  • June 20, 2025, 06:04:36 PM
Author Topic: Mini-stunt monoplane for Cobra C2808-22  (Read 1495 times)
Offline Matt Piatkowski
« on: May 27, 2015, 04:43:02 AM »
Hello,
This motor on APC 9x4.5, with 3S LiPo delivers 1184 grams ( 41.76 oz) of static thrust @21.4 Amps., delivering 237.6 Watts ( please refer to the data available on
www.cobramotorsusa.com).
I would like to build a mini-stunt monoplane for this motor and wonder how to size it.
People fly 1/2 A C/L models (~35" wing span, 20% wing thickness, 230 sq.in area, 21" profile fuselage, no flaps ) using 0.049-0.061 engines.
My initial calculations show that Cobra C2808-22, in the configuration shown above, is equivalent to 0.12 glow engine and is, therefore, two times more powerful than 0.061 glow engine.
I wonder if a model having 40" wing span having 300 sq.in area and 26" fuselage length will fly ok using my Cobra?
Taking only the static thrust ( 1184 grams) as the main factor, it seems it will fly very well.
The entire electric installation (motor, ESC, governor, prop and 3S 1800 20C battery) is ca. 400 grams (14 oz ) and I can build the complete, finished structure weighting 350 grams (12.3 oz.)
Himax published data show that, for example, HC3510 Outrunner is more or less equivalent to 0.15 glow, has 250W max power and can fly the models weighting 24-32 oz in 3D R/C flight. The parasitic drag of lines will consume about 1/6 of the available power in C/L flight but I believe my 750 grams (26-27 oz) RFT mini-stunt should fly ok. on, say, 45-50' long and thin ( 0.010") lines.
I would be grateful for your comments, suggestions and friendly critique.
Thank you,
Matt
Offline CircuitFlyer
    • www.circuitflyer.com
Re: Mini-stunt monoplane for Cobra C2808-22
« Reply #1 on: May 27, 2015, 09:00:05 PM »
Hey Matt,
From personal experience (and after reading numerous posts on here from much more knowledgeable folks than myself) I would say the C2808-22 would be a little undersize for the size of aircraft you describe.  You can fly a Flight Streak or Ringmaster on a .15 glow but you probably won't like it.  (45 ft lines wouldn't be much fun either).  Parasitic drag from the lines is part of the equation, keeping them tight is another.  The rule of thumb is 11watts of peak power/oz of airplane.  26 oz airplane = 286 watts.  More motor, more weight.  26.5 oz = 291 Watts
1800 3S battery is also a little low and may limit your flight time from what you prefer.  More battery, more weight.  Now your up to 27.5 oz = 303 Watts.
You may want to consider the Cobra 2814-12 with 2400 mAh 3S batteries
The static trust on the APC 9x4.5 is impressive but only proves it will accelerate very quickly on takeoff.  After it's in the air, you may not have the lap time (line tension) you would like.  More pitch would be better but, final prop selection only comes from test flying.  I'm partial to the APC 9x6EP myself.
Here is a post I'm sure you would like: http://stunthanger.com/smf/index.php/topic,6347.0.html
Paul Emmerson
Offline Target
  • C/L Addict
« Reply #2 on: June 09, 2015, 09:24:43 PM »
This 3S 2100 battery weights 5.3oz. http://www.atlantahobby.com/Store/pc/3-Cell-2100mAh-3S-11-1V-ProLite-+-Power-25C-LiPo-1205p19261.htm
That should help with your equation. I think your plan might be worth a try.
If the motor turns out to be too small, just put on/in something with a bit more poop.
Good luck,
Chris
Chris
AMA 5956
