  • June 21, 2025, 06:55:54 PM
Author Topic: Low cost Spinner? What are you using?  (Read 3238 times)
« on: May 03, 2014, 11:38:30 AM »
What are people using for low cost spinners?
Im looking for a low cost (not a TT) 2 inch reverse pitch spinner for my project.
Offline William DeMauro
Re: Low cost Spinner? What are you using?
« Reply #1 on: May 03, 2014, 01:44:08 PM »
Paul,
Sorry I meant to answer this too in your last post. If you want a low cost E-spinner you can use the Great Planes ones. They do have to be modified slightly for the reverse props. Tru-turn, which you don't want, custom cuts them for us. I don't know of any off the shelf but if you do find an off the shelf one let me know
AMA 98010
« Reply #2 on: May 03, 2014, 03:27:46 PM »
I have also been using the Great Plane - the transluscent plastic ones - with the prop opening re-cut for LH props.  The smaller ones (1.5", 1.75") don't look too bad with the holes cult to almost square and fitting over the nearly square prop hubs inboard of the main blade shape.
These are light and pretty inexpensive too.
Offline James Mills
« Reply #3 on: May 03, 2014, 05:17:03 PM »
Tom Morris has some aluminum spinners that are not high price, I don't remember the brand.
James
AMA 491167
« Reply #4 on: May 03, 2014, 06:42:15 PM »
Thanks Guys
I got one of toms. It does not have a flat back. 😩
Offline Tim Stagg
« Reply #5 on: May 06, 2014, 07:01:24 AM »
Paul,
I use the Great Planes ones like Dennis on most of my stuff. I have a few Tru Turns  they are real nice......but a little heavy and for the money.....I will stick with Great Planes, they work great, are fairly true.... and look just fine.
Tim
Tim Stagg
« Reply #6 on: May 08, 2014, 07:56:53 AM »
Thanks Tim!😊
Offline Peter Ferguson
« Reply #7 on: May 28, 2014, 12:28:41 AM »
Ditto on the GP electric spinners.
Peter Ferguson
Auburn, WA
Offline Kerry Ewart
« Reply #8 on: May 28, 2014, 02:31:54 AM »
Hobby king have 51mm,carbon spinners with no holes for props cut ,,cheap too,have used them  and they are not to bad,,
"If you cannot beat them!JOIN THEM.
Offline Robert-Jan
« Reply #9 on: May 28, 2014, 05:40:33 AM »
Do you now what the nose radius is?
In FAI F2B it is not allowed to have a sharp nose.
b) All spinners and other forward-facing metal or equally rigid projections should have a minimum radius
of 5 mm.
Thanks in advance.
Greetings Robert-Jan
Offline RC Storick
« Reply #10 on: May 28, 2014, 09:12:59 AM »
I am making my own now. only 14 grams
Offline Dick Pacini
« Reply #11 on: May 28, 2014, 09:26:43 AM »
3D printer?
AMA 62221
Offline RC Storick
« Reply #12 on: May 28, 2014, 09:30:43 AM »
Nope if you watch my youtube videos I show exactly how I made them. is is done in 4 short clips. Here is one
« Reply #13 on: July 24, 2014, 09:26:03 PM »
Robert,
They look great!
Paint will stick to them quit easily?
Are you taking orders in different sizes?
Charles
