  • July 07, 2025, 10:24:47 AM
Author Topic: Castle Creations Phoenix v3.0 is released  (Read 1072 times)
Offline Crist Rigotti
« on: November 12, 2009, 08:58:46 PM »
Just noticed that CC has just released v3.22 for their CastleLink and v3.0 for the Phoenix.  Stay tuned.
Offline Dean Pappas
Re: Castle Creations Phoenix v3.0 is released
« Reply #1 on: November 13, 2009, 10:10:14 AM »
I wait with bated breath. (it would be baited breath, but I don't care for sardines anyway.) n~
Dean P.
Dean Pappas
« Reply #2 on: November 13, 2009, 11:57:47 AM »
Gentleman,
It looks like Castle has done their homework.  Very little difference between v3.13/v2.13 and the latest v3.22/v3.0.
As a reminder each version was bench tested on my Resolve EP using a 10x7 APCE cut down from 11 inches.  I find that this prop comes very close to the same load while flying.  Both versions were run using the same set up.  Apples to apples, just 1 month apart.  Also the temp for the ESC on v3.13 may be a little low from actual.  Not much tough.
V3.13/v2.13
Battery temp - 120
Motor temp - 122
ESC temp - 97
Mah used - 2422
Amps ave - 23.32
Min Volts - 13.83
V3.22/v3.0
Battery temp - 123
Motor temp - 122
ESC temp - 104
Mah used - 2465
Amps ave - 23.91
Min Volts - 13.76
« Last Edit: November 14, 2009, 10:19:23 AM by Crist Rigotti »
Alan Hahn
« Reply #3 on: November 13, 2009, 12:06:42 PM »
Crist,
Was the ESC a Phoenix 45?
Alan
« Reply #4 on: November 13, 2009, 12:08:58 PM »
Alan,
Yes the ESC was a Phoenix 45.
Online Dennis Toth
« Reply #5 on: November 13, 2009, 02:33:58 PM »
Crist,
Looking at the CC web site it indicates that they added a "Punch Control" for acceleration, could we somehow use this to give the little pop out of a corner?
Best,                  DennisT
« Reply #6 on: November 13, 2009, 08:01:41 PM »
Crist,
Best,                  DennisT
The best to know is to fly it and see.  Not much flying going on around here.
