  • June 22, 2025, 02:21:31 PM
Author Topic: Prop Adapter with Collet, 4mm  (Read 1398 times)
« on: December 22, 2020, 07:02:03 PM »
Guys,
I am just finishing up my electric S1 Ringmaster and installed a E Flite Prop Adapter with Collet, 4mm. Problem is that the shaft thread is a bit short 5/8" and doesn't allow installing a spinner with a normal width hub needs about 3/4". Anyone know who makes a longer shaft adapter?
Best,    DennisT
Online William DeMauro
Re: Prop Adapter with Collet, 4mm
« Reply #1 on: December 23, 2020, 05:02:51 AM »
Hyperion makes Xl adapters that I have been using for years . The   one that should work for you is the ADAP 40xl. They can be found here and at other places  https://hyperion-world.com/en/p1773439-hp-adap-40xl-12601. The last time I ordered from here , the shipping was insane but they did refund the difference to actual shipping a day or 2 later. Of course I cant guarantee you the same experience.
AMA 98010
« Reply #2 on: December 23, 2020, 07:04:17 AM »
Thanks William, I just order a few, site worked well.
Best,   DennisT
« Reply #3 on: December 30, 2020, 11:52:25 AM »
Success - the Hyperion 4mm Xl adapter works perfect with a Dubro 1 3/4" spinner and APCE - P 9x6. Thanks again William.
Best,     DennisT
« Reply #4 on: February 01, 2021, 12:03:35 PM »
I have found one issue that you should look out for if you use the Hyperion 4mm XI adapter. The shaft is 6mm not 1/4". This works OK with a new Great Plains electric spinner but if you had opened it for use on an E Flite adapter it will be over size by about 0.006". This may not seem like a lot but it will throw the balance off and cause the motor to make odd sounds as it spinners up. I believe on the DuBro spinners you can fit one of the inserts to get a good fit. Also check your prop fit, they are likely 1/4" so you should be able to use an insert there also.
Best,   DennisT
Update: Just ran a test on the new backplate sized for a smooth 6mm fit and same for prop. The run-up was smooth, to full power-rpm. No odd noises or vibration.
« Last Edit: February 01, 2021, 05:09:50 PM by Dennis Toth »
