  • August 03, 2025, 11:37:24 PM
Author Topic: Arming Plug--Anti Spark switch????  (Read 5212 times)
Offline Shawn Lenci
« on: August 11, 2013, 09:55:00 AM »
I am looking at the Arming Plug assemblies that Maxx Products sells.  Do I need the anti spark switch for 4S-6S set ups?  I am looking to purchase a few and am wondering if the anti spark is needed.
Shawn
AMA 97686
Offline John Cralley
Re: Arming Plug--Anti Spark switch????
« Reply #1 on: August 11, 2013, 12:21:21 PM »
4S probably no but 5s and 6S yes.
John Cralley
AMA 52183
Central Illinois
Offline Paul Walker
« Reply #2 on: August 18, 2013, 05:37:49 PM »
I had one of those in my Predator for most of the year. Nice units!
Offline Shawn Lenci
« Reply #3 on: August 18, 2013, 07:10:18 PM »
Paul,
Are you using the one with the anti-spark button or just the straight plug?  In the photos posted here of your Predator I can see the arming plug on the bottom of the airplane with a button behind it.  I didn't know if that was the anti-spark button or the motor start button.
Shawn
« Last Edit: August 18, 2013, 08:17:36 PM by Shawn Lenci »
AMA 97686
Offline Paul Walker
« Reply #4 on: August 18, 2013, 07:37:44 PM »
I used the anti spark system with the red and black buttons until mid June. I then switched to the Jeti ESC and then only used an arming plug. The slide switch you see starts the timer.
Offline Andrew Borgogna
  • Andy
« Reply #5 on: August 18, 2013, 08:11:32 PM »
This may already have been talked to, but why is there a need for an anti-spark device?  Is damage being done to some or all of the different electrical devices in an electric power system?  I am serious, I really want to understand this problem and know when I need to take precautions.
Andy
Andrew B. Borgogna
Offline Keith Renecle
« Reply #6 on: August 19, 2013, 10:58:30 PM »
Hi Andy, it's all to do with the fat capacitors charging up very quickly when you connect the battery, and as you go to more than 4 cells, the sparks get bigger. Four cells makes a short "crack", 5 cells makes a fat spark, and with 6 upwards.......you start arc welding! It not only takes out the connectors, but puts a nice big spike through the timer processor, and that applies to any of the timers in use at this time. Igor showed his simple method with a 10 ohm resistor on the round MP Jet connectors some time ago, and it's pretty easy to add this to a Deans plug or any other connector. Maxx Products state that it is a MUST for 8 cells and upwards, but I reckon that it's a good idea from 5 cells and more. Here's the link to the Maxx Products website and it's down at the bottom of the page http://www.maxxprod.com/mpi/mpi-21.html
Keith R
Keith R
Offline Frank Imbriaco
« Reply #7 on: August 20, 2013, 06:37:17 PM »
Castle Creations calls the spark "a friend ".
 I haven't used an anti-spark device on 4S and 5S stunters. My 2M R/C pattern ships use two 5S 5300(10S), and no anti-spark device. On the 10S setup, I use 10 gauge  wire and 5mm bullets. I periodically swipe the male bullets with a piece of 400 sandpaper . Seems to work.
Offline Douglas Ames
« Reply #8 on: August 22, 2013, 10:06:41 PM »
Does the anti-spark device use a condensor? Sort of like what's used in a points ignition system?
AMA 656546
  • Andy
« Reply #9 on: August 22, 2013, 11:45:52 PM »
As I understand the concept the anti-spark device is not really a spark suppressor, more like a spark preventer.  A resistor routs the +V to the ESC through a pushbutton switch to pre-charge in input decoupling capacitors prior to applying the full voltage from the battery.  The resistor essentially drops the voltage of the battery to give the ESC what would be a battery of a lessor cell count.  When the switch is released and the ESC is connected to the battery, the full battery is not looking at a dead short because the input caps are already charged up.  It's simple and I guess it works but the resistor would have to be sized to the battery you plan to use.  Or maybe they just size it to work with a ten cell battery and everything below just works.  I have never had a problem with my setups because I never run more than four cells.
Andy
Andrew B. Borgogna
« Reply #10 on: September 01, 2013, 03:01:25 PM »
Initial charging of the filter capacitors does make a little spark with 5 cells.  I use a Deans Ultra Plug in the battery lead.  They are gold plated, so the spark doesn't seem to leave any burned places on the shorting plug.  The fancy anti-spark gadgets are OK, but I believe in keeping the complexity down.  More reliable that way!
« Reply #11 on: September 23, 2013, 04:21:43 AM »
Andy
Thanks for the explanation. One day I'd like to convert to electrons... Learning everything beforehand.
I found this info on how to size the resistor to your ESC. Hope it helps.
http://rc.runryder.com/helicopter/t547501p1/
AMA 656546
« Reply #12 on: September 23, 2013, 07:43:28 AM »
Douglas and any others.
It appears that, if you use the formula that is presented in the link you posted, you will come out with a resistance that is too high for proper spark abatement and ESC arming. Read all of the comments it the thread. I think Igor Burger suggested a 10 ohm resister which is way different from a 1500 ohm one.
Igor can correct me if I am wrong. ;D
John Cralley
AMA 52183
Central Illinois
« Reply #13 on: September 23, 2013, 02:53:34 PM »
The thread in the link stated an EXAMPLE to demonstrate the formula.
Did you do the math in regards to your ESC & Battery pack?
Does one size fit all (10 Ohm) or can the resistor be better matched?
If I paid $400+ for a complete elec. system & charger,
I'd be a little aggravated at having to change terminals due to arcing.
AMA 656546
« Reply #14 on: September 23, 2013, 03:22:38 PM »
Douglas, There are a number of threads here on Stunt Hanger about sparks and arming plugs. I suggest that you do an "advanced search" using spark as subject and Igor Burger as the author and read some of those threads.
I do not use a spark arrestor because so far I only use a maximum of 4 cells for my batteries.
John Cralley
AMA 52183
Central Illinois
Online Howard Rush
« Reply #15 on: September 23, 2013, 06:16:30 PM »
As I recall (I'm too lazy to do a search), the resistor value has to be low enough for the voltage at the ESC to get close to the battery voltage before the ESC measures the voltage to set the cell count.  I'd guess the value would depend on the ESC and how much freedom the designers were given to program clever things into it.  Also, as I recall, Castle's response to the question of how big a resistor to use with theirs was not to use the automatic cell count feature.  The result of the discussion was that I decided not to use a desparking resistor.  I'll just change the connectors from time to time.  I have found that by first making contact with the + side of the Deans arming plug, then firmly rotating the - side into the socket, I can usually avoid the plug sticking partway in.
On another subject, if you calculate the power requirement for the resistor using "Twinkle, twinkle little star, power = I squared R, you get about 40 watts for a 5S battery and a 10-ohm resistor.  That's what you'd use for continuous current, but I'd guess we'd only need 1/2 watt or so.  Assuming the resistor either has 10 ohms or is an open circuit, a resistor failure due to picking too low a power rating would be benign.  What power rating do folks use?
« Reply #16 on: September 25, 2013, 01:59:11 PM »
If you insist on using a "charge-up" resistor, the value isn't critical.  Higher value just takes more time for the capacitors to charge up to battery voltage.  Resistor wattage is based on continuous duty.  The charging function only takes a second or two, and the current tapers off logarithmically, becoming near zero as the capacitors reach full charge.  a 1/2 Watt resistor should work just fine.
F.C.
Online Howard Rush
« Reply #17 on: September 25, 2013, 04:30:33 PM »
It might be critical.  That's the problem.
