  • July 12, 2025, 09:11:32 PM
Author Topic: blank  (Read 1448 times)
Online Motorman
blank
« on: March 24, 2014, 11:32:48 AM »
blank
« Last Edit: October 07, 2021, 01:02:37 PM by Motorman »
Offline William DeMauro
Re: Building 2nd E Plane
« Reply #1 on: March 24, 2014, 12:50:54 PM »
I don't swap. With creative buying its not very expensive. I only have my #1 and one other flying anyway. My son has a #1 and a back up ready. I have a new # almost ready and hopefully my son will have a new#1. I have an ARF flight streak set up for short flights for my dad and intro to electric (training purposes).
AMA 98010
Offline 55chevr
« Reply #2 on: March 24, 2014, 12:53:43 PM »
What Will said.   I don't swap the set ups either.   I have 3 ready with all electrics onboard.
Joe Daly
Offline Crist Rigotti
« Reply #3 on: March 24, 2014, 01:15:51 PM »
No swapping for me either, except batteries.
Offline Robert-Jan
« Reply #4 on: March 24, 2014, 01:20:46 PM »
Even worse I have every part spare.
If you are at a competition and your ESC is blown..........
Greetings Robert-Jan
Offline RC Storick
« Reply #5 on: March 25, 2014, 06:27:52 AM »
Well here it is for the cost of 1 PA .75 I got 5 2826/12 Cobra motors. So if you take into cost the pipe and header for the PA you can get the rest of the setup less the batteries. The battery is the knee bender if your using the high priced ones. I have 6 of those at $100.00 a pop. But you look at I don't have to buy fuel at 20+ a gallon for 20 flights.
So the cost at first seems high but over the long run cheaper.
Offline Bob Hudak
« Reply #6 on: March 25, 2014, 07:29:51 AM »
Invest in the 2nd setup. Less hassle swapping out parts and you can take both to the field and fly to your hearts content.
350838
Offline 55chevr
« Reply #7 on: March 26, 2014, 03:24:21 PM »
MM --- once you get past 3 planes the wife can't tell how many planes you have. Paint them all the same colors and don't store them together.
Joe Daly
« Reply #8 on: March 29, 2014, 01:00:18 PM »
It's often difficult to swap electrics between planes.  Space constraints often require wiring to be shortened (you know, batteries and motors seem to come with 10" long wires).  This makes each installation more or less a custom job.
