  • August 01, 2025, 08:38:02 AM
Author Topic: ARF Flite Streak prop?  (Read 2709 times)
Online Larry Renger
« on: November 07, 2017, 08:58:05 PM »
I scored an ARF Flite Streak kit at the Golden State Championships a year ago ($30!  ;D ), and am assembling it as an electric. Motor is a Turnigy AS-3 35-36 -1050. I am thinking an APC electric 10x6 or 10x7 prop. Does that sound about right?
Re: ARF Flite Streak prop?
« Reply #1 on: November 08, 2017, 03:19:19 PM »
I went with a 9x4.5 prop
Online Larry Renger
« Reply #2 on: November 08, 2017, 07:26:15 PM »
Actually, my question was not complete. I should have also asked what lines and battery to use as they all inter-relate.
Thanks for the input so far.  H^^
Online Tim Wescott
« Reply #3 on: November 09, 2017, 04:47:43 PM »
I'm guessing four cells if you use the 9-4.5.  I don't know what the motor's capable of, though.
On slime, it flies great with a 1/4-28 prop nut that's followed by an APC 9x4 sport prop that's followed by an OS 20FP.
Offline Brent Williams
« Reply #4 on: November 10, 2017, 12:33:21 AM »
Pat Johnston reports that he has been using a 4s 1550mah battery and a 10x6e on his 28oz Shark 402 which is Flite Streak sized.
Offline Target
  • C/L Addict
« Reply #5 on: November 10, 2017, 10:26:57 AM »
I can loan you a tp 2100 4s, if i can make it to the flying field some day.
Chris
AMA 5956
Online Larry Renger
« Reply #6 on: November 15, 2017, 07:50:09 PM »
I flew it today with an APC 9X6 EP prop on 52’ .012 lines. Performance was marginal. Will try a Master Airscrew 10x6 p prop next. Plenty of power margin on the 2200 3s battery so far. 2 minute flight used 23% capacity.
Thanks for all your input! H^^
Online Larry Renger
« Reply #7 on: November 16, 2017, 08:31:09 AM »
This is a wood gas prop.
Online Larry Renger
« Reply #8 on: November 28, 2017, 10:07:26 AM »
On 50ft. lines, the plane is flying great with this prop. Power consumption is about 250 Watts.  ;D
Weight with a 3200 mAh 3S is 30 ounces.
« Last Edit: December 15, 2017, 12:35:10 PM by Larry Renger »
« Reply #9 on: November 28, 2017, 11:46:44 AM »
Here's an old video of a Electric Flite Streak with an E-flite Power 10 (1100Kv), and I believe it was 3 cell, and APC 9x6E on 60' lines
