  • July 11, 2025, 04:35:54 PM
Author Topic: Can I use 5S in Turnigy G25?  (Read 1603 times)
Offline Guilherme Souza
« on: October 24, 2013, 06:36:45 PM »
Dear all
Can I use 5S Battery in Turnigy g25 (E-flite 25) copy ?
I have 2 5S batterys 2450 mAh and I would like to try with a low pitch prop
But I ´m afraid to burn the motor
Thank you
Online John Rist
Re: Can I use 5S in Turnigy G25?
« Reply #1 on: October 24, 2013, 08:53:46 PM »
What is the KV of your motor.  If it is the 610 KV it should be OK on 5S (18 V), with an RPM of 10980.  If it is 870 KV RPM would be high at 15660.  With the right prop the motor should be safe.
« Reply #2 on: October 25, 2013, 04:49:53 AM »
Dear John
The kv is 870 , this motor is copy of e-flite 25 ,
I have 2 batterys of 5S and would like to try
But this is my only motor so I can t take a risk
thank you
guil
Offline Dean Pappas
« Reply #3 on: October 25, 2013, 12:16:58 PM »
Hi Guil,
I'm afraid not. A Kv near 750 is most apprpriate for 5S.
 Dean P.
Dean Pappas
« Reply #4 on: October 25, 2013, 03:58:53 PM »
Hi Guil,
 Dean P.
Hi Dean
Thank you for your answer
I dicided that I will not use
I will keep these batterys to another motor
thank you
guil
Offline William DeMauro
« Reply #5 on: October 26, 2013, 12:36:16 PM »
I have had the power 25 and the G 25 side by side. It is NOT a copy of the power 25 as some are lead to believe. I have also heard, though not confirmed, that they are 10 pole motors which make them less than ideal for our use. If you are one of the few running obne with a 2.4 gig throttle system then it does not matter.
AMA 98010
« Reply #6 on: October 28, 2013, 06:08:36 AM »
Dear DeMauro
Excuse me but I didn´t understand
For our use the motor need to be 12 poles ?
I trying to find some good motor in Hobbyking site , but to control line is difficult
Could you tell me one good for Control line ? I would like one to use in a 60 size glow plane  witl batterys 4S and 5S
thank you
Guil
Offline Jack Pitcher
« Reply #7 on: October 29, 2013, 12:57:31 PM »
I have both an Eflite Power 25 and a Turnigy G 25 on my bench. I bought a G 25 on the rumor that they were the same motor as the Eflite. As Will has stated they are not the same. The physical shape and dimensions are slightly different. I visually counted the magnets in both. The Eflite has 14 magnets, the G 25 only 10. The difference is easily felt when rolling them over by hand. The cogging is much rougher on the G 25.
I’ve run them both for very short runs on a test stand. I used a KR timer set and tached at 9300 rpm on the Eflite on an APC 8-6 prop cut down from a 12-6. With the same prop and timer setting the G 25 ran at much higher rpm. I don’t remember the number right now but it was well over 12,000. I shut it down after 15 seconds, put it back in the box and set it aside.
I’m assuming that the KR timer is looking for a certain motor pulse count that equates with 9300 rpm on the 14 pole motor and to get that same pulse count from 10 poles the rpm has to be considerably higher. I suppose the rpm could be dialed back down but whether it’s safe to run that way, I don’t know.
Jack
« Last Edit: October 29, 2013, 01:44:17 PM by Jack Pitcher »
Jack Pitcher
Vortex Stunt Team
AMA 65309
Offline jose modesto
« Reply #8 on: October 29, 2013, 01:29:59 PM »
If you are using a Castle speed controller the 10 pole motor can be used. See Howard list for programing the castle with 10 pole motor. The platt motors are 10 pole and they are used with Castle controllers.
Jose Modesto
« Reply #9 on: October 29, 2013, 03:15:40 PM »
To clarify, 14 pole motors work best for our use. Motors like the power 25, Scorpions, Cobra's, Axi, some Turnigy but not all , some Exceed but not all are 14 pole motors. Castle speed controllers seem to be the most compatible with 14 pole motors. This does not mean that Castles controllers cant be used with 10 pole motors as some people are doing. Like Jose says Howard is doing it very successfully. Since you already have the G25 I would try it but with a 4 cell pack and see how it works out. You can also get the G 25 in a 710kv version that you can use your 5 cell with. http://hobbyking.com/hobbyking/store/__19024__Turnigy_G25_Brushless_Outrunner_710kv.html
If you are looking for a budget motor an emax or aerowind might work well for you as long as you are willing to buy somewhere other than Hobby King The Emax/Aerowind 2826-06 is similar to a power 25 and will use a 4 cell battery. The Emax/Aerowind  Emax BL3526/05 is similar in size to a power 32 but will work with a 5 cell battery
AMA 98010
