  • June 20, 2025, 07:48:26 PM
Author Topic: 4s battery for power 25  (Read 1332 times)
Dwayne
« on: June 17, 2019, 11:20:10 AM »
Hey all, I have a E Flite Power 25 probably around a 12X6 prop going in a Legacy 40 type stunter, it's a tight space where the battery is going so a 5s won't fit, please about what MA ratting will I need?
thanks.
Offline Bob Hudak
Re: 4s battery for power 25
« Reply #1 on: June 17, 2019, 11:27:07 AM »
Thunder Power 4s 2800mah 25c will get the job done. You might need to trim the prop to 11.5" but do try it at the full 12" first. I trimmed mine down because the corners were too soft. Big difference by losing a  mere 1/2"!
Bob
350838
Online Mike Alimov
« Reply #2 on: June 17, 2019, 12:35:08 PM »
Bob is pretty close. I run the following setup in my kid’s Vector arf: Cobra 2820-12 (kV 970), Zippy Compact 4S 3000 mAh, Talon 35, FM-9 timer, prop APC 11-5.5 pusher. The extra battery capacity allows us to fly on longer lines 62.5’ at 5” lap for slightly better wind resistance.
By the way, the Zippy batteries are not only half the price of the Thunder Power, they also have lower internal resistance (11 mOhm per cell on average vs 15 mOhm for the TP). They are about one ounce heavier though.
Offline Fred Constantine
  • C/L Retread
« Reply #3 on: June 17, 2019, 04:27:25 PM »
thanks.
Dwayne - I have flown a similar setup for two seasons - Hacker A30-10XL (same specs. as the E-flite 25), Castle Ice Lite 50, Hubin FM-9, APC 11x5.5 pusher, and Zippy Compact 4cell X 2700 mahr, in a 49 ounce much modified ARF Nobler.  Four cells with a 900kv motor is fairly standard, and produces plenty of power.  Zippy Compact will just fit in the narrow Nobler fuselage. The challenge is to creating adequate air flow around the battery. I have used the 12X6, but prefer the 11X5.5. The 2700 mahr battery is 80% exhausted after 5:30 air time.  The two props consume about the same mahr when flown at the same airspeed.  The one inch increase in diameter from 11 to 12 is offset by the 1000 RPM reduction due to the higher pitch.  The increase in pitch has only a small effect on power required.  Keep checking this forum, the info is here.
Fred Constantine
Calistoga, CA   AMA 6798
Offline Bob Hudak
« Reply #4 on: June 17, 2019, 05:30:11 PM »
Mike,
 My new Thunder Powers are 8 meg ohm per cell. The 5 yr old TP battery is chugging along at 10-11 meg ohm.Bought the new ones on Black Friday, $35 ea. nobody gets hurt! Hope to get 6 yrs.or more on them.
Bob
350838
Dwayne
« Reply #5 on: June 17, 2019, 07:21:14 PM »
Thanks guys I have a couple Venom 3200 so I guess they are a bit overkill but will give em a go. Thanks again.  #^ y1
