  • July 11, 2025, 07:11:43 PM
Author Topic: Batteries, How many "C's" ?  (Read 1567 times)
Offline Ward Van Duzer
« on: September 02, 2013, 10:04:29 AM »
OK, from a complete neophyte...
Building a Primary Force with an E-Flite 15, Hubin 2a timer, ICE 50 ESC. Expect to be using 2200 mAh, 4S batteries.
OK, I went to hobby-King to look at batteries. They have four major brand/varieties, Zippy, Zippy Compact and
Turnigy and Turnigy Nano-Tech. A couple of buddies mentioned Zippy (I presume as the more economical). I’m not upset by the comparable price differences if you think The Turnigy’s are a better battery!
My major question though is what is the difference (in english, not, Numeric formula) between a 20C and a 45C, and the in-betweens. Is the higher number going to give me a longer run time? (or leave more juice in the battery after shut down). Will they provide more power in the violent maneuvers? My motor spec sheet says my E-flite 15 draws 34A continous, and Max Burst of 42A. I’ll be using a 2200mAh 4S battery. My current (bad) Gadex batteries are rated 25C but I think that was the only choice when I ordered them a year or more ago. Are there better choices now? The lower rated batteries are of course lighter in weight, and dollars, but I want to get the right ones first time!
Ward-O
Offline Robert Redmon
Re: Batteries, How many "C's" ?
« Reply #1 on: September 02, 2013, 10:25:54 AM »
The "C" (capacity) rating of a battery refers to the rate of discharge that is permissible before damaging the battery. You are using 2.2ah capacity cells, so a "C" rating of 10 means you can safely discharge it at a rate of up to 22 amps (continuous). It will get rather warm at that rate, though. Most batteries today are rated 20C or better, so your 2.2ah battery could provide up to 44 amps discharge, and so on. The "C" limitation is closely associated with the internal resistance of the cells. Generally speaking, the lower the IR, the higher the "C." The lower the IR/Higher the "C" rating, the cooler the cells will operate at a given discharge rate. To some extent the "C"rating is also influenced by the chemistry of the battery and the ruggedness of the construction.
Lipo cells are also rated at a certain "C" for charging. Better cells are generally rated for 5C or better charge current. i.e. a 2.2 ah battery with a 5C charge rate rating could be charged at up to 11 amps.
Higher "C" cells are typically heavier and thicker than their lower "C" counterparts.
Generally speaking, 25 to 35C cells will work very nicely for our purposes.
Hope this helps.
Bob
Robert Redmon
AMA 58073
Offline Jeff Traxler
  • T-Bone
« Reply #2 on: September 02, 2013, 10:59:51 AM »
Hi Ward,
    I speak English,I'll try.20c is plenty for your motor current draw.The c rating will not increase flight times.A 2200 mah battery with a 20c rating will discharge at 44 amps continous.A 45c will discharge at 99 amps.As far as the batteries I like the Zippy Compact.I just got 4 25c 2700mah 4s Zippy Compacts for my Barf Nobler.For less than $100.00 I might add from the US warehouse.I was able to get 38 flights this weekend at the team trials in between my pit boss/pull test duties and these batteries perform better than expected.I was a bit concerned about the "Compact" in the name but not any more.Zippy Compact has a 2450mah 35c for less than 25 bucks as well.I do like a higher c rating with this being said just for the extra "headroom" and higher c's will run a bit cooler.At the trials Orestes had 25c batteries in his ship and kept them in a cooler but his friend Josias had 70c batteries in his Shark and they barely felt warm.Hope this helps.Trax
Offline Dan Bregar
  • Field Marshall
« Reply #3 on: September 02, 2013, 11:24:08 AM »
Hi Ward
Just a thought for you on using a 2200 batt..  If you want to be able to do the full pattern and if so you will probably need about 5 1/2 minute flight time, the 2200 batt. may be cutting things very close, due to the fact that you don't want to be using up any more than 80% of the capacity of the pack (preferably less than 80%).  With this in mind when you set up the way you are going to mount the battery, and also when you go to set up the CG and balance it, try to leave some extra room for a slightly larger pack, and also room to be able to slide it fore & aft to help with the CG.  You could get lucky and not need a pack larger than 2200, but sometimes we end up needing a little more, than we figured, due to using a bigger prop or longer lines and such.  Just sayin. :)
AMA 33676
« Reply #4 on: September 02, 2013, 11:25:06 AM »
Hey Ward-O:
The "C" rating is part of a mathematical formula, so it's kind of hard to avoid.
But: if you're flying control line stunt, and if your flight time is between 5 and 6 minutes, and if you're not sucking the batteries completely dry each flight, then 10C is barely enough, 20C is better, and the only thing that a 45C discharge battery gets you is slightly less temperature rise and (possibly) quicker charging.
If your case doesn't match all the "ifs", then you need to play with math a bit to get the right number.
The last time I checked there was no industry standard way to establish the "C" rating on a battery.  Some manufacturers may rate the pack for what will give a life that's only a teeny bit shorter than if you used the battery "perfectly", others may rate it for what won't burst into flame the first time you try it out.  Most will be someplace in between.  Each manufacturer is going to find their own balance between impressive marketing numbers and honesty.  What this all boils down to is that a cheap Chinese pack's "C" rating may be much higher than a "name brand" pack's "C" rating even if the packs are identical in every way.
« Reply #5 on: September 02, 2013, 01:23:55 PM »
Jeff,
Thx for the info on the zippy compact 2450. It fills in where I had some doubts. My current (dead) 2200's were bought with size concessions in mind(101mm length). I was not real comfy with the 2200, but they fit in the Force. The zippy 2450 at 114mm wil require a little modification on my motor mount, but I'll stuff it in there!
Thx to all for the info... H^^
Ward
Offline Igor Burger
« Reply #6 on: September 02, 2013, 01:44:21 PM »
May be it is easier to understand it from opposite side. 1C means that you can discharge battery minimally 1 hour of constant current (for example 2Ah battery at 2 Amperes or less). 2C means you can drain it 2x harder and discharge it in 1/2 hour  (means 4A). 10C means you can do it in 1/10 hour means 6 minutes. 20C means you can dischrage it in 3 minutes. So if we fly 5 minutes, we do not discharge by constant current and we need some reserve, the minimal discharge rate is 20C.
Higher C rate will give you also better discharge efficiency (because of lower internal resistance) but it also means heavier battery.
Offline Robertc
« Reply #7 on: September 02, 2013, 02:25:36 PM »
Going to your battery question on the Turnigy, I've better luck with the Zippy.  Turnigy on paper looks better, but has not
worked out for me.
Offline Steve Fitton
« Reply #8 on: September 02, 2013, 05:12:58 PM »
How come the 2200s are dead?
Offline John Cralley
« Reply #9 on: September 02, 2013, 08:45:53 PM »
 My motor spec sheet says my E-flite 15 draws 34A continuous, and Max Burst of 42A. Ward-O
The spec sheet is giving you the maximum that your motor can do. What you need to know is what you are actually pulling from your battery which should be at least somewhat below those maximums!! How many actual amps you are pulling will determine how long a flight you can get from your 2200 mah batteries.
John Cralley
AMA 52183
Central Illinois
« Reply #10 on: September 03, 2013, 09:54:39 AM »
Steve,
Batteries 'dead' due to ignorance. Bought them more than a year ago (mebbey two) and were never charged. One had two very nearly dead cells and wouldn't charge. The other had one very low cell. I'm going to try and bring that one back by running it in balance mode, perhaps with a higher charge rate. Error msg says to charge it at .5 amp while balancing. Of course it's possible they were bad to start with!
Ennyway we're going to try the Zippy 2450's.
Thanx all
W.
« Reply #11 on: September 03, 2013, 10:19:53 AM »
Watch that cell if you do -- LiPo cells don't like being brought back to life after the voltage gets too low.  I can't remember the critical voltage (and it varies with the way the cell was manufactured, anyway), but charging after letting the voltage get too low is one of the ways to make a cell burst into flame.
Offline Doug Moon
« Reply #12 on: September 03, 2013, 08:22:59 PM »
Steve,
Thanx all
W.
If you have a batt with one cell way below the others then you should discard that battery and not use it anymore.  If your charger would let you put a higher rate into it you would probably get a very bad result...
When I start a charge I usually take a quick peek at the starting voltage for the cells that way I know they have all discharged evenly across the pack.
If you should run a battery evenly across all cells below the 20% line and the charger wont start up and says voltage too low you can try this trick.  Flip the charger to NiMh and charge it at .5 for just a few minutes at a time.  Then flip it back to LiPo and see if the voltage is there.  If not go a few more minutes etc etc until you get minimum voltage in your battery. Then charge at a 1c Rate balance for the next charge.  Keep it in an open area and stick around while charging.  Once you get a full charge in it monitor it closely when in use or relegate it as a test battery only using it for short trimming flights.  I have done this very thing on a car battery and it worked.
If you get MA look on page 109 in the Sept 2013 issue.  There is a pretty easy to follow break down on LiPos. Its not the same discipline but batteries are batteries and what they are attached too makes no difference when learning the dos and donts.
Hope this helps.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
