  • June 15, 2025, 09:04:19 PM
Author Topic: Prop for my Cobra 2826/10  (Read 2253 times)
Offline John Rist
« on: July 22, 2017, 09:05:07 PM »
I am setting up a Cobra 2826/10 on my Sakitumi-E.  Looking at the Cobra web sight they list max continuous power at 660W.
I started out with an APC 11 x 5.5 EP.  KR timer set at 9200 rpm.  Static amp draw was 19A. Recharge from a 4 minute flight was 1183 mah on a 2800 mah pack.
Next I tried a APC 12 x 6 EP cut down to a 11 x 6 EP. RPM still set at 9200 rpm.  Static amp draw was 25 amps and recharge from a 4 minute flight was 1595 mah on a 2800 mah pack.
Tonight on my work bench I tried a APC 12 x 6 EP without cutting it down. Static amp draw was 30 amps at 15 volts.  So input power was 450W, well below the max 660W rating of the 2826 cobra.
Looking at Cobra's prop chart they say that the 12 x 6 EP amp draw will be 47 amps @ 14.8 volts yielding 695W.  They also state RPMs will be 9,720.  This would be in excess of the 660W max power allowed.
I guess my question is does all this sound reasonable.  Should reducing the RPM from 9720 to 9200 drop the amp draw from 47 amps to 30 amps.  If so it appears OK to use the APC 12 x 6 EP.  If lap times are to fast I can drop the RPM.
By the way I have the time set at 4 minutes because, right now, I am trying to learn the beginner's stunt pattern and 4 minutes is plenty.
Online Crist Rigotti
Re: Prop for my Cobra 2826/10
« Reply #1 on: July 22, 2017, 09:28:34 PM »
I use an APC 13 x 5.5EP cut down to 12 inches.
Shouldn't run your flight prop on the ground for 4 minutes.  It could overload your system.
Offline John Rist
« Reply #2 on: July 22, 2017, 09:41:47 PM »
True.  I never run on the ground more than 30 to 60 seconds.  y1
« Reply #3 on: July 23, 2017, 10:42:50 AM »
IGNORE static draw numbers, they are of absolutely no use.  Prop selection is determined by the airplane, it will tell you when it is "happy".  The motor just has to be big enough (or a little bigger) to do the job.
Any of the props you listed should work and I would expect the Cobra to work well with any of them.  I suggest just pick one, adjust the RPM to get to a good usable airspeed and fly it.  Then change props, reset speed, etc.  When you get what you like THEN measure how much battery power you are using.  Take the next prop in line and repeat the process.  Fly in different conditions (windy, calm, hot/muggy, cool/clear etc) and see which one(s) work best.
If I was a betting man I would bet the 11x5.5 will be the best.  The 6" pitch props might use a little less power but be not as good in the wind.  The 12" prop might cause your corners to open up, but in the Beginner pattern that is not much of a concern...
Offline TDM
« Reply #4 on: August 08, 2017, 10:38:34 AM »
Motor Amp draw depends on the load you put on the motor. Load comes from RPM and the prop you use. More RPM load goes up less RPM load goes down (with it so the battery consumption as you already noticed from your test).
Props load the motor in two ways.
1: Mechanical load that comes from the mass of the prop ( kind of like a baseball bat: imagine each prop blade separate like a baseball bat you try swing, the heavier the bat the harder it is to swing). So a light prop will load the motor less than a heavier prop. Long story short use the lightest prop you can find that can handle the Rpm you are shooting for.
2: Aerodynamic load (drag from the aerodynamic forces that come from the blade moving through the air) Less pitch will load less than a higher pitch props. If you have two props with same pitch the prop with better airfoil and lift distribution will load the motor less than the crude prop.
What do you need in stunt is acceleration out of a corner (here a Low pitch high RPM is King) and lap time to maintain the speed so it stays on the lines. For Power conservation you want a high pitch and low diameter for thrust you. I would try any prop in the 4-6pitch and vary the Rpm (9600 for 6 pitch to 10500 for a 4 pitch) to achieve the lap time you are shooting for (perhaps in the 5.1-5.3s) and check the power consumption.
And here I go saying just about the same thing Denis said.
« Reply #5 on: August 08, 2017, 01:08:11 PM »
Well, no.  Once the prop is at a constant RPM, there is no load on the motor to keep rotating it.  Flywheels keep going, don't they?  APC props are as heavy as they get, but are also usually quite efficient.  The mass property of props that is the most interest to us is moment of inertia, which causes a yawing moment proportional to airplane pitch rate (mistakenly, I think, called "precession" by stunt fliers).  That's why many of us use light, hollow props.
Offline Target
  • C/L Addict
« Reply #6 on: August 08, 2017, 08:57:54 PM »
Don't forget to try the Xoar wood props.
So far, for their light weight/reasonable cost, they seem about the best value to me, and have worked well for both glow and e power.
R,
Target
Chris
AMA 5956
