem with fw v3.23.  It's on my R/C airplane that the motor will pulse just off of full throttle.  I'm using fixed endpoints.  I went back to v 3.20 and the problem went away.  I wouldn't trust v 3.23.  As a matter of fact I'm changing all my ESC back to v3.20.  Good call John.  I have seen the problem you've seen!
Offline Mike Anderson
« Reply #11 on: October 04, 2010, 07:39:34 AM »
They have a graphical explanation of changes in ver. 3.23 -- It seems that you need to recalibrate your endpoints when changing to 3.23 (I'm not sure that I ever calibrated my endpoints for any previous version, but apparently my ESC is happy with whatever I've done).  Anyway, this may explain the surging and Crist's RC plane.
http://www.castlecreations.com/downloads/cl_beta_info_071910.html?subId=696
Mike@   AMA 10086
Central Iowa
Offline WhittleN
« Reply #12 on: October 04, 2010, 07:58:33 AM »
Good morning Guys
This weekend I relooked at the Castel Creations software and noticed that I does say 3.23 on the Firmware.  So between the Castel site and Castel software there is a typo.  I flew Firmware 3.24 yesterday.  The RPM reading on the tachometer are 900 RPM lower than the 3.20 version but it ran very well.  I have my governor gain set to “Custom (45)” and the RPM stayed within a couple hundred of the dial in RPM. I’m very pleased with the ICE 50 Lite.
Norm
« Reply #13 on: October 04, 2010, 08:13:42 AM »
I did recalibrate my end points.
Offline WhittleN
« Reply #14 on: October 06, 2010, 11:49:23 AM »
How do you set your endpoints?  I don't have a clue.
Norm
« Reply #15 on: October 06, 2010, 06:19:02 PM »
Norm
Here's a link on how to do it.  Remember this is for my R/C airplane and not my C/L airplane.
http://www.rcgroups.com/forums/showpost.php?p=15036064&postcount=1
Offline WhittleN
« Reply #16 on: October 07, 2010, 06:48:09 AM »
Maybe that's why I didn't have a clue.  Not for C/L.
I just couldn't imagine what we would be adjusting.
Norm
« Reply #17 on: October 07, 2010, 10:45:54 AM »
I contacted CC and they are aware of the problem plus others.  A new version will be posted within a week......that's what they said.
Offline WhittleN
« Reply #18 on: October 07, 2010, 11:41:02 AM »
I sent them the settings and data log files for my airplane - going from 3.2 to 3.24 and back a couple of weeks ago.  Good that you also contacted them.
Norm
Offline Will Hubin
« Reply #19 on: November 05, 2010, 10:05:03 PM »
Castle Creations software release notes on their Version 3.23 and above note that the governed range becomes from 20% to 90% of full throttle rather than the 10% to 90% of version 3.20 and before. (10% to 20% is now labeled as the "auto-rotate range"--not something we need!) One consequence is that (as various flyers have noted) the FM-9 Phoenix High RPM calibration doesn't give RPMs very close to the tach values any more. Another consequence is that the curve of RPM vs. throttle gets steeper in the range of RPMs we usually use, resulting larger RPM increments between adjacent settings (corresponding to 1/2 of 1% throttle changes).
(All R/C throttle channels of all R/C receivers may not give the full 0% to 100% of full throttle [i.e., 1.0 ms to 2.0 ms pulse width] that our timers easily give, at least partly because they allow a "thumbnail" adjustment/fine tuning. So apparently some helicopter pilots couldn't get the low end of their throttle channel output to 1.0 ms.)
I just made some test stand runs of an Eflite 32 motor with the ICE 50, using both versions 3.20 and 3.24. Sure enough, the motor starts to turn (at a little over 7000 RPM) at 10% throttle with 3.20 but only at 20% throttle with version 3.24.
The 3.20 version of the ICE 50 High RPM calibration with the Eflite is pretty close (usually within 60 or 90 RPM, or pretty much within error limits of measurement) to the Phoenix High RPM now in the FM-9 Programmer, so that is currently usable.
I'm planning to replace the Hacker 1/2A calibration in the Programmer with the 3.24 ICE/Eflite 32 calibration this weekend, and also check the v3.23ff firmware calibration for the ICE/Axi in the near future--which I'm hoping is similar. (The firmware in the FM-9 Programmer is pretty easy to update, if necessary, because all but the first ten or so have the microcontroller in a socket.) The latest firmware also includes 1/2 of 1% spacing when used in either the pure throttle mode or in the compensated throttle mode, so that can always be used to establish one own's RPM calibration.
Offline WhittleN
« Reply #20 on: November 08, 2010, 09:03:42 AM »
Thank you Will
I'm looking forward to the AXI/ICE calibration.  How will we be able to update or controllers?
Norm Whittle
