  • June 30, 2025, 12:53:26 AM
Author Topic: Carbon Fiber Pusher 13x4.5 Available  (Read 679 times)
Offline frank williams
« on: March 21, 2012, 12:44:09 PM »
All,
Mejzlik Modellbau in the Czech Republic has produced a carbon fiber PUSHER prop (13x4.5).  The blades are extremely thin, under-chambered, stiff, and accurately pitched.  The prop weight is very light, ~25 grams.  The finish of the props is superb.
I am selling the prop for $40.00 each.  There is a $5.00 mailing charge for 1-4 props (US only).  PayPal is the preferred method of payment.  Lonestar_77062@Yahoo.com.
The fact that the blades are stiff and do not “flex-in” extra pitch when loaded, means that the required RPM for typical stunt flight is slightly higher than what was used for the thin 4.5” pitch props in plastic.  Typically the RPM required is about 10.1K to 10.3K.   In my opinion, the flight performance with these props at this pitch is superior.  The props can be re-pitched by the user for lower RPM’s if desired.  These props have a robust hub area for both electric and IC engines.
Order at lonestar_77062@yahoo.com while supply lasts,
Frank Williams
