  • July 14, 2025, 05:27:03 PM
Author Topic: AXI 2826/12, Anyone got one?  (Read 4647 times)
« on: March 24, 2016, 11:53:07 AM »
Couple of questions on the AXI 2826/12.
Anyone got one?
Thanks in advance.
Charles
Re: AXI 2826/12, Anyone got one?
« Reply #1 on: March 24, 2016, 01:33:14 PM »
I believe I do, but I will have to check when I get home tonight from work, Privat message me
« Reply #2 on: March 24, 2016, 03:50:27 PM »
Mark,
I'm looking for measurements and photos.
Charles
Online Fred Underwood
« Reply #3 on: March 24, 2016, 04:19:44 PM »
Not sure what you are looking for, but this may have the info, certainly the measurements
https://www.modelmotors.cz/product/detail/233/
Fred
352575
« Reply #4 on: March 24, 2016, 05:54:22 PM »
Thanks Fred.
« Reply #6 on: March 24, 2016, 07:25:01 PM »
if thats all, try GOogle
http://lmgtfy.com/?q=http%3A%2F%2Fwww.espritmodel.com%2Faxi-2826-12-outrunner-brushless-motor.aspx
I did, but I didn't find what Fred did. Great link, but it's England. I'll do a USA search tomorrow.
I'm looking for a used one.
Thanks for the replies.
Charles
« Reply #7 on: March 24, 2016, 09:54:03 PM »
you know CHarles, I know you have a thing against me, but seriously, did you click on the link I posted, its a USA company, they dont sell used though,, so you are not looking for pictures, you are looking for a used motor,,
just say what you want,, I tried AGAIN to help you,,
Offline Mike Scholtes
« Reply #8 on: March 24, 2016, 10:33:40 PM »
I have 2 of them. Post what info you need and I will measure and reply.
Regards, Mike Scholtes
« Reply #9 on: March 25, 2016, 07:56:36 AM »
Mark,
 I did use your link. A google index page came up, probably because of my old Windows XP.
« Last Edit: March 25, 2016, 08:36:05 AM by Avaiojet »
Offline Chris Cox
« Reply #10 on: March 25, 2016, 09:46:09 AM »
Hey Mark
I tried your link as well, but unlike Avio, I probably waited a little longer.  Brilliant.  That was very cool.  Well done!
Chris
« Reply #11 on: March 25, 2016, 11:08:24 AM »
Hey Mark
Chris
Chris,
I waited quite a while actually. Even tried it a few times. Like I said, could be my Windows XP.
What are you using?
Charles
Offline Dane Martin
  • heli pilot BHOR
« Reply #12 on: March 25, 2016, 12:30:21 PM »
Mark, i did this on my phone, it makes for a funny animation, and even talks some trash.... I love it!
Charles, if the axi is too expensive new (totally understandable) try this alternative... It's the hobby people brand motor. Very close. This one is a little higher Kv, so you'll need less prop than the one you listed. I've used plenty of these. Very high quality. And watch for sales!
http://www.hobbypeople.net/index.php/2826-05-brushless-motor-w-hardware.html
« Reply #13 on: March 25, 2016, 01:24:00 PM »
"Great" Dane,
Thanks for the link.
I like saving money. I don't have much of it.  ;D
What RPM's are you getting?
Do you use the bolt on collet I see in the photos?
Charles
Offline pmackenzie
  • Pat MacKenzie
« Reply #14 on: March 25, 2016, 03:08:12 PM »
That is a closer match to a 2826/10.
 Probably the way they are counting the turns. For DRLK wind 5 on each tooth to make a wind, which AXI (and just about everyone else) would call 10 turns.
The original AXI motors were LRK and wound on only every other tooth. I have a couple of them (2820/10)
On 4 cells use an APC12x6 at about 9K.
Pat MacKenzie
MAAC 8177
Offline Dane Martin
  • heli pilot BHOR
« Reply #15 on: March 25, 2016, 06:22:59 PM »
"Great" Dane,
Charles
What Pat said above, spot on for my experiences as well. I will note, my sole experience with this motor i pointed out is RC. So i would take what Pat Mckenzie says to heart
Offline William DeMauro
« Reply #16 on: March 26, 2016, 05:54:45 AM »
http://www.rcdude.com/product-p/c-2826-12.htm
Much cheaper virtually the same size and specs as the Axi
http://www.rcdude.com/product-p/c-3515-18.htm
Also cheaper similar in weight, the dimensions change a little but also a good substitute. Do you realize that these are pretty much 5 cell motors for our applications?
AMA 98010
Offline pmackenzie
  • Pat MacKenzie
« Reply #17 on: March 26, 2016, 06:03:14 AM »
12 wind is better suited to 5 cells, the kV is a bit low for 4.
But the 10 wind (like the one that Mark linked to)  to will work quite well with 4 cells if used with the APC 12 x 6.
Till quite recently I had that setup in my Vector 40. Also used it in an ARF Nobler, but ended up with a slightly smaller motor to save a bit of weight.
It depends a lot on the actual application: plane size, weight, prop, type of flying.
MAAC 8177
