  • July 15, 2025, 12:33:15 AM
Author Topic: Brodak Ares setup?  (Read 4426 times)
Offline Steve Schoenecker
Brodak Ares setup?
« on: December 05, 2016, 11:15:41 AM »
After looking through all 62 pages of the engine set  up tips forum... I am wondering if an electric setup might be a better way to get back into learning to fly stunt again?  I bought an FP 40 off ebay...  After reading the engine setup stuff... I think that I understand the issues and accept the wet 2 cycle... venturi stuff...  I am wanting to build a brodak ares 59 kit.  I am trying to come back after about 30 yrs.  wondering about fuel tank height, uniflow, suction, pressure, etc...  I built a dolphin stunter when I was in High School  with stallion .35... never did get the engine run where I wanted it...  could not get to the tank after finishing the airplane...
I wonder if going electric with this one would let me concentrate on learning the pattern again without worrying about engine runs etc.  Any suggested electric setup for ares 59... I have no idea if I can build it light???  Thanks for your help!!
AMA 69021
Online Brent Williams
Re: Brodak Ares setup?
« Reply #1 on: December 05, 2016, 02:26:47 PM »
This isn't really an answer to your question, but it addresses an issue that you might appreciate.
IMHO, The Ares is too complex and fragile of a plane to use for relearning to fly stunt.
I would think a simpler and more durable design would be a better choice for your return to the fold.  Save the E-Ares for your 2nd plane after you have completed a good season of flying and your aren't crashing regularly.
I have used this simple plane to go from flying not so good loops and lazy eights, to being able to fly a pretty recognizable pattern.  I burned 2.5 gallons of fuel, 4oz at a time, learning the pattern this year and it has been great!  The fuselage is my design and it uses a foam wing.  The wing is from Phil Cartier at the Corehouse.  Ask for a Gotcha 500 with the 3" tip extensions for 54" span and 540 in.sq.  You can buy the wings 4 at a time and build a small fleet of planes to keep you flying all season.  I have repaired the wing 8 times, the fuselage 5 times, the rudder 4 times and it is still ready for more action this spring.  I have had a blast with this thing and would recommend something similar to anyone interested in making progress learning the pattern.  I fly it with a stock OS LA46 on 65ft lines (handle to fuselage centerline).  This gives comfortable lap times and plenty of sky for maneuvers.  E-power would be a cinch to adapt.
You can't learn if you are afraid to take it down to 5 feet.  There will be carnage.  Prepare for it.
« Last Edit: December 16, 2016, 06:50:41 PM by Brent Williams »
« Reply #2 on: December 06, 2016, 09:23:22 AM »
Hi Steve - WELCOME BACK to CL
The Ares is a beautiful bird, its easy to understand your nostalgia for it.  I design the electric conversions for Brodak and write the assembly manuals. The Brodak Universal "A" conversion (#BH-1943) was built into a Brodak Ares - I attached a couple pictures for reference.  I expect to finish my Ares (finally!) this winter and am optimistic about hitting my target weight of 42 oz RTF which is good for an Ares, the design does not fly well if heavy.  I will be using the following power system, (of course you can use other brand X parts and still succeed)
Arrowind 2815 #BH-1843
Brodak F2B Hornet 40A ESC #BH-1866
Hubin FM-Hornet Timer #BH-1883
4S x 2250 Lipo #BH-1888
Prop: either a Brodak 10x5 Electric (BH-1915) or an APC 10x5.8EP
This will be more powerful an far more dependable than you old Stallion 35 was!
BTW, you can also browse the "List your Set-ups" sticky note at the top of this section to see what other folks have used in similar sized birds...
« Reply #3 on: December 06, 2016, 10:15:10 AM »
Brent...  Not exactly what I wanted to hear.  But.... you are probably right.  I built a Big Otto from plans downloaded from outerzone... and I found the instruction sheet from one I built in high school...   I have already crashed it a couple of times.. with short 1/2A lines it was running 3 sec laps... I got dizzy and fell down  :-(...  made a set of 35' lines.. still really fast... - Really good golden bee...   trying to stand still and do lazy 8's and loops etc...  for a while...  getting better...  I have been thinking about getting a flite streak trainer for my grandson...  your idea may kill 2 birds with one stone.
I have emailed Phil and am waiting to hear what the cost is for wing sets etc...  the price list listed on the website says 2010... If not too much $$ I may get a 4 pack of wings.  The 540 - 550 area is about the same as  the brodak ares 59 which says it is 542.  I may just use the FP 40 I bought to get used to it... also I have 2 36X's, an old 35 combat special and some other .25, .35 and .45 engines...  I could start working on electric setup too... get my feet wet.
I may go ahead and order the ares and get started...  should be able to whip up some trainers pretty quickly and get to work... I would really like to try to go to the DMAA contest in Feb... Don't really know if I can be ready by then... depends on the weather... We can fly behind my shop if the weather permits... so it is convenient... no excuse for not practicing....
Thank You Dennis...
This will help me start looking at equipment.  I have no Idea what to expect the finished airplane to weigh.  I would think the first one will be more basic...  simple finish etc...   I wonder if I build some of these trainers -  if I should make one heavier like an ares?
Thanks again Guys!!
steve
AMA 69021
Offline Skip Chernoff
« Reply #4 on: December 13, 2016, 03:30:14 PM »
Steve,welcome back to C/L. I would not recommend you starting out with the Brodak 59 Ares. Although it is a stunningly beautiful model when built and finished properly it is also very time consuming to build.....and as Dennis mentioned it must be light to fly well. I'm working on one right now.  Also the Ares likes to fly fast which is not the best situation for someone trying to get back into stunt. Brodak has a ton of models that fly just as sweetly as the Ares  and are much easier to build.
« Reply #5 on: December 14, 2016, 07:50:22 PM »
You don't want to crash with electric unless you're rich.
Offline Russell
  • ACE
« Reply #6 on: December 16, 2016, 02:45:16 PM »
I also have a Brodak 59 Ares to build and have the electric conversion kit too.
Along with all the positives with electric fly there some negatives I'm finding out as follows:
1. It costs more than nitro or gas initially and ongoing.
2. The Lipo batteries are an extreme fire hazard and should never be kept indoors risking the loss of your home.
3. The components don't last like most electronic stuff, whereas engines last for years.
4. Depending on how you fly many expensive batteries are needed vs. one fuel tank for an engine.
5. Sky high electric bill from running a charger or two.
6. It's a big cash cow for the manufacturers.
Offline Fred Underwood
« Reply #7 on: December 16, 2016, 04:59:58 PM »
I got curious so tried to add up the cost.  I started from scratch a couple of years ago and found about this
Motor about $60
Hubin system
ESC                 65
FM-9 timer     10
Jeti box        40  once    edit as posts below, not the Jeti Box, but the FM-9 programmer for $75 if current.
KR system
ESC                50
timer             50
program        15 once
Lipo storage in fire safe box  $20 – 30 on Amazon.  Of course you may wish to spend more and get a large box.  Cell phones and many tools and electric conveniences share those lithium batteries.  Of course that will make the conveniences inconvenient.
Components other than batteries should last.
4 6S packs for 128.50 used for 500 flights so about 0.26/flight or per tank of fuel.
Recharge one pack 2 amps x 25.2v 100.8 watts or 400watts for 4 packs and with inefficiency, perhaps double.  One 100w bulb for 8 hours...  The cost of a kilowatt-hour of electricity varies across the country, but the average (including all charges) is about 15 cents.
Cost of motor and electronics, 150/500 about 0.30/flight or up to 0.33/flight if the higher option
So about 0.55/flight – 0.60/flight with the box
Charger costs vary and the chargers should last over years and many battery packs, so a bit more difficult to figure "in the tank costs."  Of course those IC motors like batteries, glow plugs and other items as well.  If fuel is about $20/gallon and you get 32 flights then about 0.60/tank and that doesn't include motor and initial costs.  I haven't researched fuel costs and usage so may be off a bit.
What is the cost of building the plane if your time is worth 1.00/hr  plus supplies?  Is there really enough difference in IC and E to offset the overall costs, and the overall enjoyment, at least on some days, of the hobby :)
« Last Edit: December 16, 2016, 06:06:36 PM by Fred Underwood »
Fred
352575
« Reply #8 on: December 16, 2016, 05:48:02 PM »
Hubin system
ESC                 65
FM-9 timer     10
Jeti box           40  once
I didn't know you could program the FM-9 with the Jeti-box.   are you sure that works?
« Reply #9 on: December 16, 2016, 06:03:06 PM »
Joe,
I have not used Hubin and didn't read carefully about using it's own programmer since I was estimating cost.  So, I will revise above to reflect the Hubin Programmer.
Fred
Fred
352575
Offline James Mills
« Reply #10 on: December 17, 2016, 07:13:51 AM »
Not sure what you mean by this.  Ben has put his plan in more times than I can count and normally all we lost was a $3-4 prop.  We have lost a couple of batteries and motors in these crashes (batteries and motors both are under $25).  I flew IC for years, and enjoyed it, and have busted motor cases, mufflers, metal tanks, and several other things that had to be replaced as a result of crashes.  So either way you power a plane, there is a chance of loosing equipment, no need to try to steer someone away from a set up.
James
AMA 491167
« Reply #11 on: December 17, 2016, 09:10:51 AM »
Joe,
Fred
I was hoping it could. as I like to pack light.. there are times I have to bring both programmers.
Offline Keith Renecle
« Reply #12 on: December 17, 2016, 10:21:00 AM »
I always respect the opinions of others, but in this case the above is a little biased towards gas engines. For a great classic model you will need a good, light engine that can perform really well to do justice to flying a good pattern. You will also need a good, light prop, and it is not that easy to find really good wood props without some re-working. The standard APC props are cheap and they do work but are too heavy. On the other hand a cheap electric motor as suggested by Dennis will outperform your standard, sport glow engines hands down when it comes to the price/performance story. The APC E props are really good and very light, they cost peanuts, and used with a good governor system will really be hard to match with your average OS LA .25 sort of set up. When the weather is iffy, then e-power rules! You just switch on and fly without mucking about with needle settings, venturi sizes, special glow plugs, nitro, uni-flow tanks etc. etc. Did I mention the gunk that eats the paint off your model??
On the cost front, the two systems are similar and I would say that these days with low cost batteries and cheap esc's, e-power will come out cheaper. I fly both and still love engines but that is more of a nostalgia thing than a performance one. You can buy really expensive electric packages and these are similar to the high-end glow systems, but a basic system like Dennis suggests is not expensive and will perform at top level. I mean to say......Dennis has been around for a while and knows the stunt scene rather well (understatement!) so he knows what he's talking about. I would really suggest to try his setup.....you'll not be sorry!
Keith R
« Last Edit: December 17, 2016, 11:29:12 PM by Keith Renecle »
Keith R
« Reply #13 on: December 17, 2016, 11:26:15 PM »
On The engine story, a nice engine would be one of the Enya's like the 30SS or the special 35 with the anodised red head. The 30SS weighs about the same as a Fox 35 and the lightweight muffler does not add much at all.
Keith R
« Last Edit: December 18, 2016, 12:42:56 AM by Keith Renecle »
Keith R
