  • July 28, 2025, 08:24:08 PM
Author Topic: battery draw at higher voltage?  (Read 6717 times)
Online bob branch
« on: February 01, 2007, 07:11:11 PM »
I'd like to pose a question. Given the same motor, esc, prop, plane, timer, what affect will result on going from a 3 to a 4 cell lipo pack on current draw and on mah taken out of the battery for a flight?
bob branch
Alan Hahn
Re: battery draw at higher voltage?
« Reply #1 on: February 01, 2007, 07:54:39 PM »
If you simply added an extra identical cell in series, then you would draw more current, and the total run time would decrease. Adding the extra cell would not increase the mAh of the total battery. Yes there is more energy (=Volts*mAh) in a 4s than a 3s (for the same size individual cell), but you burn it faster.
Online bob branch
« Reply #2 on: February 02, 2007, 06:37:43 AM »
So basically I could reprop, reprogram the esc by going to the govener mode and programing power setting in accord with the power needed by the plane for the maneuvers ie a lower setting than 100% that the plane is currently flying and not quite having the guts for overhead maneuvers in bigger wind and these things could reduce the battery draw?
bob branch
Alan Hahn
« Reply #3 on: February 02, 2007, 12:05:29 PM »
Yes that is correct. The extra cell would give you that little extra burst when you need it.
Offline Dean Pappas
« Reply #4 on: February 02, 2007, 12:21:24 PM »
Hi Bob,
Well yes ... but this presupposes that you are going to prop and set the RPM in the right neighborhood. How comfortable are you with e-power in the first place? Upping the voltage 25% can have a dramatic effect (way more than 25%) on the current draw, depending upon a whole pile of factors including the motor specs.
Let me suggest this: gather the 3 important specs for your motor (Kv in RPM/V, Ri in milli-ohms, and Io or the no load current) and go to the Aveox website. Under UAV propulsion (hey that's us!) find the virtual testbench.
Now let's make some assumptions: Let's say you have a ~ 4 A-H battery. That means to fly comfortably, but with as much power as practical, for ~ 6 minutes you will prop to 30 A. That drains about 3/4 of the battery capacity. Put your motor constants in, and you will have to guess at the number of nickel cells that equate to 4 lithium. Depending on the current, it will work out to about 14 cells. The Aveox virtual testbench accepts fractions of cells (e.g. 14.7 cells). We all seem to fly within a few percent of 55MPH, so work out a prop diameter and pitch that draws 30A and flies at 55 MPH at the correct motor voltage (about 14.4 for 4S) .  Feel free to use oddball pitches like 4.35 and non-ieven inch diameters. Note the diameter, RPM, and pitch.
Now add 10 or 20% in pitch, to get the prop you will really use. (find the next standard pitch up, or two) Then take that % increase in pitch and take the same percentage off the RPM the simulator showed, and set the Governor to that RPM. That will keep 55 MPH. The average current draw should be very close to 30A. With the higher pitch put into the sim, it will show the maximum current BUMP you could possibly get from the ESC in a vertical climb. You may not get that much because the ESC will only do what it has to to maintain RPM, but you can see how much "headroom" is available for grunting through high drag and climbs.
The governor is not the same as throttling back: your controller came in normal throttle mode, and you will have to change it to heli-governor mode.
I hope I helped, but yell if I just made a mess.
Dean Pappas
Dean Pappas
Alan Hahn
« Reply #5 on: February 02, 2007, 01:42:30 PM »
Of course with a timer like the JMP-2, you can just adjust the initial throttle to give you the rpm you want, as long as the battery voltage, current capability and motor heat shedding capability is there.
I read Bob's post to mean that the 3 cell lipo is "just adequate" to give him the flight characteristics he wants. In that case adding the 4th cell and adjusting the throttle control on the timer should be just fine--as long as the additional weight doesn't kill the flying characteristics. One final caveat is that the ESC has a high enough rep rate to make the throttling efficient (L/R of the motor large compared to the repetition period). This at least means you aren't wasting power (into heating up the motor) at low throttle.
Online bob branch
« Reply #6 on: February 02, 2007, 06:41:04 PM »
Dean
Ok, I have to go there and play with the program some to see what comes up. One question though, how do you account for different prop charactaristics at the same size and pitch. For instance the difference between a Zinger wood sport prop with its narrow thin blade and a zinger pro wood prop with its much larger blade?  Or does this program just really get you to the point you have to go fly and see if the prop is taking the load out of the battery you expect?
Bob
Online bob branch
« Reply #7 on: February 02, 2007, 06:50:50 PM »
btw, I am flying an Axi 2826/10 with a CC phoenix 45 controller in a smoothie right now. The plane currently has 3700mah polyquest 3 cell lipos and I am going to be trying 4000mah polyquest 4 cell lipo. Currently the plane is flying with an 11X6 zinger wood sport prop. I bought it from Frank Carlisle and want to go on from there. He has the Zigras timer and is flying at 100% on the esc in its normal mode. I am planning on flying it this year and may experiment with the setup in a Vector 40 arf that is a spare on the rack for this year. So I'm just getting started with CL electric. I have flown RC electric for about 3 years. Alot of indoor rc and some outdoor stuff up to about 44 inch wingspan planes. Electric is my winter mode RC flying and I always take one or 2 to the field when I fly my RC glo planes in the summer just for some variety. ITs a hoot to fly real light indoor electrics outdoors in big wind (25 to 35 mph). Always amazes people. Obviously the CL application is different but at least I'm accustomed to the pieces somewhat.
Bob
Alan Hahn
« Reply #8 on: February 03, 2007, 09:22:47 AM »
Bob,
I would recommend the EagleTree Data recorder which would tell you what is actually going on during the flight. What matters to the plane (ignoring weight etc.) is thrust. I believe that there are a lot of props that can supply similar thrust, but what may vary a lot is the power draw from the battery. Since in electric, we can't be as energy wasteful as we can in a glow engine because that battery weighs so much and high current flows probably will shorten in life (=$ !).
So what I am saying is that working on the right prop is probably the best investment you can make! I would see if you can find some good electric props. They are a lot thinner than the glow versions since the electric power is so much smoother than that 1 kick per cycle (or 2 if you are four-stroking). I believe the thinner prop (I mean in cross-section, not necessarily blade width) will cut down the  battery  load.
On your Smoothie it probably is important to be conscious of the total weight. About the only thing you have to play with is battery weight at this stage --and maybe not even that. We are limited by the batteries we can buy--not like in glow where you can build your own tank to the exact size you want. However minimizing the current draw may give you longer life from those batteries.
Online bob branch
« Reply #9 on: February 03, 2007, 11:32:06 AM »
Alan
I'm familiar with Eagletree's stuff. It is being used onboard an RC speed plane project that I have done some aerodynamics for. Wonderful to get real world rpm and gps and airspeed data for the plane live at the transmitter. It has certainly killed off alot of myths that would have slowed down development. Course it brought up other issues, like the need for props to handle 22000 rpm from the OS.91DF that is driving the plane. The project is now doing testing with fa Bob Violett 1.08 DF motor. Anyway I digress. I was not aware of the much more economical electric flight data gathering unit. Very hice and not all that expensive either. Thanks for your input.
Bob
Online bob branch
« Reply #10 on: February 03, 2007, 11:49:17 AM »
Dean
What do we input in the Aevox computer for motor resistance for the AXI 28/26/10 and controler resistance for the Poenix 45?
Bob
