  • June 29, 2025, 12:55:30 PM
Author Topic: E-Flite 25  (Read 1341 times)
Online James Mills
E-Flite 25
« on: January 24, 2012, 09:39:45 PM »
Can any of you guys post some pictures of how you mount the E-Flite 25 in a full body plane (I tried a search and didn't really find what I needed).  Is there a way to front mount or does this motor have to be rear mounted?  This is my first attempt with electric so I'm fumbling through the learning process.
James
AMA 491167
Offline jose modesto
Re: E-Flite 25
« Reply #1 on: January 25, 2012, 06:46:58 AM »
James couple of photos on how i mount my motors.
Firewall mount and through fire wall mount.
NOTE: the through firewall mount eliminates the need for a removable cowl.
Hope it helps.
James there are many that advocate front mounted with rear shaft support. For my uses the firewall mounted motor has worked very well. The only time that i had any issues was with the Axi 2826-10 with fire wall mount. This motor after some abuse on my part,the can started to rub against the magnets.
Motors used with firewall mount Eflite 25-32,Axi 2826-10,Platt's 15-18,20-12,25-14,30-14 scorpion and many of the cheaper motors.
Photo#1 Firewall mount with exaust outlets around motor
Photo#2 Through firewall mount
photo#3 finished model,  photo#1 shows the fuse used on this model
Jose Modesto
Online James Mills
Re: E-Flite 25
« Reply #2 on: January 25, 2012, 08:48:44 PM »
Thanks Jose.
James
AMA 491167
Offline Dean Pappas
Re: E-Flite 25
« Reply #3 on: January 25, 2012, 09:11:02 PM »
Hello James,
You've been searching in all the wrong places, then ...
Try looking through the "list your setup" thread. There are many instructive pictures.
Yes, the motor can be front mounted, and I strongly suggest it.
      Dean Pappas
Dean Pappas
Offline Mike Haverly
Re: E-Flite 25
« Reply #4 on: January 25, 2012, 10:36:40 PM »
I have an E-Flite Power 32.  It has instructions on how to reverse the shaft, which is what you want.  I've done this and it makes it front mounted.  I would think the 25 has the same instructions.
Online James Mills
Re: E-Flite 25
« Reply #5 on: January 26, 2012, 08:12:49 PM »
Thanks Mike, mine did not come with any instructions.
James
AMA 491167
Online James Mills
Re: E-Flite 25
« Reply #6 on: January 26, 2012, 08:14:31 PM »
Hello James,
      Dean Pappas
Thanks Dean, I opened the electric section and then used the search function.  I'll check out the set up thread.
James
AMA 491167
Re: E-Flite 25
« Reply #7 on: January 26, 2012, 08:26:51 PM »
James,
here is a link to the online version of the instructions,, on page 3 it talks about reversing the shaft to mount it from the front.
hope this helps
http://www.e-fliterc.com/ProdInfo/Files/EFLPower25OutrunnerInstructions.pdf
Online James Mills
Re: E-Flite 25
« Reply #8 on: January 26, 2012, 08:32:41 PM »
Thank you sir
James
AMA 491167
