  • August 02, 2025, 04:32:44 PM
Author Topic: Arc/ Spark when attaching Battery  (Read 945 times)
Offline Larry Wong
« on: March 18, 2011, 03:21:55 PM »
Any one notice that happening?
Larry
Re: Arc/ Spark when attaching Battery
« Reply #1 on: March 18, 2011, 03:52:36 PM »
YES!
Kind of disconcerting isn't it?  I started using the Maxx Products arming plug.  I suspect it might still be arcing but it is internal to the plug (doubled Anderson power poles)
Offline Igor Burger
« Reply #2 on: March 18, 2011, 03:53:39 PM »
It is usual especially with more cells. You need to charge ESC capacitors before connecting. Simplest way is to install paralel resistor into one of connectors and while connecting, just touch the resistor first, only then connect the connector directly.
Offline Larry Wong
« Reply #3 on: March 18, 2011, 04:03:23 PM »
Thanks : I guess on my 4cell's didn't and the 5cell I was inside it just showed up more,  HB~> Z@@ZZZ
Larry
Offline Igor Burger
« Reply #4 on: March 18, 2011, 04:10:43 PM »
 H^^
