  • June 17, 2025, 09:51:15 PM
Author Topic: Please remove this topic.  (Read 2249 times)
mark romanowitz
« on: July 03, 2018, 06:46:40 PM »
« Last Edit: April 10, 2019, 12:18:20 PM by mark romanowitz »
mark romanowitz
Re: Conversion of Sirius from IC to Electric.
« Reply #1 on: July 03, 2018, 06:56:14 PM »
« Last Edit: April 10, 2019, 12:17:21 PM by mark romanowitz »
Offline John Rist
« Reply #2 on: July 03, 2018, 09:19:21 PM »
If this is your first electric their is a learning process to get it grooving.   However once the setup clicks it is the same every time you flip the switch.  I do love the electric power.  Also the KR timer has worked well for me.   I like the fact that you can program it without a computer.  #^
mark romanowitz
« Reply #3 on: July 04, 2018, 10:17:36 AM »
« Last Edit: April 10, 2019, 12:17:04 PM by mark romanowitz »
mark romanowitz
« Reply #4 on: July 04, 2018, 06:44:02 PM »
« Last Edit: April 10, 2019, 12:16:28 PM by mark romanowitz »
« Reply #5 on: July 05, 2018, 01:53:07 PM »
Did you re-charge your battery to find MAh usage?
Yes, they were all at 3.85 per cell.. Put them on the charger to get them to storage charge afterwards.
Cell voltage is a really unreliable measure of the state of charge -- you need to charge the battery and see how many mAh went back in.  LiPo batteries are super-efficient as far as the amount of charge delivered vs. charge put in, though, so that's a really good measure.
mark romanowitz
« Reply #6 on: July 06, 2018, 10:10:49 AM »
« Last Edit: April 10, 2019, 12:16:13 PM by mark romanowitz »
mark romanowitz
« Reply #7 on: July 06, 2018, 10:14:35 AM »
« Last Edit: April 10, 2019, 12:16:02 PM by mark romanowitz »
mark romanowitz
« Reply #8 on: August 10, 2018, 09:53:48 AM »
« Last Edit: April 10, 2019, 12:15:47 PM by mark romanowitz »
Offline TDM
« Reply #9 on: August 10, 2018, 12:11:05 PM »
I guess welcome to electrics.
I made my debut to electric flight this year too. I haven't had a bad motor run since. If you can read instructions you can get a motor run in a few flights. Most timer with exception of Igor Active Timer and Fiorotti active timer will not give a 4-2-4 break in the motor run. If you desire that you have to get one of those. Weight of propeller is important. May I suggest using XOAR props. You can get them on Ebay or perhaps your local hobby store.
I would cut out the other hard maple mount too. really it only goes on for the ride.
If you know the battery usage then you an adjust for battery size. I think you want to be below 80% battery used in flight.
« Last Edit: August 10, 2018, 12:28:14 PM by TDM »
