  • June 17, 2025, 08:39:02 AM
Author Topic: Charger balanceing adapters  (Read 672 times)
Offline Dick Carville
« on: March 05, 2012, 01:55:03 PM »
I have been using a charger from Brodak  along with  Arrowind 6c batteries. This year I'm using the same Arrowind motor but switched to TP 5S battries.
Of course the balancing plugs on the TP don't fit the charger . Since I like the charger I went searching for adapters. The attached picture shows what I found.
They all work but I had to modify the ones from Atlanta hobbies a bit.
The harness from rclipos.com fits perfect.
rclipos has all kinds if adapter harnesses. I took a shot and got lucky.
Dennis A  asked me to post in case someone else needs the info
