CLICK HERE--><--CLICK HERE
Wiring Instructions FIORETTI TIMER & JETI SPEED CONTROLLER
Started by Steve Dwyer, March 25, 2026, 06:38:14 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Steve Dwyer
Where can I find the circuit diagram instructions to set up the Jeti Box to program the Spin Pro 66 ESC and Fioretti Timer? The products come with no instructions for positioning the timer accelerometer, what connection ports to use on the Box, which pins to use on the timer for the set up and the connection to the ESC. The literature only covers setting up the control parameters but nothing on the physical wiring. I found two videos someone has created but still leaves a number of questions, a PDF would be helpful.
Ken Culbertson
Just plug the Spin BEC cable directly into the top set of pins on the timer.  That's it.  BUT, to program the ESC it needs to be disconnected from the timer and  connected directly to the Jeti box through the top set of pins.  Brown is an outside pin and it is marked on both the ESC and ESC.  When you want to program the timer you just match the brown pins on the bottom set of pins on the timer connected to the Jeti box.  If you get it right the Jeti will display "C/L TIMER".  I found this to be a real PIA in trimming if the timer is mounted inside the fuselage.  The ESC really only takes one, maybe two programming sessions so leaving it connected to the timer full time later is not a problem.  At a minimum, you need to have a patch cable for the Jeti to plug into the ESC II pins on the timer because getting to them is a royal PIA.
I put a Jeti box port on the side of my plane and use a toggle slider switch to switch the Jeti from the ESC to the timer.  Really great at the field the just plug the box into the side of the plane instead of having to open a hatch and dig out a patch cable then close it all up again.  It is really complicated with a twin which shares the Jeti port with ESC II.  That is where the switch really shines.
Bottom line - ESC/BEC on top 3 pins, timer on bottom three.
Steve Dwyer
Ken,
Ok first question is where and how to mount the yellow wrapped accelerometer coming off the Timer? Refer to photo #1. Which direction must the arrow point and does it matter if it's mounted on a vertical or horizontal surface?
Next question: You are saying just plug in the Spin BEC cable to the top set of pins on the timer. There are two cables coming off the Spin ESC, one has a RED connector and the other is BLACK. Which cable is connected to the top of the timer?
To program the ESC you are saying disconnect this lead from the timer and connect it to the TOP set of pins on the Jeti Box. This is different in the video where he connects to the bottom set of pins on the side of the box being careful the three colors are configured correctly with the brown on top and the orange on the bottom. The video also uses the Red connector lead to configure the ESC and ignores the black.
To Program the Timer you are connecting to the bottom set of pins on the timer. Refer to the photo # 2, there are three sets of pins, to be sure are we connecting to the bottom or mid set of pins? And the video again is connecting to the bottom set of pins on the box not the top? Photo # 4 shows the red and black connectors on the ESC.
Phot #4 shows the slider switch on the ESC you are referring to for making connections during programming.
I only refer to the video as a reference, it leaves a number of questions and lacks clarity. Did you receive a wiring diagram for these different steps for programing and final set up, nothing came with my equipment.
Fred Underwood
#3
This might be helpful.  Fiorotti Timer
http://www.cltimer.com/wa_files/CL_20Timer_20v6_20EN.pdf
You can/should leave a lead attached to the Jeti Box labeled pins of the timer.  Your ESC will attaach to the ESC 1 pins. You can use a standard 4 cell pack with appropriate plug to plug intlo the timer and program the timer without use of a flight pack.  You can also program the ESC from the connection with the 4 cell pack without hooking up a flight pack.  4 cell not to exceed 5.5 volts, not 6 volts hot off of a full charge. I use the 4 cell pack to change parameters in the field instead of hooking up a flight pack, just my preference.  As the picture shows in the link above, the timer plugs into the Jeti Box on what I call the bottom port and the 4 cell pack on the upper port.
The Accelerometer should always have the wiring pointing at the nose of the airplane.  Rogerio originally suggested putting the Acc in the bellcrank area, but I have seen them work fine from a few inches behind the bellcrank to in front, in the battery compartment.  Mount flat in the same plane as the wing and it can be either side up, you need to tell the timer which way in the Jeti programming.
Fred
352575
Steve Dwyer
Fred,
Thanks for the help, this is what I needed.
Steve Dwyer
Quote from: Ken Culbertson on March 25, 2026, 09:37:29 AMI put a Jeti box port on the side of my plane and use a toggle slider switch to switch the Jeti from the ESC to the timer.  Really great at the field the just plug the box into the side of the plane instead of having to open a hatch and dig out a patch cable then close it all up again.
Ken,
This is a good idea! What kind of port are u\you using for this low voltage three pin connection?
Fred Underwood
#7
What are you putting the Fiorotti timer in.  What space do you have?  I leave a servo lead on the timer pins that go to the Jeti Box, and a lead on the timer pins that go to the ESC (between the ESC lead and the timer).  Then I can just hook up to the leads and don't have to try to find the pins on the timer that are buried.  Ken takes it a step farther and brings the lead out to the fuse side.  If I want to change the ESC settings, I uncouple the ESC lead from the servo extension and don't have to pull the ESC lead off of the timer.
Fred
352575
Ken Culbertson
What Fred is telling you is 100% correct.  I only do it for simplicity and the cool factor.  When I am in 2min trim mode it is just so easy to just plug in the box, change the settings and get back up.  I do what Fred does for the ESC.  I can't remember changing a setting on one after basic trim.
Fred Underwood
I "interogate" the ESC at times.  Look at the temperature and then know that it is adequately cooled.  You can find Max rpm in the flight and actual cutoff voltage and a few things if interested.  If you turn off the timer accelerations for a moment then run the plane while holding it still (say 20 - 30 seconds), then you can see the Max "flight" rpm and tell about where you actually have Set rpm.  Or if all is working, you can just ignore all of that :).
Creative Creative x 1 View List
Fred
352575
Steve Dwyer
