  • June 17, 2025, 01:47:27 PM
Author Topic: p 38 ( maybe )  (Read 889 times)
Offline paul winter
p 38 ( maybe )
« on: November 06, 2012, 11:46:44 AM »
hi all
now for the twin
i have scaled up an A4 drawing ,bar the wing profile it has come very close to what i want ,as the picture shows (front u/c leg missing at the moment )
spec will come later but the start is
2 3810 -1000 os motors
4 cell 4400 battery ( battery shown not the correct one )
10-15 e flight retracts
2 esc castle with one red wire removed
will hubin fm9r timer
this only at plan stage
paul
Offline Steve Fitton
Re: p 38 ( maybe )
« Reply #1 on: November 06, 2012, 12:36:08 PM »
Be daring and do a B-36  VD~
Offline Bob Hudak
Re: p 38 ( maybe )
« Reply #2 on: November 06, 2012, 07:51:49 PM »
Looks like a tight squeeze for the battery and nose gear in the center pod. You will definitely be loading the battery thru a top hatch.
               Bob
350838
Offline paul winter
manchester
« Reply #3 on: November 16, 2012, 11:04:22 AM »
i have decided now to do another Manchester
it gives a good wing and the fuz has a nice nose for balancing the model
i built one many years ago but a faulty pushrod end cost me a very nice model
that one was 78 ozs and had 2 saito 40's
this one will follow Bobs Hunt's set up but with Os motors
i will try and put a build sequence as i go
paul
Offline Dean Pappas
Re: p 38 ( maybe )
« Reply #4 on: November 17, 2012, 08:54:44 PM »
Hi Paul,
As handsome as the last one was ... yes, you sure ought to.
take care,
  Dean
Dean Pappas
