  • July 11, 2025, 11:56:24 AM
Author Topic: Battery storage  (Read 969 times)
Online Larry Wong
Battery storage
« on: October 08, 2012, 02:26:20 PM »
What is the rule of thumb on battery cell difference that it's time to dump it? I been getting batteries that show full charge but will not finish the pattern , the voltage on these one cell will be much lower than the rest. (some of the batteries are almost 3-4  years old.
Larry
Offline William DeMauro
Re: Battery storage
« Reply #1 on: October 08, 2012, 06:43:48 PM »
Larry,
 The fully charged voltage of a battery, while important, does not mean as much to us as a batteries ability to hold a given voltage under load. If your batteries were stored fully charged. for any period of time during the time that you had them, they were more than likely ruined at that point. I have not lost a single lipo in more than a year and a half. A few of my $32 4 cell 3800's have more than 64 cycles on them and they are still strong. I now charge the same day I plan to fly and I discharge any unused batteries the same day. I am convinced that a good top end charger is worth every penny!!!! Most of you that know me, know that I have experimented with lots of budget stuff, Some of which has worked out well and some which hasn't. Budget chargers just DON'T CUT IT!!!! A charger without a discharge and Storage mode just isn't worth it even if free!!! You will pay for it in ruined batteries many times over!!!! I wrote the following in another post recently but its worth repeating.
 There is ton of info on RCGroups.com on lipo battery care Read up on the research by a guy called EVERYDAYFLYER he is all over RCGroups and is considered the top expert on lipos.To give you a summery of his work and what has been working for me. Lipos should never ever be stored fully charged even 1 day can hurt them. Most chargers have a storage mode that takes the batteries to the proper level.. 50-60% is considered fine. If the lipo isn't going to be used for a few weeks or you cant fly in the winter then it good to put it in the refrigerator. I put mine in a doubled freezer bag squeezing as much air out as possible. NEVER FREEZE THEM!!!. Some people will argue that its OK to store them in the fridge fully charged for a few days. I kind of disagree with that as they still need a 24 hour warm up period before you use them. If they are in storage mode and in the fridge they also need 24 hour warm up period before you charge them. I have been using this program since last year and haven't lost one battery yet. I have budget batteries with over 50 cycles on them and they still are as strong as new. Of course your milage may vary. All the batteries that I did not have on this program have failed.
  On another note, I know that the next thing that will be asked is."How come it takes so long for my charger to discharge the batteries?". Well most budget chargers do not have a very high discharge rate. I did the whole budget charger thing so I know. I highly recommend a good charger like the I-charger 306B or the powerlab 6 or 8. YES they are expensive!! but you will make it up in saved batteries many times over. If you want to use a lower priced charger then get yourself a charger that is a minimum of 200 watts output. Most of those have a decent discharge rate even if a bit slow.
AMA 98010
Re: Battery storage
« Reply #2 on: October 09, 2012, 01:48:24 AM »
While in storage mode it is NOT critical to have the individual cells perfectly balanced. They all should be close. I actually don't know of any charger that balances the individual cells while putting the batteries in storage. The batteries should be balanced when fully charged. Again there is plenty of info on this over on rcgroups.com.
AMA 98010
Offline John Cralley
Re: Battery storage
« Reply #3 on: October 09, 2012, 10:52:55 AM »
FWIW my Thunder T610 charger appears to balance when discharging in storage mode. The discharge starts at around 1.5 amps and then tails off to gradually settle on 15.20 volts for a 4C battery. Maybe it is not balancing but it sure takes a while to be "happy" at the final voltage.
John Cralley
AMA 52183
Central Illinois
Offline Frank Imbriaco
Re: Battery storage
« Reply #4 on: October 11, 2012, 02:43:12 PM »
Ditto TP 820CD
