  • July 17, 2025, 08:42:09 AM
Author Topic: Battery Discharger and Field Charger with Lipoly Power Supply  (Read 25439 times)
Online Fred Underwood
Battery discharge is occasionally desirable, though batteries are usually flown down.  Weather, change of plans, battery break in and other reasons make a discharger useful.  Most chargers offer meager discharge capability with the Powerlab 8 offering about 4 amp, 100 watt capability.  Still, not much fun to condition and break in 4 - 6 batteries at that rate, or to come home with 4 fully charged batteries from a rain out.  There is also "regenerative discharge" on IChargers and Powerlab, but that implies lead acid battery ready to accept charge.  Hopefully we can share a few simple discharge ideas.
I had a few parts setting around including a 12 volt computer fan and shield screen and a few 25 watt resistors and decided to try to make a discharger.
Parts:
12 volt 120mm computer fan with screen
25 watt 20 or 27 ohm resistors
Miscellaneous solder, wiring, and battery connectors.
The copper bars energizing the resistor wires are just 14 gauge solid household wiring stripped and soldered.  The resistors are adhesed with silicone rubber to the screen.
Using 6 cells and about 24* volts gives about 1.2 amps/20 ohm parallel resistor loop and then about 28.8 watts/loop.  If you use 27 ohm, that is 0.89 amps/loop and about 21 watts/loop.  I had 3 of the 27 ohm resistors and wen to to Fry's. They were out of 27's and had 20's so 3 of the 27's were used and 4 of the 20's.  Calculated about (4*1.2) + (3*0.89) = 7.47 amps/hr or about 125 ma/minute.  Without a fan, the approximate 310F temperature max of the resistors will be exceeded and with a fan, still close.
The fan is 12 volt and 0.35 amps, so that gives about 40 ohms of resistance. A 10 ohm and 33 ohm resistor all in series will drop the voltage to about 12 and keep the fan happy. Of course that adds a bit of amp draw.
I run about 130 ma/minute or about 7.8 amp/hour, not quite 3C for break in of batteries.  I run 9 minutes to get just lower than storage voltage of the PL8 charger.  I am using batteries charged to about 4.16 volts and normally discharge to about 25%.  Obviously fully charged batteries would take another minute or so.  If I had a second screen to put on the fan, I might load a couple more resistors to up the load, but don't want to compromise airflow.
Considered adding a timer cutoff for the unit, available 24 volt systems fairly cheaply, as are low voltage cutoffs.  I didn't have either and most are Ebay China origin, and it works fine without if you don't leave it running.  In practice I never use it without carrying my smart phone with a timer set.  It would be easy to over discharge a battery, but the timer works for me so far.
If 5 cells, the resistance to control the fan is adequate, and if 4 cells, the 10 ohm is left out of the circuit.  And, yes the wattage will drop with voltage drop, so I might use more resistors for less cells and larger amp cells.
An enclosure of Formica was made about 7" long and a slide fit.  That helped airflow and shielded the hot resistors from touch.
I will say simple as it took longer to think about and obtain the resistors than constructing.  Not counting letting the silicone dry overnight.
*The 24 volts is an average approximation as the voltage is falling along with wattage.
« Last Edit: September 13, 2016, 01:59:19 PM by Fred Underwood »
Fred
352575
Offline William DeMauro
Re: Battery Discharger
« Reply #1 on: May 12, 2016, 08:10:41 PM »
I like the idea, but having that auto cut off at the desired storage voltage level would really be nice. I was looking through RC Groups and there are some threads that address that problem. I saw this one http://www.rcgroups.com/forums/showthread.php?t=2406395 . You may be able to blend yours with this to end up with an exact cut off. A few years ago I saw a thread there that used a relay to cut the voltage off . This might be it http://www.rcgroups.com/forums/showthread.php?t=725572 . In any case  i think some sort of shut off would be a good upgrade and a nice safety feature just in case.
AMA 98010
« Reply #2 on: May 12, 2016, 09:25:42 PM »
I agree that the low voltage cutoff would be nice.  I tried to find a simple wire in board.
http://www.ebay.com/itm/Low-Voltage-Disconnect-Module-LVD-24V-10A-Protect-Prolong-Battery-Life-/131791231226?_trksid=p2141725.m3641.l6368
Selectable and close for 6 cells, but not exactly as needed.
Several circuit diagrams were found by Google search and the RC groups as you noted.  None seem "simple."
It seems like the ideal would be to run the discharge through the charger with the resistance discharge board perhaps in series taking the load, and the charger then able to break the circuit.  I am not sure quite how to do that or if feasible.
Along this line, but I haven't thought it through, on page 18, expanding the discharge mode,
https://www.progressiverc.com/media/iCharger%20206B%20Manual.pdf
« Last Edit: May 13, 2016, 05:51:31 PM by Fred Underwood »
Fred
352575
« Reply #3 on: May 12, 2016, 10:33:18 PM »
what about using an "old" undersized ESC , a motor and prop, set the cut off voltage in the ESC cut off for Storage voltage, then you can swap props for a battery break in setup at lower amps, or a steeper prop higher draw for simple discharge if you dont fly ,,
It is still  a one battery at a time proposition, but it would be a set and forget  setup basically,,
I do not know if the cut of voltage in the esc can actually be set hi enough, I need to ramp up my castle link and see,, I just have not gotten there. and I do have a couple Turnigy motors in my drawer that would be great candidates for this.
« Reply #4 on: May 13, 2016, 12:59:23 AM »
Bathroom fan timer and an automotive relay of sufficient current carrying capacity.  Turn on the relay with the timer and discharge the batteries using the relay.
Turn the dial to the desired time, discharger comes on.  When the timer goes off, the discharger goes off.
For a 24 volt system, figure out the coil current of the relay and use and appropriate dropping resistor, or find a 24-volt truck relay -- I'd use the dropping resistor.
And fix it if it shows any sign of wonkiness that might lead to it being stuck on -- that would kill a pack dead.
« Reply #5 on: May 13, 2016, 06:22:12 PM »
I don't know if the cut of voltage in the esc can actually be set hi enough, I need to ramp up my castle link and see,, I just have not gotten there. and I do have a couple Turnigy motors in my drawer that would be great candidates for this.
Mark, you might make that somewhat work, but you have an exposed prop and a lot of air moving to keep the esc and motor cool.  I can't remember for sure, but 3.5v/cell may be the highest cutoff, and that may be a bit low.  Those cutoffs obviously aren't make for normal battery usage/cycling or discharging, but flying.  3.5v with a 20+ amp load would be different than at 8 - 10 amps where the actual discharge may be too deep.
William and Tim
It seems that the iCharger line has an external load feature in addition to the regenerative feature.  I don't want to keep lead acid batteries around to maintain and discharge into, but the external resistance will expand capabilities. Again, here is a brief description.
I had to try it, so hooked up my resistance load above, clipped off the fan power supply and got 12v from the power supply to power it directly.  The resistance load was placed in series with the iCharger as shown and then the charger discharged the added series resistance with the user set cutoff and stopped.  The cooling fan of the resistance load is powered with 12v from the supply of the charger so continues to cool the hot resistors until the charger and fan are disconnected.  If the battery is replaced with a parallel board and appropriate batteries, the whole load will discharge and shut off.  Since the load is fixed, the time becomes about 10 minutes/battery but you don't have to do the swap.  All similar for lesser cell packs, but the current and wattage will be lower/slower.  More resistors would be your friend.
The stand alone unit is nice at times.  I can use it in the house with minimal fan noise and attend to it while I am on the forum. Not quite so fun with the charging unit and power supply running, but they work well in the garage. With a couple of alligators clips for the fan power supply the change over is basically 2 clips, best of both.
Of course stand alone cutoffs as proposed would also solve those problems, but the ability to cutoff voltage by a single low cell seems beneficial, if you have the iCharger and I believe the Reaktor clone.
« Last Edit: May 14, 2016, 10:47:12 AM by Fred Underwood »
Fred
352575
« Reply #6 on: May 15, 2016, 10:33:53 AM »
I just use the charger. Hmmm....
« Reply #7 on: May 15, 2016, 11:48:28 AM »
well until I get my charging system ramped up so I can minimize my charging time ( it takes me roughly four hours to charge all of my packs to fly) I have currently two charging systems and charging on balance at 1.5C I generally take right around 4 hours to charge my 8 packs to fly. SO that requires charging the night before I fly in order to be prepared for after work. So for example, I charged my packs friday night so I could fly saturday as the weather was projected to be good,, it was not, so now I have 8 packs charged to flying capacity. Discharging thorugh my charger is very cumbersome as its a very slow process. Fred, your discharger sounds viable but requires babysitting right? So my thought using an ESC seemed initially to be a more viable less painfull process. HOwever if the cut off in the ESC is ony 3.5 then that negates any benefit. I suppose that I could do a rough calculation for time to get it close then roll it over onto the charger to finish it off. I just know using my charging system as is I will take 5 or 6 hours to discharge them.
What the real solution is for me would be to have a better charging set up so that I can avoid the 4 hour charge , then I could just charge right before going flying..
now here I am SUnday hoping I was going to be able to fly out my packs ,,,,, that I charged Friday night,,,, and its raining,, so the decision, do I discharge or ho[pe for monday
« Reply #8 on: May 15, 2016, 11:56:52 AM »
Discharge them in parallel?  It'll still take forever, but it could be fairly unattended.
« Reply #9 on: May 16, 2016, 11:24:27 AM »
Takes me about a half hour (more or less) to charge 4 packs. 6 takes almost an hour so I usually do 4 then 2. About 45 minutes to bring them to storage if they are fully charged.
I use a PRC 600 power supply, an ICharger 306b and a standard balance board. Weird that. I charge at about 1.4c on average and discharge at the same rate.
« Reply #10 on: May 16, 2016, 06:26:38 PM »
Randy, just a little curious about "45 minutes to storage from full charge."  How many in 45 minutes?  I ask because the discharge capacity is listed at 80 watts, or for a 5 cell pack discharging with some load and sitting at about 19 volts average while discharging (3.8v/cell), the discharge capacity is then about 80/19 or 4.2 amps.  IIRC, the storage on iCharger is about 1100 - 1200 ma down from full charge on 5 cell 2700 Zippy packs, so 4 batteries on a parallel board could/should go over 1 hr as they would give up 4.4 - 4.8 amps.  Of course that assumes good capacity cells and that the discharge rate is as listed. Perhaps it does better?
Fred
352575
« Reply #11 on: May 16, 2016, 10:06:10 PM »
I got a chance to actually wire the system up with normal connections, not alligator clamps.  It works great with a parallel board and multiple batteries.  Soon to add a grill to the other side of the fan and 4 more resistors to get a bit more resistance, and a current draw of 10+.  Showing faintly, 7 amps.  I searched the RC forums as William suggested and found a couple of schematics for cut offs, but also found more information of using the iCharger to control the process, so went that way.  Seems very nice to set the cutoff voltage, not time.  With a little learning, the cutoff voltage can give a discharge to near storage.  I aim for just below storage charge, then the charger can easily come back up to storage.
Fred
352575
« Reply #12 on: May 16, 2016, 10:08:25 PM »
The connector to add the resistance into existing wiring in series
Fred
352575
« Reply #13 on: May 16, 2016, 10:09:37 PM »
Series connector set in place
Fred
352575
« Reply #14 on: May 16, 2016, 10:29:24 PM »
Thanks Fred, Interesting, I need to step up my charging game, I did manage to discharge my packs tonight, the hard way,, 7 flights,  D>K y1
« Reply #15 on: May 18, 2016, 02:40:17 PM »
Fred,
Well, last weekend I charged up 5 batteries, but the rain convinced me to fly only once. I put the 4 charged batteries on the system outlined and it took 48 minutes to discharge to storage (~3.8v per cell), 50% charge. Not sure but maybe the system is more efficient? No idea. Not really an electronics guy. Strangely, the one battery that I used (discharged to about 21%) took almost as long (36 minutes) to charge back up to storage. This is at about 1.4C for both operations.
« Reply #16 on: May 19, 2016, 11:46:28 AM »
Randy,
When I charge or discharge, I usually look at the amps/ma of input or output and % of charge at the beginning and end, if available.  The actual amps of input/output give a suggestion of battery capacity if you know beginning and ending % as well.  Without the amps in or out, the times don't make a lot of sense.  All of that said, your system seems to be working well.
Fred
Fred
352575
« Reply #17 on: May 19, 2016, 04:23:44 PM »
Sure, Fred. Smile. They are model airplanes.   ;D
« Reply #18 on: May 21, 2016, 04:38:18 PM »
Using the iCharger as a controller caused the iCharger to shut down as the number of resistors increased and approached a 12 amp load.  The i206b lists 20 amps, but does not seem to like the heat.  The Discharger unit works great as stand alone and uses about 190 - 200 ma/minute so about 6 minutes/6cell 2700mah pack from full to just below storage.  Also used with a parallel board and more packs.  The down side is that you have to set a timer and shut it off, but it is simple.  I may add the CellLog as below since I already use one in the field.
The CellLog8M has a switch feature that will activate at a set cell voltage and serve as a cutoff.  The cube relay, earlier suggested by Tim, controlled by the CellLog8 instead of a timer has been used by others with good results and is fairly easy to hook up.  If not a cube relay, then a DC-DC SSR can be used, also written up.  The last RCgroup thread below will lead there, thanks to William DeMauro for getting me started on the search.
The best way I found if starting from scratch and want more discharge than your charger supplies, or if you want to avoid the heat load to your charger is below.
A balancer/discharger for stand alone use is the RCMart 3-in1 balancer discharger.
http://www.myrcmart.com/rcx-3in1-battery-balancer-discharger-voltage-indicator-150w-discharging-p-4767.html
One unit gives about 4 amps discharge, and they can be paralleled giving 4, 8, or 12 amps of discharge as described below, "An effective variable load automatic LiPo discharger."
http://www.rcgroups.com/forums/showthread.php?t=2406395#post31524795
« Last Edit: May 22, 2016, 04:09:39 PM by Fred Underwood »
Fred
352575
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
« Reply #19 on: May 24, 2016, 03:35:08 PM »
Found in an electronics junk shop will serve to discharge my batteries quickly ..
Rogerio
« Reply #20 on: May 24, 2016, 09:36:09 PM »
Lucky you.  I didn't recommend resistors like that because of price.  A bargain price $49.99 used
http://www.ebay.com/itm/like/221923395778?lpid=82&chn=ps&ul_noapp=true
If you found it surplus/cheap, a good way to go.
For 5 cell at approximate 3.6v under load, 5 cell is 18v divide by 2 ohm is 9 amp and 162 watt.  A bit higher at first as the initial voltage is higher.
Fred
352575
« Reply #21 on: May 30, 2016, 05:18:20 PM »
I noticed another nice use for the discharger; testing for bad cells.  When discharging a battery with a cell checker on the JST plug, a weak cell becomes very apparent.  Much more so as the load increases.  When the load is about 4 amps on the PowerLab8 some cell to cell difference is noticeable, but much more so with increasing load.  The 12ish amps that I reach is about half of flight load, though flight load can go much higher in peaks.  Watching a cell get significantly lower than the rest gives an indication why the battery quits overhead from low voltage.  The old non-flyable packs are great for testing without wasting the good pack's cycles.
Fred
352575
Online Christoph Holtermann
« Reply #22 on: June 03, 2016, 03:01:37 AM »
Hi,
for those who are interested:
I also was in search for a light and simple solution to discharge batteries down to storage voltage during the WC in Perth in case I didn't use them on my flying day. Normal discharge currents of chargers are 1A only and then discharging takes too long.
I use 6s batteries btw. I discharge them on two H1 automotive headlamps connected in series. The full battery (6s) has 25,2 Volts and the design voltage of any automotive lamp is 12V, thus it was logic to use two in series.
You can discharge a full 6s battery down to storage voltage in approx. 15 minutes. That is a discharge power of approx. 100 Watt or approx. 4 Amps. You can monitor the battery voltage connecting a digital battery tester to the balance connector of the battery.
Pro's: it is a very cheap solution, discharge currents are approx. 2C only, so saves the battery
Con's: you need to monitor the discharge process as there is no automatic cut off at storage voltage and you may need to check whether automotive lamps can also be used to discharge 4s or 5s batteries. Also, you may need to wear sunglasses while monitoring the discharge process.
Sorry I have no picture available but try it. H1 or any other automotive headlamps (H7 or H4) don't cost anything.
Christoph
Online Igor Burger
« Reply #23 on: June 03, 2016, 05:27:26 AM »
Hmm ... somehow complicated, why you simply did not discharge to car accu? If it was full, you can simply switch on lights ... I had problems to keep car battery charged (as I charged for flight from car), you could discharge it to mine :-P
And to all: I think you take it too complicated, battery is singnificanly aging at full charge, means 4.10 to 4.2V ... if you discharge only fraction of capacity, you will limit it, yo not need discharge really half capacity if you do not store it for winter or so.
« Reply #24 on: June 03, 2016, 11:10:37 AM »
And to all: I think you take it too complicated, battery is significantly aging at full charge, means 4.10 to 4.2V ... if you discharge only fraction of capacity, you will limit it,...
That was my reasoning on the thread about charging for out of town contests - 80 - 85% charge.
The reason for the discharger is the first place was for "battery break in" as suggested by ThunderPower, and that was at 3 - 4C.  Discharge to "storage" is for the convenience of parallel charging multiple packs, a common starting voltage.  The used packs are charged up to storage and the unused can be at near storage in about 6 minutes at about 12 amps (2700 mah packs), then brought to storage. I believe that you are describing "regenerative discharge" to the car, and most chargers don't do that.  PowerLab, iCharger, and Reaktor are the ones that I recall.  You posted about having Reaktor clone of iCharger 306b as I remember.
Fred
352575
Online Igor Burger
« Reply #25 on: June 03, 2016, 01:44:08 PM »
Yes I mean regenerative discharge, and yes I have icharger, reaktor, also FMA and pulsar, only FMA does not do that, all others mentioned can do it.
Online David Hoover
« Reply #26 on: July 29, 2016, 08:34:05 AM »
I bought one of these and used it for the first time yesterday.  Works a treat and a whole lot faster than using my charger.  It's a little slow on the final finish as the shutoff point is approached so I then stop it and do the last bit on my charger which seems to accomplish that last little bit faster.  Perhaps the charger has more sophisticated hardware/software that allows a more rapid approach to the shutoff point without overshooting.
Best, Hoovie
« Reply #27 on: July 29, 2016, 10:39:38 AM »
This thread is a good read along with the RCMart 3-in1 balancer discharger.
They can be shipped with bulbs of 12 or 24V, and heat and repeated flexing of wires can be a problem.  Mounting the system can help, all in the thread, along with many other ideas.
Fred
352575
Online David Hoover
« Reply #28 on: July 29, 2016, 01:38:52 PM »
Fred, thanks for the link to the thread.
Best, Hoovie
Offline Ken Burdick
« Reply #29 on: July 30, 2016, 08:59:35 AM »
I haven't read all of the postings, but a bank of lightbulbs makes a great load. You would need to experiment with which ones to use but it's a low cost way to accurately discharge.
« Reply #30 on: July 30, 2016, 11:47:57 AM »
What's a nice boy like you doing in a place like this?
Offline Ken Burdick
« Reply #31 on: July 30, 2016, 12:17:26 PM »
was passin by with my Lark and blubbering Fox......I was wiping the castor oil off my arms when I read this.
Just carved a really nice threshold to go with the 100 yr old house in Kamloops. Fir that looks slightly golden with the Varethane on it.
« Reply #32 on: September 06, 2016, 09:33:19 PM »
Thanks for the information, guys.  I got a couple of the dischargers Fred mentioned and mounted them in a cookie tin.  The light bulbs are under the screen.  The blob to the left is a low-voltage monitor, https://www.amazon.com/gp/product/B003Y6E6IE/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 , $2.40 including shipping.  Based on the advice above, I set the dischargers to 4.0 volts and the monitor to 3.8 volts in case I forget to disconnect the batteries after they discharge.  If Igor is present, I'll discharge my batteries into his car battery.
I like Christoph's headlamp idea, too.  I usually fly until dark, so that would enable me to see to pick up my stuff.
« Reply #33 on: September 08, 2016, 03:12:23 PM »
Howard, discharge to 4 volts?  Just to take the top off until flying the next day, or are you storing at that voltage.  I like the set up, and it keeps the hot lamps away from skin.
Fred
352575
« Reply #34 on: September 08, 2016, 03:33:03 PM »
 Just to take the top off until flying the next day.
Online Igor Burger
« Reply #35 on: September 09, 2016, 01:43:32 AM »
And if Igor is not on place and if you are carefull (eg if you can specify the charge which has to be discharged), you can still discharge to another, empty battery  VD~ ... or simply charge from your full battery to another empty and problem solved  %^@
« Reply #36 on: September 09, 2016, 08:44:54 PM »
I thought about this for a while and am still not sure exactly what was meant.  To expand on what I think is meant, or add a thought, one could use the battery that is charged to power the charger to bring used batteries back to storage.  I could have an adapter to use the 6 cell pack as the power source for the charger and then use the charger to bring two 6s 2700 flown packs to storage and end up with all 3 at about storage.  The charger must accept greater than 12v input.
An example with simple calculations to clarify - Say 1800 mah used in a flight and about 600 mah to get a single pack back to storage, then I could bring 2 flown packs back to storage and at the same time remove about 1200 mah from the full pack leaving it at about storage.
Of course the voltage step up and inefficiencies could use a bit more than 1200 mah from the full power pack, but with a little experience the real numbers could be worked out.  As the usage approached 2100 mah, perhaps one power pack to one storage, but again, the numbers can be adjusted.
If a fully adjustable charger such as the FMA PowerLab 8, the storage endpoints could be adjusted for your actual battery use so that one full pack into 2 packs, parallel, to storage could make 3 packs with about matching voltage and say 40% instead of 50% storage charge.  Once the numbers are worked out, the system should run itself and shut off.  That might just be done while you pick up after yourself and load the car.  If on the same plane and electric system, battery usage and replacement should be fairly constant.  If the voltage numbers get fairly close, then the 3 packs are ready for parallel charge for the next outing, or parallel charging to the about 50% recommended value for long term storage.
Fred
352575
Offline schuang
« Reply #37 on: September 10, 2016, 10:41:02 AM »
It has been a while since this project started...
I call it "Charge Transfer" (QT) board.  The photo with two batteries connected is the latest revision (rev4).
The concept is simple: transfer the fully-charged battery (on the left side) to the one that has
been drained (on the right side) in a "controlled" and "efficient" manner.  Any cell of the discharged battery on
the right side reaches 3.85V, the charge stops (the right side green LED turned off); any cell of the fully-charged
bettery on the left down to 3.85V, the discharge stops (the left side green LED turned off).
You can also use high power resistor hook up to the right side to discharge a battery if no drained battery is available.
The QT board has been field-tested in Tucson flying field for few months now and will continue on rev5.
Sean
« Reply #38 on: September 10, 2016, 10:52:01 AM »
Great idea!
What transfer rate?  Will the system tolerate say 10 amps and serve as a new battery conditioner as well.  Same cell counts only each side, probably not since a resistor works?
I think that the concept above, using the charged battery as the power source for the charger is similar.  I can set a shut off for low battery on the power side giving similar safety.
Fred
352575
Offline schuang
« Reply #39 on: September 10, 2016, 12:13:21 PM »
Great idea!
Fred,
It's not intended for battery conditioner since you can do this on your charger more efficiently.
The board is fairly small so I've been putting it inside of the battery box and it will transfer charge automatically while driving home.  This way I don't need to lug around a charger on the field.  The rate is set to constant ~3 amps now for reasons...
Sean
« Reply #40 on: September 12, 2016, 10:01:17 PM »
The PowerLab 6 and 8, and the iChargers, Reaktors and a few others have Regenerative discharge, meant to allow the lipoly to discharge back into the power lead acid battery.  If the lead acid battery is full, headlamps or other resistance may be used to allow for some regenerative discharge.
The battery on the power side does not need a charging algorithm, nor does it have to be monitored.  If a full lipoly of adequate capacity is used as the charging battery, it may be discharged into depleted lipoly battery(s).  So a fully charged, unflown, lipoly may be discharged into flown lipoly(s) and the receiving batteries monitored as usual to control the process.
Needed is a charger capable of using a 24+V charging source, and an adapter for the lipoly to charger connection.  That adapter was easily made in my case from a male deans and the remainders of the original Zippy connectors as female donors, as below.  Also shown the system connected up and running, one lipoly for power into two lipolys in need of storage charge.
The power lipoly is also monitored, though not necessary once the process and proper numbers are worked out.  Perhaps not necessary, but desirable.  Howard's inexpensive monitor above could also be used to make sure the power battery is not overly discharged.
Fred
352575
« Reply #41 on: September 12, 2016, 10:09:00 PM »
In addition, the same setup is shown running at 10 amps, which would be a bit over 10 amps from the power battery, an adequate level for break in conditioning.  Several receiving cells in need of charge and a parallel board easily allow for 10+ amps as desired.  Various settings on the charger help to control the process and shut it down safely.
Fred
352575
Online Igor Burger
« Reply #42 on: September 13, 2016, 12:35:50 AM »
Yes, that is what I do ... or even better - I have 4 packs of old batteries taped together and connected paralel which does not have enough capacity anymore, so I do not fly them and I use them to power the charger, they have still enough capacity for 3 flights. I use also iCharger, it is well configurable to watch voltage, so no big stress.
Re: Battery Discharger and Field Charger with Lipoly Power Supply
« Reply #43 on: September 13, 2016, 02:42:57 PM »
A bit more detail for those interested.  You can run a parallel board of lipolys on the input power side and a parallel board on the charging side and have a field charging unit, as well as the previously discussed capability to discharge a battery efficiently, and run a break-in discharge.
The Batteries can be "hardwired" into a parallel brick or the board used.  The Parallel Board is easy, but a bit more bulky.  The PB has male connectors as does the input to the charger, so a simple set of insulated 3/16 or 5mm OD brass tubes of about 1.5 inches will serve as the female joiner, see below. The joiner is in line in power supply line along the Zippy pack on the far left.
The iCharger, and some others will take over 12 volts, and can be set to have a low voltage limit from the power supply.  It is default at 10v to protect your car battery, and for the lipoly packs should reset for lipoy safety. Below shows 3.2V/cell or 19.2 volts from the power supply.  The input voltage wasn't designed to be specifically from Lipolys and is not monitored by cell.  That can be done with an external monitor and alarm if desired, shown.
My "power pack," as Igor suggests, is old battery packs that are not safe for flying.  They seem to charge well, but under flight load will have a cell significantly drop.  That may limit the usefulness of some packs for power if that drop is with charging loads.  This system is dependent on the charging batteries, old and failed, to have enough capacity to charge the flight packs.  One way this works well is for the fully charged power pack to bring the flight packs up only from storage, about 1200 mah per flight pack.  Of course the alternative is to have more batteries on the power side for more capacity.  This mainly depends on your use, to be able to charge storage packs at the field while setting up, or to recharge full flight packs. It's fairly simple to figure the useful capacity of the old packs and the needed capacity for the flight packs.  Note that if the charger setting for power side low voltage is changed from the default of 10, then you need to remember and reset for 12V supplies such as if you still need to charge from the car battery.
Fred
352575
Offline Larry Wong
« Reply #44 on: September 25, 2016, 03:33:49 PM »
On the discharger the balancing plug in, on the side of unit works on Thunder power battery's with white plug, but some Thunder power battery's have Black balance plug , were do I get adapter? ???
Larry
« Reply #45 on: September 25, 2016, 03:38:13 PM »
Which discharger, and the name or type of the black plug?  Since there may be an adapter, how many cells in the pack?
Or, try this - balancing adapters jst-xh to thunder power - in Google.  I saw several possibilities.
Fred
352575
Offline Larry Wong
« Reply #46 on: September 25, 2016, 05:27:14 PM »
battery  Thunder power 5c 2700 mhA
Larry
Offline Larry Wong
« Reply #47 on: September 25, 2016, 05:56:34 PM »
http://stunthanger.com/smf/index.php?action=dlattach;topic=43251.0;attach=258384;image
with just one discharger blue plastic box with 3 white buttons
Larry
« Reply #48 on: November 01, 2019, 10:49:16 PM »
I updated my discharger box with some new technology.  The original discharger consisted of the blue control module and a switching module connected to 150W worth of light bulbs.  New ones, https://www.banggood.com/AOKoda-CellMeter-8-150W-Discharge-Module-Set-with-Lipo-Battery-Balancer-p-1196376.html?rmmds=search&cur_warehouse=CN ,  have what looks like the same blue control module, but the switching module now has an input and an output so you can connect a whole string of switching modules, which you can now buy separately: https://www.banggood.com/AOKoda-CellMeter-8-150W-Discharge-Module-Set-for-AOKoda-Discharger-p-1196377.html?rmmds=search&cur_warehouse=CN .  I got two of the latter, so now I have 300W of light bulbs for each control module.  If you have the old discharger, you can add switching modules and put the original switching module at the end of the string.
I put the whole assembly plus a parallel battery board in a bigger cookie box (technically a biscuit tin: British shortbread cookies).
« Reply #49 on: November 02, 2019, 09:06:34 PM »
Howard, that looks like it will work well.  Great update for those who looking at a discharger.  If I calculate correctly, 150 watts/22.5v gives about 6.6 amps draw for 6s pack.  So that would drop a fully charged battery to reasonable storage in 10 to 15 minutes depending on where you want it.  And better quicker for 300 watts.
Fred
352575
