  • July 19, 2025, 03:53:37 PM
Author Topic: AXI motor repair?  (Read 2533 times)
AXI motor repair?
« on: August 26, 2014, 12:19:03 PM »
I did the usual "search" function trying to locate repair parts, or a repair service for AXI motors.  Even an internet search got nothing.  The AXI web page doesn't offer repair parts.
I would prefer to have someone else fix my motor, rather than my messing it up even more
Offline Igor Burger
Re: AXI motor repair?
« Reply #1 on: August 26, 2014, 12:44:53 PM »
Repair for standard AXI is directly in Modelmotors. If you mean F2B 2826/13, contact me, I will give you address where to send it.
BTW what is wrong?
« Reply #2 on: August 26, 2014, 01:39:46 PM »
Thanks, Igor.  This is a small 2208/34.  It has a bent shaft (hollow).
Offline Igor Burger
« Reply #3 on: August 26, 2014, 01:58:41 PM »
shafts are available as spare parts as far as I know, but replacing is not trivial, better to send it
address:
Model Motors s.r.o.
Sladkovského 594
530 02 Pardubice
Czech Republic
 e-mail: info@modelmotors.cz
Offline John Cralley
« Reply #4 on: August 26, 2014, 02:54:23 PM »
Floyd,
This looks to be close to your AXI  (claims to handle 10 AMPS vs AXI 8 AMPS).
The price is right and they have it at the USA warehouse.
http://www.hobbyking.com/hobbyking/store/__34577__D822_17_Brushless_Outrunner_1100kv_US_Warehouse_.html
John Cralley
AMA 52183
Central Illinois
Offline William DeMauro
« Reply #5 on: August 26, 2014, 06:14:05 PM »
That motor has a 3.2mm shaft(1/8). That's a common sized shaft, so its available from many sources as long as you are willing to cut to length. If you have a damaged shaft odds are your bearings have been damaged too and they you said it was a hollow shaft, Do you use that feature? If not it can be replaced with a solid shaft. If you don't need it very fast pm me and I more than likely can fix it. It should not be a hard fix, but your best and most economical fix could be doing this yourself. By the way the equivalent cobra will only cost you about $26 + shipping and you will have it in about 2 days http://www.rcdude.com/servlet/the-2024/Cobra-C-dsh-2208-fdsh-34-Brushless-Motor/Detail . That is way cheaper than you shipping that motor 2 ways and paying for parts and shipping and you are getting a good quality motor besides. Just buy the cobra. By the way the motor John recommends will also work.
AMA 98010
