  • July 17, 2025, 09:24:39 PM
Author Topic: Battery break-in  (Read 3819 times)
Offline Larry Renger
Battery break-in
« on: September 29, 2016, 08:00:41 AM »
I ran a search and found a couple of references to battery break-in, but no specifics.  Why is it needed and how is it done?  ???
Online Motorman
Re: Battery break-in
« Reply #1 on: September 29, 2016, 11:02:55 AM »
Did you read this   http://stunthanger.com/smf/gettin-all-amp'ed-up!/discharge-rate-while-flying/
Hmm... how come the full link never comes up? Anyway it's not hard to find.
Just set your charger for the lowest termination voltage usually 4v then set your timer for 3 minutes and put on a much lighter load prop and set the rpm very low about 5-7k then charge and run the battery on the ground about 3-4 times and that should do it. You can also just fly the battery normally without break in but it'll get hot the first few times and won't last as long.
« Reply #2 on: September 30, 2016, 06:01:27 AM »
Got it, thanks! I don't know why that didn't come up on my search, but it fills the bill!  H^^
Online Fred Underwood
« Reply #3 on: September 30, 2016, 04:23:45 PM »
I did the search once and found only this thread. I changed word order in the search and tried again and found more.  There is some variability in the search function.  Some threads here with a variety of methods
http://stunthanger.com/smf/gettin-all-amp'ed-up!/battery-discharger/msg460875/?topicseen#msg460875
http://stunthanger.com/smf/gettin-all-amp'ed-up!/lipo-batteries-safety-and-handling/msg29269/?topicseen#msg29269
http://stunthanger.com/smf/gettin-all-amp'ed-up!/battery-break-in/msg92424/?topicseen#msg92424
Fred
352575
Online Motorman
« Reply #4 on: September 30, 2016, 05:15:58 PM »
Once again only half the link, Robert what's up with that?
« Reply #5 on: September 30, 2016, 07:44:48 PM »
Online Motorman
« Reply #6 on: October 02, 2016, 04:19:45 PM »
Offline Russell
  • ACE
« Reply #7 on: November 07, 2016, 02:03:04 AM »
Put your URL aka link between these: <>
 Example: <link>
« Reply #8 on: November 08, 2016, 07:54:00 PM »
I'm lost. ???
Offline Russell
  • ACE
« Reply #9 on: November 09, 2016, 02:17:55 AM »
I'm lost. ???
The problem with the link is the handling of special characters. Using "Insert Link" behind the scenes is enclosing the link with <test link>.
