  • June 16, 2025, 12:35:29 PM
Author Topic: Speed 400  (Read 1036 times)
Speed 400
« on: August 15, 2009, 09:50:44 AM »
I have a new Speed 400 brushed motor (12 volts) and speed controller to match.  Does anyone use these now that 3-phase motors are "in"?
Not sure what to do with it.
Offline Archie Adamisin
Re: Speed 400
« Reply #1 on: August 16, 2009, 05:53:18 AM »
Floyd,
Is it a Graupner motor?  Most Speed 400's were either 4.8v, 6.0v, or 7.2. The higher the voltage, the lower the Kv.  I used the 6v on 7 NiCad cells in my Speed 400 racers a few years back.  The 6V motor on a 2S lipoly would be a lot of fun in a 1/2A stunt or combat ship.  Just beware they run at a whopping 50-60% efficiency.
The reason fo everyone using brushless right now is they are just as inexpensive anymore.  Plus they don't where out if you don't go beyond their capabilities.  Speed 400's are throw away motors. Once the brushess are gone, it's over.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Offline Leester
Re: Speed 400
« Reply #2 on: August 16, 2009, 09:21:04 AM »
Floyd: I have a Dare Design P-51 Mustang 1/2a trainor. The dirrections call for a speed 400 electric motor as an option to the 049.
Leester
ama 830538
Re: Speed 400
« Reply #3 on: August 17, 2009, 10:07:24 AM »
Use an Emax 2805-2800Kv on 2S 1250's and a 6 x 4 APC prop.  It will be lighter and more powerful than both other options.  The motor is $5 and available on from Hobby City.  A 15 amp turnigy controller and a Will Hublin simple timer and you are set to go ECL.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Offline Leester
Re: Speed 400
« Reply #4 on: August 17, 2009, 07:54:42 PM »
OK Archie just to be perfectly clear on this stuff, the motors shown on the site are 2840 kv ? how about the 1600 kv ? Is the controller the one on the 3rd page 8-15A UBEC ? what programming card.  Thanks for helping
Leester
ama 830538
Re: Speed 400
« Reply #5 on: August 18, 2009, 07:38:20 AM »
Lester,
It depends on prop.  If you want to stay with the 1/2A 6" prop rule, use the 2840 Kv.  I have 6 of these motors and they rock.  The 1600 Kv would swing up to a 9 x 6 on 2S, or 7 x 5 on 3S.  Note, there are also some tower pro motor/prop/esc combos that work nicely.  They have a 2408-21T which is 1700Kv that comes with prop 9 x 4.7 and controller for $14.  I use these for RC foamy combat models.  They are simple bell motors/CD rom motors, but I have hundreds of flights on several and they run great.
Controllers, I would use the Turnigy plush 15 amp with Turnigy programming card.  I have also used the Tower pro 18 & 25 amp controllers with no issues.  They are cheaper yet.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
