Electric Stunt => Gettin all AMP'ed up! => Topic started by: Larry Wong on March 18, 2011, 03:21:55 PM
Title: Arc/ Spark when attaching Battery
Post by: Larry Wong on March 18, 2011, 03:21:55 PM
Any one notice that happening?
Title: Re: Arc/ Spark when attaching Battery
Post by: Dennis Adamisin on March 18, 2011, 03:52:36 PM
YES!
Kind of disconcerting isn't it?  I started using the Maxx Products arming plug.  I suspect it might still be arcing but it is internal to the plug (doubled Anderson power poles)
Post by: Igor Burger on March 18, 2011, 03:53:39 PM
It is usual especially with more cells. You need to charge ESC capacitors before connecting. Simplest way is to install paralel resistor into one of connectors and while connecting, just touch the resistor first, only then connect the connector directly.
Post by: Larry Wong on March 18, 2011, 04:03:23 PM
Thanks : I guess on my 4cell's didn't and the 5cell I was inside it just showed up more,  HB~> Z@@ZZZ
Post by: Igor Burger on March 18, 2011, 04:10:43 PM
 H^^
