  • July 13, 2025, 05:52:49 PM
Author Topic: Brodak Blue Angel Kit with Brodak Electric Conversion Kit  (Read 1002 times)
Offline David Ruff
« on: August 15, 2019, 07:39:21 AM »
So I am thinking of this as my first electric.  Anybody familiar with the Brodak conversion kit for Blue Angel?
Thanks in advance.
Retired Army
Re: Brodak Blue Angel Kit with Brodak Electric Conversion Kit
« Reply #1 on: August 15, 2019, 10:28:13 PM »
Hi David,
The Electric Conversion for the Blue Angel is a fairly recent addition to the Brodak line, and since we are not into building season I would be pleasantly surprised to hear if any are flying yet.  Attached below is a copy of the assembly manual for the conversion, so you can see what it entails.
The design includes a front mounted motor and shows a Brodak 2826 installation, which should be more than enough power.  However there is room for even the large frame (35xx series) motors - I would only use one of those if the airplane turned out tail heavy and needed extra nose weight.  The installation includes an inboard side-access battery compartment both for security and to get around the forward location of the canopy which precludes a top hatch.  The conversion also includes building a reinforced pocket into the wing leading edge to allow the battery to go aft an extra inch or so if needed to adjust CG.
I designed and built the installation shown in the instruction manual. My Blue Angel has been essentially ready to cover since March of this year, but got set aside as I have built five other conversions since then, with a sixth currently on the board.  Should you go forward with this, keep in touch and I can help you with any questions along the way.
Offline David Ruff
« Reply #2 on: August 16, 2019, 05:12:35 AM »
Dennis...thanks very much.  I think I will try the Tanager first, however.  Profile with a Brodak conversion.
Retired Army
