  • July 16, 2025, 02:24:36 PM
Author Topic: Broken magnets  (Read 6937 times)
Offline Guilherme Souza
Broken magnets
« on: September 11, 2016, 08:50:14 AM »
Dear all
Had Someone problems with EFlite  32?
I'm  trying to use spinner but the original system that uses a clamp (I don know if the name is correct) don't hold the propeller in place and when this happen the motor broke magnet part.
Thank. You
Guil
Enviado de meu ASUS_Z00AD usando Tapatalk
Online Fred Underwood
Re: Broken magnets
« Reply #1 on: September 12, 2016, 02:36:58 PM »
Not sure that I really understand what happened.  Is the clamp in question a collet?  Did a magnet inside the motor break or come loose?
Fred
352575
Re: Broken magnets
« Reply #2 on: September 12, 2016, 02:44:42 PM »
Do you mean the prop adapter?
Normally when a prop adapter comes loose the prop assembly just flies off the end of the motor without immediately damaging anything -- any damage that happens comes later, when the prop or the airplane smacks into something.
This is known as a "collet type" prop adapter in English:
Offline Kim Doherty
Re: Broken magnets
« Reply #3 on: September 12, 2016, 04:55:50 PM »
Dear all
Thank. You
Guil
Guil,
The collet (clamp) is made of fairly soft aluminum. (vs the steel shaft and prop nut) If you over tighten the collet you will expand the taper and ruin the collet. They are very powerful and only need to be medium tight. (no explosions trying to shake the prop loose) Think of the collet just like a glow plug... cheap and indispensable. If in doubt, replace it with a new one.
I think the prop coming loose caused an imbalance and the magnets and stator touched. The air gap is fairly small. You could try taking it apart and using just a very small amount of JB Weld or CA to glue it back in. Clean the area well before gluing and wipe away any squeeze out. I have built complete motors and this is not a hard thing to do.
The EFlite series is not a high end motor. Some minor problems could be expected. You might also check your bearings.
Kim.
Re: Broken magnets
« Reply #4 on: September 12, 2016, 07:41:49 PM »
Dear Fred
The magnets broken
The collet loose and after this happen the motor get hard to turn .
When I open the magnets were broken
Online Motorman
Re: Broken magnets
« Reply #5 on: September 12, 2016, 08:47:54 PM »
If the prop came off and the motor screamed out then too much heat made the magnet come out and break also might have melted the insulation on your wires. You can try to glue the magnet back in but still might not work because of melted wires.
Re: Broken magnets
« Reply #6 on: September 12, 2016, 09:02:50 PM »
If the motor is within a year of purchase.. it might be under warranty if the damage is not from a crash.
Re: Broken magnets
« Reply #7 on: September 12, 2016, 09:14:31 PM »
Does the throttle try to maintain set rpm, or is there just a moment of rev or torque change?  I actually remember a friend loosing a prop with KR timer and there was not over rev, but the KR uses a sensor wire for rpm and has the governor in the timer.
Dear Fred
The magnets broken
Thanks for the explanation.  I'm happy that it got some discussion for you.
Fred
352575
Re: Broken magnets
« Reply #8 on: September 12, 2016, 10:56:39 PM »
Dear all
Excuse me my English , sometimes is difficult to explain.
Yes the collet goes off and the motor stop. This the second time this happen
Both times I was trying to use a spinner.
The first time broke one magnet too . But I removed the parts and used normally ,without spinner.
I will try to send some pictures.
I have this motor more than 2 years .
It is a Christmas gift from a big big Friend.
Thank you
Re: Re: Broken magnets
« Reply #9 on: September 12, 2016, 11:01:28 PM »
Thank you  Tim
This is exactly what I was trying to say.
Do you know if is possible to change this prop adapter to a different type?
My Hyperion and Cobra motor have a different prop adapter .
Thank you
Guil
Online Crist Rigotti
Re: Broken magnets
« Reply #10 on: September 13, 2016, 12:11:50 AM »
This is the prop adapter I use with a spinner.
http://www.rcdude.com/product-p/hp-adap-50xl.htm
Hyperion HP-ADAP-50XL
It works with a 5mm motor shaft and it has a 6mm prop shaft and nut.
Re: Broken magnets
« Reply #11 on: September 13, 2016, 08:51:16 PM »
Hi Chris
thank you but I´m looking for some prop adapter that use bolts  like Cobra Motors
Do you know where I can find it ?
Thank you
Guil
Re: Broken magnets
« Reply #12 on: September 13, 2016, 09:12:48 PM »
Oh, sorry I thought you were looking for a prop adapter with a long enough shaft to fit a spinner.
Offline Horby
Re: Broken magnets
« Reply #13 on: February 26, 2017, 01:17:56 PM »
Are you front or rear mounting your motor?
Warren
Online Motorman
Re: Broken magnets
« Reply #14 on: February 27, 2017, 08:22:14 AM »
blank
« Last Edit: March 06, 2022, 09:20:33 AM by Motorman »
Offline Horby
Re: Broken magnets
« Reply #15 on: February 27, 2017, 08:11:21 PM »
Mounting position makes a difference in bigger planes.
W
Re: Broken magnets
« Reply #16 on: March 02, 2017, 03:47:54 PM »
I just happens to have an E-flite 32 with perfectly good magnets but the stator has an issue..  I might be interested in the stator if it is in good shape.   :)  or maybe vice versa
« Last Edit: March 02, 2017, 09:46:18 PM by Joe Yau »
Re: Broken magnets
« Reply #17 on: March 07, 2017, 08:01:01 PM »
Joe
I have interest
I´m using this motor  with the magnets broken , and until now is working normally .
I will buy cobra prop adapter ,that uses bolts  and use it .
Thank you
Guil
