  • July 11, 2025, 09:23:14 PM
Author Topic: Big electrified C/L'ers  (Read 2697 times)
Offline Jim Howell
« on: November 20, 2012, 05:33:49 PM »
Okay folks,
I think I've seen reference to C/L models of upwards of 700 square inch area.  Has anyone built and electrified anything "Really Big"?  If so, can you pass on anything about your experience?
TIA,
Jim Howell
Huntsville, AL
Jim Howell
Huntsville, AL  AMA 545805
Offline James Strickland
Re: Big electrified C/L'ers
« Reply #1 on: November 20, 2012, 06:19:52 PM »
Hi,
I haven't personally, but there are quite a few models flying that are right at 700 in.2
Offline bob whitney
« Reply #2 on: November 22, 2012, 10:33:03 PM »
i am flying a 1974 Scorpio which has over 700 sq in's   using a carbon LH 12 x 6 after some help trimming it by the Smith brothers it has become a fun plane to fly
rad racer
Offline John Hammonds
« Reply #3 on: November 23, 2012, 01:51:39 AM »
I can't offer any real world examples yet but I'm currently building a Coasby Taurus. I think it's around 67" span. Not sure of the wing area but it must be "Up there". Flight report hopefully early 2013. Any thoughts on what to power this beast with gratefully received.
TTFN
John.
BMFA 165249
« Reply #4 on: November 23, 2012, 12:35:54 PM »
Paul Walker was flying a 750 square inch Impact a couple of years ago that was electric.
Offline Dennis Saydak
« Reply #5 on: November 23, 2012, 05:46:01 PM »
I recall someone built a 1/3 scale SIG C/L Spacewalker electric powered model. I don't recall who it was for certain but it might have been Mike Gretz? I do have the kit and I'm thinking .................. ;D
Offline robert harness
« Reply #6 on: December 05, 2012, 09:00:55 PM »
Hi Jim;       The  two-bits twin that I posted last week is a 72" wing span with 800 sq ins.   At the 90 oz gas engine weight it needed the area...At the 76 oz elect. weight It could be smaller...But than it wouldn't be classic legal.  Just having fun  Bob Harness    ;)
Offline Andrew Borgogna
  • Andy
« Reply #7 on: December 06, 2012, 11:06:34 AM »
As part of my RSM electric power system testing I took the LA .65 off my Top Flite Score and replaced it with an electric motor.  This plane weighed just over five pounds on gas and about the same on electric.  The electric motor weighed a lot less than the gas engine and muffler, but the battery was heavier than the full 12 ounce fuel tank but it was about a wash in the end.
The plane flew great, I even used the same gas prop from the .65 and except for the sound the performance was as good or better.  I know in the R/C world they are using electric in 1/3 scale planes with great success.
Andy
Andrew B. Borgogna
Offline Juan Carlos Pesce
« Reply #8 on: December 06, 2012, 11:51:08 AM »
Hi Andy,
Please. Can you show pictures of the installation on the Score?
Thanks in advance
Juan Carlos Pesce
Buenos Aires
ARGENTINA
Offline Sina Goudarzi
« Reply #9 on: December 08, 2012, 06:08:14 PM »
Here are some info and images of the plane I am currently flying.
Tweener Design by Jose Modesto
WS: 64.5  equal panels
WA: 745
Weight: 64 oz
Stab & Elev. Impact, area: 164
Nose @ 11'', Tail @ 19"
Power Package
eFlite Power 32
Phoenix 60
FM9 Hubin Timer
Sky Lipo 3000 5c
13x5.5 apc e.pusher
Construction
Complete composite technology Wing, fuse and stab.
Wing has foam insert. no ribs, One hollow tube. There is only two half ribs for LG
Carbon fiber re-enforcement for wing tips and nose area (nose from inside)
Others
Lines 65 eye to eye
Kaz Handle 8.5 cm
Lap time 5.3
This is a Big Jim Tweener air foil (High aspect), Impact fuse, stab and Elev.
Very nice stunter, responsive, tight corners, nice line tension every where, blast to fly.
Special Thanks to:
Jose Modesto, for his teaching, his support, his knowledge and sharing, his coaching, his innovative approach to building.
William DeMauro, for sharing his expertise in electrical power system.
« Last Edit: December 08, 2012, 10:05:59 PM by Sina Goudarzi »
Sina
Offline Jim Howell
« Reply #10 on: December 15, 2012, 08:06:45 PM »
Thanks, guys, for all the info and taking the time to respond.
I've been on travel for a couple of weeks and away from the forum so I'm really behind the 8-ball on my "Thank you!" shout out.  Sounds like size isn't too much of a problem for E-C/L.
Jim Howell
Jim Howell
  • Andy
« Reply #11 on: December 16, 2012, 10:27:59 AM »
Juan Carlos
I wish I could provide a picture but I didn't take any.  It was just a short term project to test the motor for Eric Rule at RSM.  But what I did was very simple.  If you are familiar with the Score, here is what I did.  I removed the gas engine and the bolt on motor mounts.  I use the rear mounting cross on the electric motor and just bolted it to the firewall, very simple.  I don't think I would recommend this unless you reinforce the firewall with some fiberglass or carbon fiber.  Since it was a test setup I put the electronics where the fuel tank went and mounted the battery under the fuel tank compartment.  To my supprise the CG came out very close to where it was with the gas engine.  I had a very heavy LA .65 prior to the electric setup and the electric motor plus electronics and battery were about equal.
Any questions you can email me.
Andy
Andrew B. Borgogna
