  • July 26, 2025, 10:09:06 PM
Author Topic: Question about APC props  (Read 1342 times)
Offline Martin Quartim
    • StuntHobby
« on: December 10, 2013, 03:13:00 PM »
APC has two 13x4.5 EP props listed in their website:
http://www.apcprop.com/ProductDetails.asp?ProductCode=LP13045EP
and
http://www.apcprop.com/ProductDetails.asp?ProductCode=LP13045EP%28F2B%29
Can any one tell me what is the difference?
Martin
Offline William DeMauro
Re: Question about APC props
« Reply #1 on: December 10, 2013, 03:52:51 PM »
The f2b is the thin hubbed one. This is identical to the first prototypes that most of us really liked. Later they made a thicker hubbed one that was stiffer and heavier and a little less efficiant. Many of us did not care for the thicker one. Last year Dennis Adamisin requested that they bring back the original as many of us wanted them or needed replacements. They agreed so now we have both props.
AMA 98010
Offline Dean Pappas
« Reply #2 on: December 11, 2013, 01:36:14 PM »
Hello Martin,
The thicker hubbed prop is quieter in the corners due to its stiffness, but as Bill said, you pay a price in weight and maybe power consumption. You might try both. The "WOW" noise in the corners is due to gyroscopics coupling with prop flex trying to vibrate the nose of your airplane apart ... if it happens with your combination. For some planes, the thinner prop does not do this, for others it does.
  Dean P.
Dean Pappas
    • StuntHobby
« Reply #3 on: December 11, 2013, 01:54:43 PM »
thanks all!
good to have options!
Martin
« Reply #4 on: December 11, 2013, 05:18:03 PM »
Hi Martin
The F2B version of the 13x4.5EP needs to run about 9500 RPM - that is some 800 to 1000 RPM slower than the thick version.  If you want to use a thicker/stiffer prop use the 13x5.5EP  It usually runs about the same RPM as the thin 13x4.5EP within +/- 100 RPM.
There are people who have tried them back to back - some folks like the 4.5, some like the 5.5 with no real compelling reason why one is prefered (or not) versus the other!
When the 13x5.5EP (then called WEP) first came out we had several folks try them and give there impressions versus the original thin blade 13x4.5EP (now called the F2B) I charted their impressions - see below.
    • StuntHobby
« Reply #5 on: December 11, 2013, 07:11:05 PM »
Hi Dennis,
Thank for the info. My eyes are getting tired and I could not read well, can you email the chart in higher res ?
I plan to use the Eflite Power32 and a Legcy ARF to get a taste for Electric. Not knowing much about eStunt, I´d guess the 13x5.5EP would need a bigger battery.
Martin
« Last Edit: December 11, 2013, 07:41:48 PM by Martin Quartim »
« Reply #6 on: December 12, 2013, 03:43:11 AM »
Ha!  Maybe I should have called the table "Eye Chart"?
Here's a pdf you can download - let me know if that is any better...
« Last Edit: December 12, 2013, 02:18:13 PM by Dennis Adamisin »
