  • July 08, 2025, 01:07:02 PM
Author Topic: Arming Plugs/switches,What are they,how do you build and use them?  (Read 2253 times)
Offline Ward Van Duzer
What more can I say? Other than how do you build them in Full fuselages, and profiles? Maybe, why do you build them?
Dum Ward-O
Offline Crist Rigotti
Re: Arming Plugs/switches,What are they,how do you build and use them?
« Reply #1 on: May 18, 2011, 11:54:16 AM »
None needed on a profile.
Offline eric david conley
« Reply #2 on: May 18, 2011, 01:13:19 PM »
     What? I have 4 e-profiles built over the last 3 years and each one of them has an arming plug and none of them was easy to install but for safety's sake needed. Crist, could you tell me about why I dint need them?  Eric
Eric
« Reply #3 on: May 18, 2011, 01:27:33 PM »
For that matter, when folks say "arming plug" or "arming switch", do they mean "gizmo that cuts off the timer from the ESC", or do they mean "gizmo that removes battery power from the whole darn system"?
For a while I had an RC plane, where I used a miniature headphone jack for the "on" switch.  "Off" was when the plug was in, "on" was when the plug was out.  I made up a bright red ribbon that said "REMOVE BEFORE FLIGHT" and attached it to the plug -- I thought it looked very decorative sitting on the flight line.  Be kinda heavy if you wanted to cut off battery power, though.
I'd love to see pictures of how people solve this problem with CL planes.
« Reply #4 on: May 18, 2011, 02:13:27 PM »
     Here are some pictures of my arming devices. They turn off ALL power from the battery when pulled out. So when you have the battery plugged in, the hot wire is split until you complete the circuit by plugging in the red (hot wire from the battery) wire into the red receptacle at the trailing edge of the wing. To disarm you pull the red wire out. The pictures show a e-15 carrier plane and a e-profile plane with the same setup. Last picture is the arming switch sold commercially but was cumbersome and heavy.  Eric
Eric
« Reply #5 on: May 18, 2011, 02:25:01 PM »
I simply plug/unplug the battery into the connector attached to the ESC.  What is so hard about that?
« Reply #6 on: May 18, 2011, 02:40:05 PM »
     I guess in your case it might be OK. With my planes having hatches to open before you can get to the plug I felt I needed to be able to disarm my planes from the back of the wing away from the motor and perhaps a moving propeller.   Eric
Eric
« Reply #7 on: May 18, 2011, 02:43:54 PM »
It's more than OK.  It works great and doesn't cost anything extra and it doesn't weigh anything either.
« Reply #8 on: May 18, 2011, 02:59:50 PM »
     OK.  Eric
Eric
Offline John Rist
« Reply #9 on: May 18, 2011, 04:52:03 PM »
Lets say that if it is hard to get to the battery connection in a hurry an arming plug makes sense.  If the battery plug is readily accessable it acts as the arming plug.  SO I am stating the obvious.
In actual pratice, on a very sleek stunter I am not sure that one would want an arming plug hanging out somewheres.  I am guessing that on these stunters that the battery access hatch goes on easyly.  So once again the battery plug becomes the arming device. My feeling is forget the arming plug.  Plug up the battery at the last minute before the flight. Be careful not to hit the start switch on the timer before you are ready.  AND once the airplane goes hot (battery plugged up) treat it as snake ready to hurt you.  Keep hands out of the prop and keep the airplane pointed away from people and secured until it is time to push your start button and release.
 %^@  Wow I stuck my finger in the prop - it HURTS!!   LL~
« Reply #10 on: May 18, 2011, 06:22:24 PM »
For a full fuselage airplane an arming plug would be highly recommended.  Here are 3 links that talk/show what others have used for arming plugs.
On Norm Whittle's Sultan-e he uses a single connector.  See the sticky above on his cookbook.
http://stunthanger.com/smf/index.php?topic=18169.0
http://stunthanger.com/smf/index.php?topic=10048.0
http://stunthanger.com/smf/index.php?topic=10050.0
Offline John Witt
« Reply #11 on: May 18, 2011, 07:45:13 PM »
Here's the set up for my E-Impact.  The socket for the arming plug is the female half of the connector which was epoxied into a small piece of 1/8 ply. The external cover is a contoured piece of 1/16 ply.  The Plus lead to the ESC from the battery is interrupted by the connector, so when you insert the arming plug, the ESC is powered.  The arming plug is the male connector with a small piece of brass bar soldered across the terminals and covered with heat shrink. Make the bar wide enough so you can get a grip on it to un-plug easily.
The small toggle interrupts the plus lead from the FM-9 timer to the ESC (that's the small gauge three wire ribbon cable). The white push button is the enable for the FM-9 programmed sequence.
When you are ready to start the flight, the following things occur:
1.  Plug in the arming plug, and the ESC sounds its start up tones. The number of beeps indicates how many cells it sees (Castle ESC).
2.  Flip the toggle to "ON" and the ESC plays its sequence tones (kind of like a bird call, I think)
3.  Push the white button and the propeller spins momentarily, this confirms the timer is talking to the ESC.  You are now walking to the handle as the timer counts down the preset delay (30 seconds, in my case)
The set of switches is set up for a 1-2-3 sequence working forward from the wing.  Flipping the toggle to "OFF" aborts everything, even if the motor has reached flight speed.
Hope this is of help.
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline Dean Pappas
« Reply #12 on: May 18, 2011, 09:57:48 PM »
If the battery and/or its connector is under a hatch, then use a safety disconnect for heaven's sake! PLLLLEEAASE!!!!!!!
There are many clever, and clean ways to do this.
I liked what Hunt did, of course.
Of course it is appearance points day worthy.
Bob, you have a picture to share?
Dean P.
« Last Edit: May 19, 2011, 12:39:21 PM by Dean Pappas »
Dean Pappas
Offline Will Moore
« Reply #13 on: May 19, 2011, 05:03:58 PM »
By all means, do not fly without one. You will save the life of your aircraft, and perhaps a friend.
Here's mine.  I like the nuts and bolts look, because my plane is a take-apart, with 9 visible bolt heads on the airframe.
And the red and black housing and wire, emphasize clean , quiet, efficient, and powerful electric propulsion
« Last Edit: May 20, 2011, 06:32:39 AM by Will Moore »
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
 AMA # 209
Offline Andrew Borgogna
  • Andy
« Reply #14 on: May 20, 2011, 12:19:22 PM »
So far I have only built profile electrics and like Crist I really can't see where an additional disable function makes the total system any safer.  I consider the battery plug the circuit protection.  It's the last thing I plug in at the circle and the first thing I unplug after switching the timer (KR timers have a slide switch) off.  I am a believer in safety first but I just don't see where the additional safety comes from.
Full fuselage that's a whole different story because I can't get to the battery harness quick enough, I can easily see a need for an external circuit breaker device.
Andy
Andrew B. Borgogna
« Reply #15 on: May 20, 2011, 12:52:47 PM »
There's a sales opportunity here, for someone who either knows of a lightweight switch that can be made to look good, or has the capability to build one.
I'm not sure that a positive cutoff switch is really going to add any more safety to the system than a positive fuel shutoff would.  It seems that you'd do better to put a fuse in of the correct current rating, and have an easy to access 'off' switch on the ESC -- that would protect you from just about any event that a battery cutoff would, except for a severely misbehaving ESC.  Since I haven't heard anything about misbehaving ESCs, this tends to make me think you'd be OK.
Most "batteries in flames" events aren't going to be helped with a cutoff -- once the battery's swelling and smoking, it's just going to go.
« Reply #16 on: May 20, 2011, 02:54:14 PM »
I think the idea of an arming plug is for safety of the ground crew and not the airplane.
« Reply #17 on: May 20, 2011, 03:04:32 PM »
For that -- assuming that you can trust the ESC -- you just need to cut the timer power.  With no signal to the power a properly functioning ESC isn't going to let the prop turn.
That said, I would never let any body part (mine or someone else's) inside the prop arc at any time when the main battery is plugged in.  So I suppose that extends pretty quickly to needing an arming plug.
Which gets back to needing to make it look good.
Maybe a hatch with a good strong magnet latch over the arming plug?
« Reply #18 on: May 20, 2011, 05:09:43 PM »
The key word is "poperly functioning ESC".  Using an arming plug removes that from the equation, thus using an arming plug is even a safer bet.  Why take any chance?
