  • July 31, 2025, 11:21:55 AM
Author Topic: ztron timer question  (Read 1711 times)
Offline Jeffrey Olijar
« on: October 08, 2008, 06:02:07 PM »
does the ztron timer have a low voltage cutoff? and will it work with a 1s lipo?
If it ain't broke, fix it till it is.
Re: ztron timer question
« Reply #1 on: October 08, 2008, 06:13:57 PM »
The low voltage cutoff should be in your speed controller. The timer is nothing more than a "simulater" to take the place of the reciever in an RC plane,, or
 y1maybe the reciever takes the place of the timer since we know control line is way cooler and more important right? y1
« Reply #2 on: October 08, 2008, 07:33:46 PM »
thanks I wasnt sure I lost my manual and I wanted to make sure.
Alan Hahn
« Reply #3 on: October 09, 2008, 10:26:54 AM »
Mark is right! y1
Offline Mike Anderson
« Reply #4 on: October 09, 2008, 01:50:01 PM »
Which manual ?  I can send you a copy of the z-tron instructions, in fact, you can google them and find a set, I believe. At least for one of the versions.
If it's the ESC manual, most of them can be downloaded from various places also.
Mike@   AMA 10086
Central Iowa
